DIY Storage Systems-Drawer Bearings
Submitted: Saturday, Sep 16, 2006 at 21:28
ThreadID: 37766 Views:8394 Replies:5 FollowUps:12
Good evening all,
I am currently in the process of constructing a storage system for the back of my Hilux. All is going well and I just thought that I'd share a budget tip with you all.
I have decided to go with a "Bearing Style" drawer system, using bearings of the following measurments:- 8mm shaft , 22mm outer, 7mm width. After being told by the local bearing mob that I was looking at $7.70 / bearing, I jumped on E-bay.au and found that a set of skateboard bearings (which were identical) were just $10.99 for a set of eight. Instead of having to outlay a possible $246.40 it cost me only $56.60 including postage, which is still a damn sight cheaper than any slide system available. All in all I reckon that the whole system will come in well under $500, better than around the $2k that some retailers are asking.
Heefers
Reply By: Steve - Saturday, Sep 16, 2006 at 21:35
I am selling a new set of drawers all steel , out of the box for $500. but got no replies .... reckon I am too dear !!...reckon this site is full of ....skates /n w..kers ??
AnswerID: 194866
Follow Up By: awill4x4 - Saturday, Sep 16, 2006 at 21:38
Yep, and posts like this are a great way to get people to buy your stuff. NOT!
Regards Andrew.
FollowupID: 452887
Follow Up By: Heefers - Saturday, Sep 16, 2006 at 21:50
God bless steel Steve, Shame it's nearly three times the weight of aluminium!
FollowupID: 452891
Follow Up By: RosscoH - Sunday, Sep 17, 2006 at 06:55
Steve,
What are your draws to suit, and where are they in the trader section, I haven't seen them, also where are you in this fine country.
Cheers RosscoH
FollowupID: 452913
Reply By: Member - Jeff H (QLD) - Saturday, Sep 16, 2006 at 21:36
Thanks Heefers,
. The more of this info brought to light, the further the $s will stretch.
Don't need bearings today, but who knows?
AnswerID: 194867
Reply By: Heefers - Saturday, Sep 16, 2006 at 21:54
P.S. If there are a few of you guys out there constructing, E-bay global has lots of 100 for around $35 US + P&H. (No affiliation, yarda, yarda, etc, etc)
AnswerID: 194873
Reply By: Ianw - Saturday, Sep 16, 2006 at 21:58
I was planning to use the whole skateboard wheels. Drawers are then rubber mounted and no rattles. Get the cheap boards with small wheels, each wheel is fitted with 2 bearings. Boards can be purchased very cheaply at the cheap shops. Any thoughts?
AnswerID: 194874
Follow Up By: Heefers - Saturday, Sep 16, 2006 at 22:12
G'day Ianw, My plan was to "Sandwich" a runner between a series of bearings therefore eliminating the possibility of the drawer jumping up and down. This will save on space as my system is only wheel arch high.
Heefers
FollowupID: 452894
Follow Up By: Ianw - Saturday, Sep 16, 2006 at 22:39
Steel runner? steel bearings. I reckon it will develop a rattle. Same system with wheels slightly more bulky but definately no rattles
FollowupID: 452900
Follow Up By: Heefers - Saturday, Sep 16, 2006 at 22:50
Not steel Ian, 20x20 aluminium square tube with a 1.5mm thick strip of rubber along the runner surfaces, same effect as the solid plastic skateboard wheels, less size.
FollowupID: 452901
Reply By: geocacher (djcache) - Saturday, Sep 16, 2006 at 22:45
22mm dia bearings are too small.
The smaller you go the smaller the surface area of the sphere that is carrying the weight.
Also the smaller you go the higher the cost.
I can't remember if mine are 30mm or 35mm dia, they are on a 10mm bolt. They were about $1.67 each from the local bearing shop.
The plans are on my website. They have the details on the bearings.
Also on the second set I built the top bearing at the back of the drawer was replaced with a soft nylon wheel cut from cutting board. This became the anti rattle stop.
AnswerID: 194884
Follow Up By: Heefers - Saturday, Sep 16, 2006 at 23:04
G'day Geocacher, These bearings are made to take the weight of a human whilst carrying out acts of, what seems to the normal person, stupidity. I'm pretty sure that they can take the weight of whatever I can fit in my drawer. On the subject of price, perhaps my local bearing shop was just prepping me for a fisting.
Heefers
FollowupID: 452904
Follow Up By: geocacher (djcache) - Saturday, Sep 16, 2006 at 23:57
Actually you are wrong.
There are 8 bearings to each left and right boot in a set of rollerblades.
Those bearings are made to take the weight of the average person divided by 16
Assume 80kg / 16 equals 5kg.
That's without allowing for the several g in forces you can exert off road with corrugations, potholes, erosion crossovers etc.
You can use them if you want to hammer flats on the surfaces and have notchy feeling bearing runners. I really don't care.
You might be pretty sure they can take the weight of what ever you can fit in your drawers, but I'm pretty sure you're wrong.
I'd hate to see you disappointed. It's a lot of work to reengineer it later to take bigger bearings.
Surface area is everything when it comes to load carrying ability for bearings. That's why roller bearings are used for really heavy stuff.
FollowupID: 452908
Follow Up By: Member - Mal B - Sunday, Sep 17, 2006 at 21:26
made timber frame and draws about 280 mm high and they go in as far as the rear seats for my 80 series about 5 years ago no rollers just slides on a laminex strip, both boxes are full and slide ok , just got back from cape york no problums .[no rollers to break] safe driveing mal b
FollowupID: 453057
Follow Up By: Member - Norm C (QLD) - Sunday, Sep 17, 2006 at 22:00
Depends what you are after I guess. I built a set of drawers based on Dave's (Geocacher's) plans. I got serious roller bearings from a bearing specialist. Like Dave sais, they use a 10mm bolt, through 3mm steel supports. Used either 20 or 24 roller bearings @ a touch over $2 each.
The advantage is the drawers roll beautifully. They are 1500mm long and roll all the way out. Only about 150mm stays in the drawer unit when fully extended and they stay rock solid and self supporting, despite the big weight I put in them.
There are cheaper ways of doing it, but I am delighted with the strength of mine.
FollowupID: 453065
Follow Up By: Heefers - Monday, Sep 18, 2006 at 09:13
G'day Goecacher,
Many thanks for your concern, but I don't think that there will be a problem. Yes the weight of a person is distributed by eight bearings in a skate which is why I will be utilising eight bearing each side of each drawer. As for your G force argument about corrugations, skaters don't exactly treat their skates with care and they don't seem to have any problems.
I'll post a note to let you know how I go when all is done and tested.
Heffers
FollowupID: 453104
Follow Up By: geocacher (djcache) - Monday, Sep 18, 2006 at 09:18
Hi Heffers,
No problem. Good luck.
Just a couple of points for consideration before you embark.
If your jig setup for drilling bearing mounts is not perfectly setup you'll end up running on less than the 8 a side. Be very carefull about this. You could end up running on 3 a side quite easily.
There will also be a very good reason why no commercial manufacturer uses the 22mm O/D bearings for load bearing rollers on any of their drawers. They use them for side guides only.
Your call. Be interested to hear how they are going after 50000km.
FollowupID: 453106
