Jerry cans on roof ?
Submitted: Friday, Sep 08, 2006 at 10:20
ThreadID: 37534 Views:3656 Replies:16 FollowUps:13
Hi all, whilst meandering through a few posts, as one does when you have some spare time on your hands, I noticed that a few members suggested that jerry cans not be carried on roof racks. Apart from the obvious - altered center of gravity, wind drag, vunerability to low obstacles etc, are there any issues with this practice that are not so obvious. Dont forget that Im only a 2D thinker......nissnut.
Reply By: Member - Andrew W (SA) - Friday, Sep 08, 2006 at 10:37
like putting them up and down ... squashed my thumb doing it once.
and being sure that they don't leak or break.
And then getting it out of the jerries without it going on you or your clothes ...
AnswerID: 193456
Follow Up By: Crackles - Friday, Sep 08, 2006 at 19:10
Easy fixed........swap the jerries for boat fuel tanks. Fill them on the roof then use the fuel line (complete with squeeze pump) & siphon direct into tank. They're tough, no mess & requires no heavy lifting :-)
Cheers Craig................
FollowupID: 451475
Reply By: Member - Phil G (SA) - Friday, Sep 08, 2006 at 10:43
Went away with someone that had 6 steel jerries of diesel on top of a Troopie. 3 of them leaked on the first dirt road - his tent that was next to them was covered in diesel and unusable. And the dust really stuck to the roof!
Need to pad them with carpet to prevent rubbing.
Weight is the main factor - empty them as soon as able.
In my experience, the steel ones tend to leak, plastic ones are better.
AnswerID: 193458
Follow Up By: Exploder - Friday, Sep 08, 2006 at 16:22
I don’t trust plastic jerries personally, I go with steel.
I have 2 steel Jerries’ build date stamped on em.. 1940 U.S ARMY still going strong and they have seen plenty of action.
Like to see a plastic one last that long, Steel’s real. LOL
FollowupID: 451416
Follow Up By: Shaker - Friday, Sep 08, 2006 at 18:52
Most jerry cans are German, hence the name. The US ones had big screw on lids & are quite hard to find, they also had very positive screw on pourers.
FollowupID: 451466
Follow Up By: Member - Phil G (SA) - Friday, Sep 08, 2006 at 23:05
Exploder,
Steel jerry cans have gone downhill in recent times. Some are very thin, and the seal and latching mechanism is cheap and nasty. Like you, I had some steel jerries dated in the 1950's that have done good service, but I've used the Rheem and Willow plastic jerries a lot in recent years and gave become less cynical.
Shaker, can you point me to a brand new German made jerry can that I can buy today!! The new ones aren't what they used to be.
FollowupID: 451528
Follow Up By: Shaker - Saturday, Sep 09, 2006 at 19:07
Phil, unfortunately I can't, but Aussie Disposals have some very recent ones in excellent condition.
FollowupID: 451623
Reply By: joc45 - Friday, Sep 08, 2006 at 11:07
On this subject, does anyone know how the plastic jerries handle being laid on their side or their edge on a mesh floor on the roof rack with carpet separating?
What I'm trying to ask is whether the jerries are only designed to be carried vertically, or will the sides also tolerate a pounding.
Gerry (no pun intended)
AnswerID: 193461
Follow Up By: oldmagpie2 - Friday, Sep 08, 2006 at 11:34
ive tried them on their side & they leaked, put them on their edge with outlet facing up & never had any problems but you have to keep them fairly strapped & dont overfill them, thats in a trailer. cheers
FollowupID: 451369
Follow Up By: Member - Glenn D (NSW) - Saturday, Sep 09, 2006 at 11:55
I have the " Rheem " ones and have had them laid flat on the rack no worries , just had a piece of canvas under them. All I do is empty them as soon as you can.
Glenn
FollowupID: 451578
Reply By: Robin - Friday, Sep 08, 2006 at 11:19
Hi Nissnut
The jerries are meant to be carried vertical , and on the roof is not a good choice to start with ,let alone vertical as I have seen some.
Heat from the sun can expand things and put a lot of pressure on seals.
I have preferred to carry plastic jerries inside my patrol,before on the roof.
Laid on there side on floor, but only some like Willow from supercheap have sealing system that is acceptable to me for this purpose.
Robin Miller
AnswerID: 193467
Reply By: Member - Doug T (W.A) - Friday, Sep 08, 2006 at 11:43
worst case scenerio,
jerry can of petrol on roof, jerry can leaks, driver smokes,
AnswerID: 193473
Reply By: ingo57 - Friday, Sep 08, 2006 at 12:07
I carried plastic jerry's on the roof this year when we did the Simpson. Bought the jerry's from super cheap and laid them down on the roof (lids to the top) on a piece of carpet and slid carpet tiles between them to prevent them from rubbing through each other. We did not have any leaks or problems but did empty them as soon as we could.
Not the best Idea to fill them on the roof either like we saw other people do, you should always put them on the ground to earth them, is safer and a bit more effort involved but much cheaper than a long ranger.
AnswerID: 193476
Follow Up By: Crackles - Saturday, Sep 09, 2006 at 15:33
How does one earth a plastic Jerry can??????
FollowupID: 451599
Follow Up By: ingo57 - Saturday, Sep 09, 2006 at 16:00
By putting them on the ground!!!!! Static electricity Crackles. A lot of out back servos have the signs on their petrol bowsers that jerrys are to be on the ground when filling, we only learnt this on our last trip when we were told to pull them off the roof at Innaminka to fill them.
I seem to remember a year or so ago a guy filling a jerry can in the back of a ute, whilst he was doing this his jumper was rubbing on the toneau cover (producing static electricity) which reacted with the fuel vapours. Next thing he was on fire.
FollowupID: 451601
Follow Up By: Crackles - Sunday, Sep 10, 2006 at 16:55
I was under the impression that earthing was only for steel jerries & drums?(I stand corrected) Our local fuel station would allow filling of plastic containers on the back of our trucks but not the steel 44 gallon drums. (required a jumper cable clipped on to earth)
FollowupID: 451716
Follow Up By: ingo57 - Monday, Sep 11, 2006 at 09:43
I tend to agree that it would only apply to steel jerry's but I was still stopped at Innaminka from filling them on the roof and told to put them on the ground, Since then Ive allways just pulled them down.
Sounds like a job for"Myth Busters"
FollowupID: 451811
Reply By: Groove - Friday, Sep 08, 2006 at 12:14
I have carried jerry cans on the roof on a couple of occasions. I only use Rheem plastic ones. I lay them on a scrap of marine carpet and secure them with ratchet tie downs.
I empty them as soon as there was room in the tank to take the extra fuel to get the weight off the roof ASAP, The only other thing on the roof is a spare anyway.
I had no problems in very rough hot conditions but they were not up there for a long time, only a couple of days. I dont lay them flat but I lay them on the narrow side.
As for them heating or leaking, I recon that has just as much chance of happening wherever you put them.
AnswerID: 193478
Reply By: Member - Andrew W (SA) - Friday, Sep 08, 2006 at 12:34
Only ones I have had leak were the Rheem ones.
I do put them on their side on rubber mat whenever I have trouble with low hanging branches, and haven't had an issue. I do check the lids are real tight.
I generally have used the yellow ones from supercheap and they have stood up fine to 12 months hard work.
I am using diesel, so the roof filling is not a problem and works for me.
Ciao for now
Andrew.
AnswerID: 193479
Reply By: Grizzle - Friday, Sep 08, 2006 at 13:33
I met a guy in Broome with a 4.2 TD Patrol. He had bought 2 x 25 Litre marine plastic tanks that are used in Tinnies etc. The benefit being their low height and large footprint. He would then siphon down when required. A more expensive option but seems safer.
AnswerID: 193487
Reply By: Willem - Friday, Sep 08, 2006 at 15:22
I have carried 4 jerries on the roof rack lying down on occasions. Its not advisable but other means aren't always available. I have steel jerries and have seldom had them leak. The secret is to renew the seals every so often. Lifting them them up or down is no issue as I am reasonably tall. Just lay them down on a good piece of tube/rubber/ folded tarp and tie them down with ratchet straps.
I now carry 12 jerries lying down in the bottom of my trailer for long trips out in the never never. This gives me a fuel capacity of 330 useable litres of diesel.
AnswerID: 193507
Reply By: Member - Shane D (QLD) - Friday, Sep 08, 2006 at 18:18
I went to cape york with 6 steel jerry's on the roof rack and had them tied down with good ratchet type straps so they couldn't move and rub excessively and drove accordingly, being aware of the whole gravity thing.
The main reason was I didn't have to get up there every day,and once they where empty,they where out of the way(and light)leave the cargo area space(inside the vehicle)for the stuff you have to use during day/night dust free and DRY!!!!
AnswerID: 193555
Reply By: Pajeroman - Friday, Sep 08, 2006 at 19:48
I have used both steel and plastic to carry petrol and would only use steel now. The plastic ones tend to expand in the sun and stretch straps and then when they cool even slightly the straps are loose.
I now use timer and threaded rod to bolt mine down. They are filled from the roof, which has caused no problem and then lifed down. I have syphoned from the roof direct to the tank but this is slow, but causes no problem.
I have carried 6 Jerries ont he roof but like to get this down to 2 ASAP due to weight.
AnswerID: 193584
Reply By: nissnut - Friday, Sep 08, 2006 at 21:19
A variety of opinions. They all seem to have their pros and cons. Thankyou all for your responses. Ive got 4 jerry cans so Ill strap 2 on the roof and carry 2 in the back, see how they go. nissnut ps Im a smoker.........................BOOM......................................
AnswerID: 193610
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Sep 08, 2006 at 23:22
Boom is right!!
FollowupID: 451530
Reply By: Tim HJ61 (WA) - Friday, Sep 08, 2006 at 23:22
I saw a 4WD arriving into Perth a few weeks ago with a line of jerries across the front of the roof rack. Must have been 7 - 8 across the rack! 160kg just in the fuel, who knows what they had on the rest of the rack if they thought 160kg across the front was a good idea! I'm sure the engineer who designed their roof rack didn't incorporate it being used like that.
I've heard of/seen but not used, flexible fuel bladders that boaties use. You can get them for water storage too, but they can sit on the floor behind the front seats and are strong enough to take the kids weight and you can put a bit of carpet over it if you're worried about holing it.
Tim
AnswerID: 193628
Follow Up By: Member - Andrew W (SA) - Saturday, Sep 09, 2006 at 10:53
just ordered one from Fabric Solutions Australia for water at this stage.
The fuel one (for the roof rack though (110 litres) will come next.
There is a bit of a problem - roof rack mounting points are only supposed to hold 150kg according to Toyota ... although mine regularly has to have more.
Oh well - the car has a GVM of 3850 too and without passengers and luggage I start at 3040.
Without an alternative, I carry on with care and attention.
Ciao for now
Andrew.
FollowupID: 451573
Reply By: Member - Woodsy - Saturday, Sep 09, 2006 at 06:37
Hi nissnut
My experience is only with steel jerrys both on the roof and inside the 4by.
Being a short ars., jerrys on the roof are a PITA and I don't like all that weight up there, for centre of geavity reasons and potential roof rack/gutter damage.
A number of years ago I did the Connie Sue in my 3.0 petrol GQ and as I could not get any good info on the track I decided to carry 7 jerrys. Made a steel frame to bolt across behind the front seats and bolted it down to existing rear seat holes etc (rear seats were out). Made sure that jerry seals were OK and strapped them into the frame. Solid as solid. Just laid soft gear, clothes bags, sleeping bags etc on the top of them.
No leaks, no smell, easy & convenient. Safe?
The GQ has gone but that frame has been modified by a friend to take 4 jerrys inside his Rangie with again, excellent results.
Just me experience, not a recommendation.
Happy 4 wheeling
Woodsy
AnswerID: 193640
Reply By: Member - Roachie (SA) - Saturday, Sep 09, 2006 at 10:24
A few blokes have mentioned using carpet on the rack......
I just bought a new roof bag (Halls Canvas, Adleaide) and I wanted to avoid it having to sit directly on the ARB rack's mesh floor. Wasn't too keen on the carpet idea , as when it gets wet it'll be heavy and smelly.
So, I hit on the idea of those rubber squares that clip together like jigsaw pieces. They are 600mm square......perfect for a 1250mm x 1700mm roof bag.
As for the jerry cans, I've had a couple of the black plastic Rheem ones....just gave them away to Brew69 as I don't use them anymore. I also have 2 of the half-height steel jerry cans (10 litres each). I use these for petrol for the Yammie gennie. They are much easier to hoik up onto the rack. I make sure I never fill them right to the top, so that they won't over expand if left in the sun. Probably only needed to get one of 'em anyway.....but I like to have 2 of everything!
Roachie
AnswerID: 193665
