Camper Trailer bearings
Submitted: Monday, Sep 04, 2006 at 17:30
ThreadID: 37418 Views:4687 Replies:5 FollowUps:8
I’ve heard it said that bearings in trailers which are used regularly tend to last longer than those which sit in the shed for 12 months without moving between trips. Something to do with turning the grease over or whatever. Wondering if anyone else shares this opinion and what you do about it. I take the trailer for a run ‘around the block’ every 6 months if I don’t manage to get away on a trip but I’m still not sure if it is more for the trailer of my own pining for the outback ;-).
Reply By: Member - Julie P (VIC) - Monday, Sep 04, 2006 at 18:57
Don't know about your theory - but we had a wheel bearing fail on our first major trip - to the Alice - all around and back down the Oodnadatta - got to Whycheproof in vic - pulled in for coffee - next stop Bendigo - coming back from shop saw black stuff all over wheel - 3pm Friday afternoon (we seem to have a fascination for 3pm Friday disasters - thats when we broke the rear window on our last trip as well) - anyway luckily the local dealer - terrific lot of blokes at Prestige I think it was helped John fix it as supplied a new bearing for us - had done some damage to the axle but managed to get home and had it fixed under warranty very quickly. But just goes to show - use it - don't use it - who knows????
jules
AnswerID: 192761
Reply By: cokeaddict - Monday, Sep 04, 2006 at 19:25
In theory you are correct, but it does depend on a few things....
Maintanence is critical, most problems ive come acrooss were caused by using incorrect grease. Mind you, using the best grease around doesnt mean its bullet proof either, 1 river crossing is enough to contaminate the grease esp if the seals are worn.
Poorly adjusted wheel bearings play a part too. too tight or too loose will speed up bearing wear which also damages the grease.
All the above could be a cause for bearings to collapse. If trailer is sitting idle for months on end, its possible for the grease to harden to the point where it becomes solid, so as soon as u drive off, its like having a stone in ur shoe, you dont get that smooth rotation and can cause the bearings to roll out of round.
What i do with my trailer is sit it on stands for long periods and whenever i go in garage i spin wheels a few times as i pass by the wheels. It also helps to have those grease caps fitted, helps keep water out when full.
Ange
AnswerID: 192770
Follow Up By: Vince NSW - Tuesday, Sep 05, 2006 at 12:17
Ange,
I fitted 2 lots of the Bearing buddies. but have resorted to the old grease caps.
The bearing buddies just seem to fall out on rought sections. Tried giving them a real good bash with a block of wood, but same result.
Have you or anyone else had the same problem ?
Vince
FollowupID: 450764
Follow Up By: cokeaddict - Tuesday, Sep 05, 2006 at 18:31
Hi Vince,
No mate I havent had that problem. But i have to say though, I probably havent done as many rought tracks as you have mate. Mine is just an off raod 7x5 box trailer which i use to transport my bike and camping gear when doing a big weekender. But I have to say mine were a bugger to fit, super tight and still are very hard to remove when i inspect bearings.
Ange
FollowupID: 450819
Reply By: Member - Duncs - Monday, Sep 04, 2006 at 20:02
I have a policy on wheel bearings.
I replace them regularly or prior to a major use of the trailer.
The camper gets new bearings and grease before every major trip or every two years whichever comes first. My trailer gets used at least one short trip (200 - 600km) and one long,but not major, (Broken Hill to Sydney) trip every year.
The box trailer which does the tip run and picking up building materials etc... It gets new wheel bearings regularly. It was first registered in 1975 and is on it's third set. It will get the 4th set in 2015, for it's 40th birthday, whether it needs them or not. They do get regular adjustment but that is all.
My thinking is this. The box trailer never leaves town and rarely carries a heavy load. If it does spit out a bearing I'll unhook it, go get the replacements and fit them at the side of the road.
The camper on the other hand gets some high-speed stuff, some ruff stuff and is used in remote areas where a bearing failure could be expensive, seriously inconvenient and quite possibly dangerous. I don't want a failure on that 'cause it will have a detrimental impact on the most important thing in life.....holidays
I hope my camper never sits for six months without being used, that would be the tragedy to end all tragedies
Duncs
AnswerID: 192777
Follow Up By: Shaker - Tuesday, Sep 05, 2006 at 09:37
I don't really understand why you would, do you do the same with your vehicle?
If you use the trailer regularly the bearings will be fine, if you don't, the ideal thing is to put the trailer on stands.
There is a theory that long periods of inactivity can create minute flats on the rollers causing the bearing to fail.
FollowupID: 450727
Follow Up By: Member - Duncs - Tuesday, Sep 05, 2006 at 11:22
The point is Shaker that it only costs me about $25 to replace the bearings at home and takes only an hour or so, even at my relaxed pace.
However if a bearing went while I was out in the mulga somewhere I would have to source the bearing, (yes I carry spares, a complete fully assembled hub to be precise, but once I have used it I then have to replace it) and use up valuable holiday time working on the trailer. That's why I do it at home before I go.
As for the car, it gets serviced regularly, every 5000km or six months, whichever comes first. Part of that servicing is the service/replacement of wheel bearings according to manufactureres specification. This can be reliably tracked because the car has an odometre. I can take an educated guess at the distance the trailer travels and at the time it spends sitting around but it is not accurate. So I invest a small amount of money and time before a trip to ensure things are working properly. Holidays are for lying around, exploring, playing with the kids, stuff like that not working on cars or trailers.
Duncs
FollowupID: 450753
Reply By: Gmouse - Tuesday, Sep 05, 2006 at 08:43
Like them or not, this is what I use on the boat trailer
as well as the off road rig, think they are great
AnswerID: 192884
Follow Up By: Gmouse - Tuesday, Sep 05, 2006 at 08:44
Help if left a link ay
www.bearingbuddy.com/
FollowupID: 450718
Follow Up By: Member - Duncs - Tuesday, Sep 05, 2006 at 11:24
Gmouse,
Have you ever had a problem with them getting knocked off in the bush? Someone once told me this was a problem.
Duncs
FollowupID: 450754
Follow Up By: Gmouse - Tuesday, Sep 05, 2006 at 11:39
Hi Duncs
Not at all, but then again l have Range Rover rims
on my trailer the centers stick out a bit more giving
good protection
or you could use a bit of loctite on them
Remember that most get Knocked off in car parks lol
FollowupID: 450758
Reply By: Longreach - Tuesday, Sep 05, 2006 at 09:45
Many thanks everyone.
I think I should do 3 things.
1. Go on more trips.
2. Put the trailer on stands when home.
3. Get the bearings checked/replaced prior to a major trip.
AnswerID: 192890
Follow Up By: Moose - Tuesday, Sep 05, 2006 at 13:37
G'day Longreach
Get your hands dirty and service them yourself before a big trip. Easy job. Save dollars and get to know what to do should one fail on a trip. Take spares and you could replace it yourself and save yourself from a potentially ruined holiday.
FollowupID: 450773
