2003 T/D Hilux LSD Too slippery
Submitted: Sunday, Sep 17, 2006 at 09:26
TJC
Has Any one had problems with their Hilux factory LSD being too slippery? The vehicle has 26,800 klm. I have just got it back from toyota (under warranty), who had it for a week, to replace the clutch plates and springs and re-tension the diff. It performs no different. When one rear wheel lifts off the ground, it spins and looses all forward propulsion (just like a normal diff.). I have not been able to go back to them yet(will be back on monday). Also when I jack one wheel off the ground and spin the lifted wheel, there is minimal resistance.
Has any body had similar problems? If so did you fix it? I have spoken to a local Diff place who said they can tension the Diff to my specs (for a price of course).
Appreciate any useful feedback.
Cheers.
Reply By: Member - Blue (VIC) - Sunday, Sep 17, 2006 at 10:52
If history serves as a good indicator, that's toyota lsd's for ya...
194916
Follow Up By: awill4x4 - Sunday, Sep 17, 2006 at 11:14
Unfortunately, Blue is correct. The Toyota LSD's don't have a very good reputation in the length of time they operate correctly and it appears 30K-40K is the norm. Rather than spend (waste) money on the LSD you would be better served in putting in some kind of cross axle locking diff like ARB airlocker or an auto mechanical locker. I have an ARB air locker in my Patrol and it's great.
When I converted my GQ years ago to a rear locker I should have actually put in a front locker instead and used the Nissan rear LSD the Nissan LSD is the only one that actually keeps working and I know of late 80's early 90's GQ's with LSD's still working fine.
Regards Andrew.
452953
Follow Up By: bigcol - Monday, Sep 18, 2006 at 10:05
Toyota LSD by name only.
You don't actually want a Toyota LSD to work do you.
My 75 series blew the rear. I had it fixed and it lasted about 3 days before it was performing like an open centre diff.
My 2004 STR Navara is approaching 100 000klm and the LSD works as good as it did when it left the factory.
453113
Reply By: Member - 'Lucy' - Sunday, Sep 17, 2006 at 11:42
Listen hear TJC.
Tell the truth - its a Navara and your just too embarrassed to own up to it.
And for the rest of the Nissan peantut gallery - No! he has got a JEEP either.
Ok! Ok! I'll be serious (maybe)
Talking to a gentleman last night who has got a JEEP. For some reason unknown even to himself he decided that he would stop the wear in his diffs by changing the oil to something called MBL (or similar) .
Apparently is full of lead and copper and can be used anywhere in the engine or drive train, where it coats all moving parts etc in this filthy chit.
Guess what - no more LSD. Diff works perfectly otherwise but no limited slip and the only was to fix it is piff the diff centre, flush it as best you can and then hope that the muck has been dispersed sufficiently not to interfere with the replacement.
Is it possible your diff in the Hilux may have had some 'additive' added or a different oil used on a service. I would imagine it would have been changed at least once since purchase.
194921
Reply By: Exploder - Sunday, Sep 17, 2006 at 12:38
Welcome to the world of Toyota LSD’s LOL
When Toyota repacks there LSD it will be to factory Specification so it will be useless off road, as it’s not done tight enough to be effective. This can be because of the way Toyota pack in their friction disks or because they don’t use many friction disks in there LSD’s.
The average Clutch type LSD will be toast by around 100,000k for off-road work anyway.
My Ford 8.8 Trac Loc LSD has 150,000 on it, and on road it still works but off road you get some articulation happening and it will cut in and out or just slip.
If you want a LSD that works take it to a Diff place and tell em to pack it up tight.
Or fit a Detroit True track LSD that will never wear out, the other option would be a auto mechanical locker.
Cheers.
194925
Reply By: Old4runner - Sunday, Sep 17, 2006 at 21:41
Toyota LSD are infamous for their lousy LSD`s. My V6 4Runner had one after about 30,000 Km it was virtually useless. As soon as one rear wheel got the slightest amount of shifted to the opposite side rear, the wheel with the least resistance would spin
In the end I opted for Detroit lockers fron and rear and thats been the case since I bought ths last of the V6 4Runners. Now I am able to go through
places where standard 4x4 with LSD`s cant make it. As they become cross axled the vehcile just stops, and many time its been a case of out with the snatch strap and a gentle tug gets them going.
Never felt that LSD`s were worth very much - some work better than others, but there comes a time when they all begin to fail. Am not a great lover of ARB air lockers for various reasons, but have found the Detroits to be simply great in all types of off road surfaces and the new models are even better then the ones I fitted back in 1996 . So think its time for an upgrade to the latest Detroits. The 4Runner has been a great medium sized 4x4 for only the two of us. Dont need anything bigger.
194977
Follow Up By: Plantman - Sunday, Sep 17, 2006 at 22:04
Just wondering roughly what kind of money do detroit lockers set you back on your Toyota.
Plantman
453067
Reply By: Old4runner - Monday, Sep 18, 2006 at 01:53
Hi Plantman.
The qoute I received for the latest Detroits, which are a vast improvment on the models that I had fitted in `96 are now +/- $1200 fitted. I`m planning on having the new lockers fitted to the front first - as that is the axle with the least amount of articulation, see how that goes then later towards the end of the year fit the latest Detroit to the rear. Hope that helps answer your question
194997
Reply By: Member - Jeff M (WA) - Monday, Sep 18, 2006 at 14:54
Yeah it's a sad story I'm affraid.
Mine's done about 140k and is still 'average'. I had an LSD in my Rocky and in my Frontera and they both kicked ass. This one is lathargic at best. It does work (sounds like it works better than yours) but it takes a few seconds for it to kick in and then you can still feel the diff slipping.
I notice it the most when you
park on the side of a sealed road with two
wheels in soft sand and two
wheels on the road. When you drive off it spins and spins for about 2 seconds before you finally get some traction on the road. The frontera used to JOLT you as it locked in and then lurch out of the sand in the same situation.
195093
