Recommended Route
Submitted: Tuesday, Sep 05, 2006 at 13:06
ThreadID: 37447 Views:2296 Replies:3 FollowUps:3
I am thinking of doing a caravaning trip from Shepparton,Vic to Eden,N.S.W. and ask what would be the best route that would not be too hard on my 1990 Ford Maverick. (very hilly country)
Regards.....Greg.
Reply By: roosey - Tuesday, Sep 05, 2006 at 14:00
Greg,
The route I'd take would be straight down Hume to Melb., then via Ring Rd & city link throught to Princes Highway and then keep going. Suggest this is easiest & fastest way.
Roosey
AnswerID: 192929
Follow Up By: Member - Craig M (VIC) - Tuesday, Sep 05, 2006 at 16:18
Greg, Agree with Roosey. I go there reasonably often from Romsey, and while the map looks tempting over the mountains or through Canberra I reckon you'll be happier going the other way. I have done it through Canberra and spent a night there also, but would still go through Melb. As a matter of interest if you haven't been to Lake Wonboyn area, check it out.
Regards,
Craig.
FollowupID: 450792
Follow Up By: Member - Ian W (NSW) - Tuesday, Sep 05, 2006 at 20:37
I support Craigs comment re Wonboyn Lake, glorious spot on the coast.
I don't particuarly like Wonborn Village itselfe prefer going in from the other side, which entails entering from the Eden Woodchip Wharfe side for want of a bwetter description
Ian
FollowupID: 450840
Reply By: Leroy - Tuesday, Sep 05, 2006 at 20:52
check out www.whereis.com.au You can map either by shortest time or shortest distance. You will save 1hr and 100km if you go via Cooma but it is hilly.
Leroy
AnswerID: 193022
Reply By: Member - Ivan H (NSW) - Wednesday, Sep 06, 2006 at 11:56
I'm sure your Ford Maverick would do ok on the run via Wodonga - Khancoban - Jindabyne - Bombala - Pambula - Eden.
AnswerID: 193122
Follow Up By: 1arm - Wednesday, Sep 06, 2006 at 15:41
The only problem with this is it depends on what sort of caravan you are towing. Having gone from Sheparton to Jindabyne last January I wouldnt do it towing a caravan at all.
Evan
FollowupID: 450980
