2001 Suzuki Grand Vitara
Submitted: Friday, Sep 08, 2006 at 13:11
ERIC DRUMMOND
I am thinking about installing driving/fog lights in the indentations in the lower front bumper bar.Has anyone done this, if so some guide lines would be a help.
I. E. Do you need to remove the bumper bar?
How do you cut out the cut outs if this is required?
Can I wire relay direct to wires leading to high beam?
I need all this dumb stuff advised & more.
Eric D.
Reply By: MAVERICK(WA) - Friday, Sep 08, 2006 at 15:24
first you need to work out if they are fog lights or
driving lights - fogs do not go through high beam and require lower amp wire -
driving lights need to go through high beam and need higher amp wire. rgds
193510
Follow Up By: Gerhardp1 - Friday, Sep 08, 2006 at 18:50
Can you clarify what you mean by low/high amp wire?
If I fit 2 55 watt fog lights why would I need lower amp wire than if I fit 2 55 watt
driving lights?
451464
Reply By: ERIC DRUMMOND - Saturday, Sep 09, 2006 at 12:04
Information on driving lihts only
Eric D.
193672
