DIY Powerpack
Submitted: Wednesday, Sep 06, 2006 at 17:51
steep
Hi all,
I have been reading the many archived posts about diy powerpacks.
I am looking to purchase a Waeco 50l (or something similar) but working out how I can power it for our once a year fishing trip up north to
steep point. We don't use the 4wd's at all for about 5 days and take different vehicles each year so an external powerpack is a good idea (I don't have a dual battery and don't want one).
We take a large generator which we run for 5 hours in the morning and 5 hours in the evening.
So I was thinking of plugging a charger to the genny, a DIY powerpack (made out of a $60 casing and a marine battery) to the charger and then the fridge.
By running the genny every 5 hours I think the battery will continue to be topped up and we can run the fridge pretty cold 24hrs a day.
So my questions -
Will it work?
Is the battery OK (to keep the costs down I can take it out of the boat for the week). So not asking if it is ideal but will it work without damage?
Is there something easier? ie leaving the fridge in the car and just recharging the main battery..... but then I would need to continue changing leads and plugs.
Also don't want a 3-way fridge as the rest of the year the 12/240 will do fine
Thanks for reading this long first post and hopefully for your advise.
Craig
Reply By: Member No 1- Wednesday, Sep 06, 2006 at 18:00
it will work
but it is advisable to get a smart charger...something that will put in say 20amps or more at first
193184
Reply By: Robin - Wednesday, Sep 06, 2006 at 18:46
Craig
I couldn't quite see this in your post - But you should run the fridge off the gennie via 240V input whilst charging which will make things last longer.
And it should be set to freeze, with gennie run for couple of hours in a couple of sessions as opposed to 5hrs constant.
By doing this you will minimze the temperature differential which is really how you lose heat (
well gain it actually).
You can't really go wrong with what you propose as long as you keep a bit of an eye on fridge temp , because worse case you just run another session with the Gennie.
Robin Miller
193191
Reply By: Pajman Pete (SA) - Wednesday, Sep 06, 2006 at 19:15
We have a similar scenario and use 2 ex gopher gell cells wired in parrallel to give 70AH. Cost = < $50 from any gopher place.
193194
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Sep 06, 2006 at 19:45
We have done the hard yards for you. You need a 'FLYER'
193205
Follow Up By: Leroy - Wednesday, Sep 06, 2006 at 22:33
is this a 9 stage charger? Does it come in a compact enclosure? will it make my coffee?
Leroy
451080
Follow Up By: D-Jack - Wednesday, Sep 06, 2006 at 22:51
The guy's asking for advice. Please don't send him a 'flyer'!
451084
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Sep 07, 2006 at 06:11
Dry ice lasts up to 'FIVE' days. 9 stage defrost. :-)
451100
Reply By: Member - Jeff H (QLD) - Wednesday, Sep 06, 2006 at 22:22
Craig,
. Along with the above comments, I guess you already 'wrap' the 'fridge in bedding during the day, with a pillow on top?
193231
Reply By: Mike Harding - Thursday, Sep 07, 2006 at 06:57
If you're running the gen for 10 hours a day (how do you stand the noise?) you hardly need a battery at all.
Mike Harding
193254
Reply By: steep - Thursday, Sep 07, 2006 at 11:08
Thanks for some of your comments and some of you for advise.
Pajman Pete, so would I wire the two batteries up within the casing?
This fridge is going to be used for drinks for about 8 thirsty guys or for freezing fridge so I am guessing that it will need to be run for more than 10 hours a day. Also the genny is hard to avoid unless we buy a solar panel each and it runs when we are hopefully catching fish.
193275
