Making water taste better out of plastic tanks
Submitted: Tuesday, Sep 05, 2006 at 12:39
mule
Has any body got any suggestions on how to make
water tanks, ......any products......suggestions...... I know stainless steel tanks are better but I am stuck with a plastic one untill I do better.
thanx
Reply By: Member - JohnR (Vic)&Moses - Tuesday, Sep 05, 2006 at 12:57
Leave
water with bicarb soda in it for a while has been
the tip of the past mate, perhaps drain it and change it afterwards. I think whisky is another option to flavour the
water;-)
192918
Reply By: Moose - Tuesday, Sep 05, 2006 at 13:06
G'day Mule
Is the
tank the problem? Perhaps the
water is already tainted before getting into the
tank - do you allow the hose to run for a while before filling? Personally have never had bad taste from
water tanks by following above procedure.
192920
Reply By: anoldbuddy - Tuesday, Sep 05, 2006 at 13:16
We used to have similar taste issues with the tanks in our van and we were advised to make some simple changes: 1) ensure that only food quality tubing was used everywhere; 2) ensure that no light can enter - in other words use black tubing where there is any suggestion of sunlight; 3) don't fill the tanks through garden hose - use the same food quality hose that you use in a van
park when connected to mains pressure
water; 4) where possible leave a fair amount of
water in the
tank when not in use.
Preceding all of the above changes, we flushed the tanks thoroughly - tried puratabs (chlorine boost) but they offered only another taste.
Now our
water is always pleasant to taste even after a month or two of inactivity. The other decision we made was to add a
water filter (two stage including a 0.5micron ceramic cartridge) for
water used specifically for drinking or for tea & cooking - best investment ever for that
water is really as good or better than any bottled
water available.
How that helps....
192924
Follow Up By: Member - Boo Boo (NSW) - Tuesday, Sep 05, 2006 at 14:28
Spot on! If you don't use food quality plastic your more often than not stuck with a taint.
Regards Bob
450779
Follow Up By: Member - Ian W (NSW) - Tuesday, Sep 05, 2006 at 20:44
Hell!
I must just be damned lucky!
I fill my camper trailer
tank via the ordinary old garden hose, never drain or flush and have never had aproblem in over five years.
No help to you I know, so maybe I need to sit down and have a think as what it is I actually do or don't do to have finished up the way I have.
Ian
450842
Follow Up By: maxhugen - Wednesday, Sep 06, 2006 at 11:16
Could it be that you let the garden hose run for a bit before filling the
tank? This would get rid of any
water that was left in the hose, which could get tainted.
450929
Follow Up By: Member - Ian W (NSW) - Wednesday, Sep 06, 2006 at 15:36
Good question, but when I thought about no, I just take the nozzle of the end of the hose because I have to feed it around a stupid little bend. Then I turn the sucker on and let it blow till the
tank overflows out the filler.
Once again, just lucky todate I suppose.
What are the odds now that when we go away in October the
water will be tainted
Ian.
450977
Reply By: Member - Omaroo (NSW) - Tuesday, Sep 05, 2006 at 14:33
We fill 1,000 litre tanks from our river & then tralier them to our permanent
campsite at Omaroo. The
water stays in these tanks for weeks on end, and can get quite a taste up.
The way we find works the best is to get a simple Brita
water filter jug. Works a treat. Removes most of the plasticy taste and also removes river-borne colour such as that from tannin. Simple and cheap!
Chris
192939
Reply By: greydemon - Tuesday, Sep 05, 2006 at 17:05
I am reminded of a quote attributed to W.C Fields ...." I always add a drop of
water to my whisky, and vice versa".
192969
Follow Up By: Member - Duncs - Tuesday, Sep 05, 2006 at 21:11
You beat me to it, I was simply going to say...........scotch!!!!
Duncs
450847
Reply By: Member - Boo Boo (NSW) - Tuesday, Sep 05, 2006 at 18:15
OK Chris, I give up were is Omaroo?.
I've looked on a couple of maps with no success.
Regards Bob
192980
Reply By: Max - Sydney - Tuesday, Sep 05, 2006 at 19:34
Mule
I think this is the lazy person's way to do it, but it works for us. When we have drawn off a bit of
water from the
tank (or even from the direct connection to the caravan
park supply) we fill a plastic jug (or the kettle) and let it sit. After an hour or so it is potable to the exacting taste buds of the managing partner, and saves replacing van piping, hoses etc. We did buy a (single stage)
water filter from a caravan place to no effect.
We use it for cuppas ands drinks of
water. All else comes out of the
tank / hose with no problem.
Max
192996
Reply By: Muddies Doe(Trippn) - Tuesday, Sep 05, 2006 at 19:52
Hi Mule
I use any non brand named vinegar. Add as much as you feel you need to the
water and drive around for a day or two. Empty out then fill it up a bit, let it swish around while driving, you may need to rinse it out a few times? After that the
water should taste OK. The same can be done with vanilla essence. I find the vinegar is more effective.
I have never had a problem doing this method so I hope this remedy will work for your containers.
Cya
193003
Reply By: Member - Phil G (SA) - Tuesday, Sep 05, 2006 at 22:12
Solved our
water tank's plastic taste by replacing all the hoses - filler, breather and the tap hose - with Nylex 1/2 inch blue, braided
drinking water hose. There was no problem with the
tank.
And I bought a charcoal canister from the
water filter
shop for $50 and use it when filling from the home tap.
193050
Follow Up By: Farrelly - Friday, Sep 22, 2006 at 19:17
How do you find the Silent Armours ??
I run MTRs on my 75 series troopie and recon there the best this since sliced bread
Do you think the resist punctures in the ruff stuff?
454182
Follow Up By: Member - Phil G (SA) - Friday, Sep 22, 2006 at 21:20
Silent Armours are fine. I've done 10,000k, including 2 desert trips - but managed to get a sidewall stake in one. No wear or chipping. I had a set of MTRs before them - 45,000km including a heap of desert and other offroad trips - never had a puncture, but I managed to get the sidewall of 2 tyres to delaminate a bit (got a bulge). Goodyear replaced the set of 4 prorata which was better than I expected.
Both these tyres have been equal or better than other brands on the same trips. If you want an AT tyre, go the Silent Armours. If you want an aggressive tyres, go the MTRs again.
phil
454202
