SOS - ROAST IN THE CAMP OVEN - ODAY
Submitted: Sunday, Sep 17, 2006 at 08:31
TheBestHalf
Hi all,
I have the
camp oven and I have a nice rolled roast. I even have a trivet. I also have an oven or stove top.
All I need are some directions for putting it all together for a roast lunch today.
Can anyone help?
Bron
Reply By: sammo - Sunday, Sep 17, 2006 at 09:01
Campfire with lots of hot ashes is the way to go - second best is the oven, mod heat, put trivet into
camp oven, salt and herbs on the roast, veges in if u want, lid on, and enjoy it about 1 1/2 or 2 hours later depending on size of the roast. Wouldn't advise the stove top tho.
194899
Follow Up By: Member - Robyn J (QLD) - Sunday, Sep 17, 2006 at 09:10
Agree with your information. Can use heat beads if you cant have a timber fire. Have used ours on the gas stove top when
camping in a non powered caravan site where you cant have a fire or burn heat beads and is ok for roasts but not good for cakes as you cant get enought heat on the lid to brown the cake. Cake cooks ok though.
Have a good lunch.
452925
Reply By: Mike Harding - Sunday, Sep 17, 2006 at 09:12
http://www.google.com.au/search?q=dutch+oven+cooking&start=0&ie=utf-8&oe=utf-8&client=firefox-a&rls=org.mozilla:en-US:official
Will give you more information than you can poke a stick at :)
194900
Follow Up By: Mike Harding - Sunday, Sep 17, 2006 at 09:14
If you have problems with that link just type:
dutch oven cooking
into Google
452926
Follow Up By: fisho64 - Sunday, Sep 17, 2006 at 14:56
Ha, I thought you were taking the p.ss til I typed it in! I thought a dutch oven was what you did lying in bed on sunday mornings, while pulling the covers over the misses or kids!
452975
Reply By: Member - Ric K (WA) - Sunday, Sep 17, 2006 at 09:25
Hi Bron,
Using a
camp oven you need hot coals, sit roast in
camp oven on a spacer (to keep meat off bottom) with a small amount of
water or wine in bottom of
camp oven. Flatten coals out so temp is not too hot and also put some on lid of
camp oven, if
camp oven on edge of coals, rotate
camp oven 180 deg so both sides get done, time taken depends on size of roast, approx 2 kilos takes around 3 hours depending on temp, meat could possibly be blacker in colour than normally done in oven but tastes yummy, ps dont forget the veges. we have done this several times. Best time was at Home Valley station on
Gibb River Rd, where we met some lovely people and invited them to a roast, they provided tablecloth serviettes and silver service, and being from the SW of WA we also provided the wine. Good Luck and have a go.
194902
Reply By: Member - Robyn J (QLD) - Sunday, Sep 17, 2006 at 09:28
Just another thought - have you used the
camp oven before or is it its first use. If it is its first use you must season it correctly or the roast wont taste very nice.
If you havent seasoned it you may have a fair bit of work to do before you put your roast in to
cook.
194903
Follow Up By: TheBestHalf - Sunday, Sep 17, 2006 at 10:19
Hi Robyn, yes the oven has already been seasoned and we have had a couple of really nice dampers and a beef and red wine casserole out of it.
Well, am off to season up the meat and whack it in the oven.
Wish me luck!!
Bron
452941
Follow Up By: Member - Robyn J (QLD) - Sunday, Sep 17, 2006 at 10:40
Another good trick is preheat the
camp oven to get it really hot and then sear the meat against the sides and base of the
camp oven then put the meat on the trivett for cooking. This seals the meat and keeps all the juices in.
452951
Reply By: Member - AVA 191 (QLD) - Sunday, Sep 17, 2006 at 18:55
We stuck to the advice given in here some time ago, and we had excellent results cooking in the open fire place:
cook for 1 hour per kilo
throw veges in 1/2 hour b4 time
no coals under the
camp oven (to stop bottom burning)
spade full of coals on top
rest packed all round the outside surface.
194950
Follow Up By: Member - Peter R (WA) - Sunday, Sep 17, 2006 at 22:36
Perfect roasted chicken and veg.
Aluminium trays;
Put chicken, garlic, olive oil and onion in a large tray covered with several layers of alfoil and place it on cool ground and cover with hot coals.
Another tray with veg and covered, after chicken has been cooking for one hour place veg tray on cool ground and once again cover with hot coals, half an hour later both chicken and veg are ready.
***Hint*** Brush off most of the coals with green brushwood and then use a length of 8mm pvc hose, blowing through the hose will remove most of the ash so not to contaminate meal with ash when removing covering of alfoil.
Few red wines, the stars are out what could anyone ask for anything better?
Who knows what may be for dessert. wooooohooo
Nightjar
453073
Reply By: Member - Peter R (WA) - Sunday, Sep 17, 2006 at 23:47
Hello viewers,
Following up from my post below, if you wish to use your
camp oven for the roast, place the chicken in the
camp oven and shovel "cool" ash up around sides to lid level then shovel glowing coals on the lid only covering it completely. Of course some are going to spill over the sides but the cool ash insulation will keep them away form the sides of the
camp oven.
*** Remember place the
camp oven/ Aluminium tray on cool ground or your roast will burn, definitely no coals underneath.**
Nightjar
194989
Reply By: Member - Duncs - Monday, Sep 18, 2006 at 17:34
I'd go along with wverything that has been said above.
However, I was born far too close to the scottish border to be wasting money on fancy "do-dahs" like a trivet. I use a sacrificial vegie. Carrots are good cut into big chunks and scattered about the bottom of the oven. Roast on top and then add theotehr vegies later as others have suggested.
Oh and I like to add whole onions fairly early in the piece 'cause I like how they flavour the roast.
Duncs
195112
Reply By: nissnut - Tuesday, Sep 19, 2006 at 17:52
KFC....cant beat it
195367
