uhf cb radio problem
Submitted: Monday, Sep 11, 2006 at 21:02
Dan
I have a GME tx4400 in my rodeo. say im talking to a friend, i can hear him clear as day, yet it sounds like im whispering to him.Even if he turns his CB up full, i still sound like a mouse!
Anyone know whats wrong with my radio?
thanks
Dan
Reply By: Doggy Tease - Monday, Sep 11, 2006 at 21:17
1) how old is the set?
2)are you/it always in dusty conditions?
3) replace/clean out the mic,,,,,this will help no end to solving your problem.
meow.
rick.
194046
Reply By: Member - AVA 191 (QLD) - Monday, Sep 11, 2006 at 21:40
Have you got a better aerial than him maybe???
194052
Reply By: Member - Nick (Kununurra) - Monday, Sep 11, 2006 at 21:50
Get him to turn up his volume.LOL
194055
Reply By: Member - JohnR (Vic)&Moses - Monday, Sep 11, 2006 at 22:28
I know some people that don't actually talk into the microphone Dan and they can hardly be heard. Perhaps you don't....... I know I can sometimes feel the fingers against the beard, that close with a trimmed beard!
194064
Follow Up By: Dan - Monday, Sep 11, 2006 at 22:45
Thanks guys for your responses.
The radio is about 1 year old and basically never see's any dust. I've borrowed friends GME mics and still the same result, so i've rulled out a faulty mic.
I have a middle of the range 6db ground independant aerial.
And i've also tryed yelling into the mic, but still been told im whispering.
hope this helps
Dan
451952
Reply By: Mad Dog - Vic - Monday, Sep 11, 2006 at 22:49
Sounds like the radio has low FM deviation, a radio tech will check it out for you.
194070
Reply By: howie - Monday, Sep 11, 2006 at 23:00
a test of your raidio with an S.W.R. meter would be handy. bab connections were the cause of 95% of the faults i've cleared.
good luck
194073
Follow Up By: howie - Monday, Sep 11, 2006 at 23:04
i'll spray that again!
radio or even bad connections.
especially twixt radio and aerial.
this keyboards gone #aulty again, #ucking thing
451960
Reply By: joc45 - Monday, Sep 11, 2006 at 23:46
I recall that GME give a 2 year warranty with their products (to original owners). Suggest you take it back.
But the problem doesn't sound like an antenna issue (not swr). More like a transmit modulation problem; ie, either the mic is faulty, or the transmitter has a problem.
Gerry
194078
Reply By: SA_Patrol - Monday, Sep 11, 2006 at 23:51
Your finals could be gone,
194079
Reply By: nonon - Tuesday, Sep 12, 2006 at 01:56
Are you the only one he has the problem with?
194084
Reply By: Big Woody - Tuesday, Sep 12, 2006 at 05:03
Test your antenna cable with a multimeter for a dead short. Just remember to remove the antenna first.
One of your connections may have a strand of braid touching the inner core of the coax.
Good luck,
Brett
194086
Reply By: Rosco - Qld - Tuesday, Sep 12, 2006 at 08:43
Dan
Big woody's on the money. I had the same problem and it turned out to be a broken connection at the aerial. The cable running through the big springy thingy at the base was the issue as apparently if the aerial is bent fully over the cable can be strained.
Get that checked/fixed and all should be OK.
194096
Follow Up By: Grizzle - Tuesday, Sep 12, 2006 at 09:12
I agree, had the same problem. Soldered arial connection and co-ax plug at other end. Works great now
451994
Reply By: Troop-a-dour - Tuesday, Sep 12, 2006 at 16:08
Can you swap radios (car to car) ?? That would eliminate antenna problems or identify if it is the radio thats faulty??
194162
