Engel Fridge
Submitted: Tuesday, Sep 12, 2006 at 12:55
ThreadID: 37649 Views:2499 Replies:4 FollowUps:6
Hi all just a quick question, I have read on here before and for the life of me cant find it, how do you change the battery for the digital readout in the 40L anniversary model. I know it was easy but dont want to touch it till I get the correct procedure. Thankyou Regards Steve M
Reply By: bellie - Tuesday, Sep 12, 2006 at 13:26
Steve,
If you lift the lid on the fridge you may find the instructions there. I know its there on mine.
Rgd's Todd
AnswerID: 194131
Follow Up By: madcow - Tuesday, Sep 12, 2006 at 14:35
What sort of battery is it?
FollowupID: 452037
Reply By: madcow - Tuesday, Sep 12, 2006 at 14:39
Just rang Engel and it is an LR44 qty of 1
AnswerID: 194143
Follow Up By: Member - Stephen M (NSW) - Tuesday, Sep 12, 2006 at 18:58
Thanks there madcow, appreciated can get battery prior to pulling apart, unfortunately I have miss placed the instructions so not sure how to pull apart but will ring engel tomorrow, hopefully they will inform me how. Regards Steve M
FollowupID: 452083
Follow Up By: madcow - Wednesday, Sep 13, 2006 at 07:42
i guy I work with only asked me the same question 10 mins before I read your post. As he does not have access to the net i read your post and gave them a call. I'm sure he said the instructions were under the lid.
FollowupID: 452160
Reply By: Member - Stephen L (SA) - Tuesday, Sep 12, 2006 at 20:40
Hi Stephen,
You only have to remove 6 screws, the 4 that hold the lid hinge, and the 2 top on the back of the fridge. There is no need to remove all the other screws that hold the back cover in place.
AnswerID: 194212
Follow Up By: Member - Stephen M (NSW) - Tuesday, Sep 12, 2006 at 20:54
Hi Stephen, thanks for that much appreciated. Regards Steve M
FollowupID: 452104
Reply By: Member - Pedro the One (QLD) - Wednesday, Sep 13, 2006 at 01:34
Hi, Stephen .................
as the others have said AND you can buy a pack of four LR44's in Woolies for only a few dollars .......... and then you tape a spare or two inside the housing for next time !! You should get a couple of years out of a set , depending on variables ???
Regards ........ Pedro
AnswerID: 194256
Follow Up By: geocacher (djcache) - Wednesday, Sep 13, 2006 at 01:57
They'd keep much better in the fridge....
FollowupID: 452146
Follow Up By: Member - Stephen M (NSW) - Wednesday, Sep 13, 2006 at 12:55
Thanks Pedro, ggod thinking amd would work out cheaper and as you said spares for next time . Thankyou Regards Steve M
FollowupID: 452232
