80 Series Dual Battery holder
Submitted: Monday, Sep 11, 2006 at 18:39
BenSpoon
I have recently had to remove my dual battery tray (mounted in the usual spot on the driver's side behind the headlight) and now I need a replacement. The only place I can see that the 2nd battery can fit now is over the shock tower on the passenger side.
I have heard of these trays before, but can not find anyone that sells them on the internet or in
Perth. Can anyone help? I am even happy to swap the one I have (fully moulded, black powdercoated OL battery tray with clamps) for the one I need if anyone has one.
I am not all that keen on getting a random fabricator to knock one up as it seems the only support nearby is from thin sheet metal which will not support the battery's weight, and mounting a brace between body and shock tower I am told is yellow sticker material.
Cheers.
Reply By: Alloy c/t - Monday, Sep 11, 2006 at 19:24
I bought what you are after from another EOer a cpl of mths ago ,have not fitted it yet , not interested in a swap however , let us know if your interested in buying ,
194017
Follow Up By: BenSpoon - Wednesday, Sep 13, 2006 at 11:44
depends how much it is and how much postage will be...
why havent you fitted it yet?
send us an email- bdelbianco at croesus dot com dot au
Cheers.
452220
Follow Up By: Alloy c/t - Wednesday, Sep 13, 2006 at 17:21
Email sent.
452289
Reply By: Derek from Affordable Batteries & Radiators - Monday, Sep 11, 2006 at 19:33
Hi Ben
Sounds like a custom job. I have not seen one in that position. You would need support to the guard as
well as to the wheel arch.
Let us know what you find and send a photo before and after.
Regards Derek.
194020
Follow Up By: Alloy c/t - Monday, Sep 11, 2006 at 19:41
1 bracket / bolt to an already captive nut on firewall ,,another to same on inner guard and another to shock mount ,,solid as , will fit 305mm battery , not even nesesary to move or shift anything.
451909
Reply By: Member - Mal B - Monday, Sep 11, 2006 at 20:39
why move the battery fits ok in that spot mal b
194032
Follow Up By: BenSpoon - Wednesday, Sep 13, 2006 at 11:42
I have turbo piping in the way of where it used to be- That is why I had to remove it.
452219
Reply By: Member - Mal B - Wednesday, Sep 13, 2006 at 19:58
could you let me know how you go with the bracket i want to fit a 3rd battery to my 80 series thanks mal b
194409
