35mm over Warragamba
Submitted: Thursday, Sep 07, 2006 at 10:31
ThreadID: 37502 Views:1997 Replies:3 FollowUps:4
Yup, good drop last night. Bit over 35mm all over the Warragamba catchment (40mm at home- just 10 k from 'Lake' Burragorang.
And the reports will tell us storage has risen by 0.000000001% !!!
Reply By: Truckster (Vic) - Thursday, Sep 07, 2006 at 10:54
lmao i thought you were going to say something like DROUGHT IS OVER like other forums
AnswerID: 193274
Reply By: 3.0turbob - Thursday, Sep 07, 2006 at 12:19
Yeh, report on the radio this morning said Sydney had around 100mm !! Pity we can't push the clouds over the catchment area.
AnswerID: 193281
Reply By: Member - JohnR (Vic)&Moses - Thursday, Sep 07, 2006 at 12:21
You would have to get some soil saturation before you get runoff much. Need more everywhere......
AnswerID: 193282
Follow Up By: Pavo - Thursday, Sep 07, 2006 at 12:28
Yep. It'll be nice when all the rivers are flowing again.
FollowupID: 451163
Follow Up By: Member - JohnR (Vic)&Moses - Thursday, Sep 07, 2006 at 13:28
you can say that again. I haven't had a good year of kayak paddling since 1997.
FollowupID: 451174
Follow Up By: pt_nomad - Thursday, Sep 07, 2006 at 13:34
JohnR - Your on the money.
Just looked at you pics - the desert wheel alignment one is interesting. Is it a result of a roll over?
To further the post - some hydrology 101.
Before rivers start to flow you need water to start flowing across the land to channels - runoff . Runoff only occurs once the land and vegetation between where the rain fell and the channel can not absorb or store the water received. In an urban area you can see this on your concrete driveway - the first few broad sprays with the hose result in wetting of the concrete - but no visible pooling or flow. All the little holes in the concrete absorb and store the water, once they are full you get flow.
Concrete can be considered to be a water proof surface compared to native bush land, so the trees, grasses and land can soak up quite a bit of water before it runs off.
Similar to watering you garden, when you water slowly all the water is absorbed. Low intensity rainfall can be easily absorbed by the bush. Hi intensity rainfall ( like a jet on a hose rather than a spray) delivers to much water for the slow absorption process to work - thus it gets converted run off quickly.
The other factor, assuming that there was sufficient rainfall to convert to runoff is travel time. I takes time for water to travel across the land, down rivers and into storages. It's not quite as fast as tipping water into he bath and seeing an instantaneous rise in level.
Of course the other explanation is that the data on he dam could be out of date or the instrumentation stuffed :)
You could probably check the inflow rivers to the dam to see if any water is on its way. www.waterinfo.nsw.gov.au/drr/index.shtml
Cooee Paul
BTW - 0.000000001% change would probalby be beyond the accuracy (precision) of the measuremnt systems in place.
FollowupID: 451176
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Sep 08, 2006 at 07:37
Paul, the pic was a rollover after a little bit of rain on the Strz Track. Third day of their married life together started badly. They have a babe now so that will keep them stable.
Am well acquianted with what makes a runoff situation as you seem to be. Farming here with and without concrete. Have had high intensity, but could do with some of that now......
FollowupID: 451317
