Firestone Airbags Query
Submitted: Sunday, Sep 17, 2006 at 16:40
Member - Jack
I will be fitting a set of Firestone airbags (Coil helpers) to my 1991 80 Series Landcruiser this week. Just a cursory look underneath and I can see the bolt that secures the bump stop. Whilst I think the airline will pass through the hole when I take them out, it looks a "bit squeezy", and I am a bit concerned that it may end up pulling the airline out of the airbag.
If anyone has fitted these bags to an 80 series, can you give me an idea if I should drill out the bump stop hole, and if so, what size drill should I use.
Thanks in advance.
Jack
Reply By: Alloy c/t - Sunday, Sep 17, 2006 at 18:11
Jack , the bump stop has to be removed and cut down to 2 indents and then replaced , so the bolt hole is NOT used for the air line as per fitting diagram , if you fit without the cut down bumpstop there is nothing to stop the coil from "falling out " at full extension ,, literally fit the bag upside down so the air tube runs thru the hole at the bottom of the coil "
seat " and run the line along the diff then up to the body and back to where you want ,
194942
Follow Up By: ACDC - Sunday, Sep 17, 2006 at 18:48
I have never fitted firestones but if they are like polyairs you have to remove the bump stop and use a hole saw to open up the bolt hole to 40mm.
The bump stop does'nt stop the coil falling out, if the coil is loose on full travel then the shocker is to long and unroadworthy!
453010
Follow Up By: Member - Jeff M (WA) - Sunday, Sep 17, 2006 at 19:20
No alloy is correct with the Firestones (the surf uses the same springs and setup as the 80). The firestones air line goes through the bottom (I had to drill a hole for
mine).
453018
Follow Up By: Alloy c/t - Sunday, Sep 17, 2006 at 19:24
ACDC , the Firestone "coilrites" are much the same as polyairs ,EXCEPT for they are blue/ not red / wall thickness is thicker / load capacity is higher / and for fittment on an 80 series coil suspended the bumpstops are REMOVED and CUT DOWN to 2 spaces/rings ,, then REFITTED ,, the hole for the airline therefore does NOT exist as per the written instructions ,,the hole for the airline is full of bolt holding the bumpstop ,turn the bag upside down = no drilling /no problems ,, and as an aside you can get the Firestone delivered to your door for less than 1/2 the price of polyairs in Aus from Trucksprings in the US of A.
453019
Follow Up By: japmel - Sunday, Sep 17, 2006 at 20:33
My Firestone Airbags were fitted by professional fitters and they took the bumpstops out and drilled a 30mm hole in the top where the bolt was then they put the airline though the top.
japmel
453037
Follow Up By: Member - Jeff M (WA) - Sunday, Sep 17, 2006 at 20:47
japmel, yeah if you've read any of my posts before, you'll probably know that I don't think much of a lot of 'professionals' work. :-)
These were the instructions I received with the bags an followed:
http://members.westnet.com.au/themeads/pictures/host/crin4112[1].pdf
453044
Follow Up By: japmel - Sunday, Sep 17, 2006 at 21:18
Jeff M,
Yes I received the instructions from truckspring as
well. But I wasen't entirely happy about cutting the bumpstops. (just in case I want to remove the airbags in the future) So I went and got them installed by the People that are installing them all the time.
They took one look at the instuctions and threw them away, Saying they where for the Yank cars (that hardly ever get used off the road)
japmel
453051
Follow Up By: Member - Jack - Sunday, Sep 17, 2006 at 21:20
Hi Jeff:
Weird ... Just checked out my fitting instructions and it says through the top. But nowhere does it say anything about drilling out the bolt hole, and I am certain it will be a tight fit.. I think I will just assess it when I pull the car apart and work it out from there...or call Firestone.
Thanks.
Jack
453053
Follow Up By: Member - Jeff M (WA) - Sunday, Sep 17, 2006 at 21:20
hahaha, I love comments like that. Just go have a look at YouTube and tell me the yanks don't go 4wding! :-)
I can't see any reason why the way firestone intended them to be installed should be a problem, hell
mine have been in comming up 2 years and they are good as new. I regualry have them pumped up to 35psi to keep the rig level when we do trips and do some quite sevre offroading with them like that.
453055
Follow Up By: Member - Jeff M (WA) - Sunday, Sep 17, 2006 at 21:22
Ah, it won't matter, do whatever looks best. It's a pretty basic concept. Bag goes in spring, air goes in bag.
I followed my instructions and didn't have a problem, I would assume if you do the same, then you will have no problems either. ;-)
453056
Reply By: Pajeroman - Sunday, Sep 17, 2006 at 18:22
Personally I wouldn't fit airbags to any vehicle going over rough, particularly corrigated roads. Springs are designed to take up the shocks and all air bages do is stop them doing this job and make the tyres work harder.
Go the the Pink Road House at Ood web sit for more info but basically I have seen 4 vehicles all with airbags shred tyres up the Ood Track.
You will do tyres in guaranteed. OK on road but let the air out off road or get in trouble.
194944
Follow Up By: ACDC - Sunday, Sep 17, 2006 at 18:44
Sorry but don't agree !
453009
Follow Up By: Alloy c/t - Sunday, Sep 17, 2006 at 18:51
Dribble , what has an air bag inside a coil spring got to do with "shredding tires " for effs sake , the air bag makes the coil spring no different than replacing the standard coil with a heavier spring rate coil EXCEPT for the fact you can then adjust the air to suit extra load , you shred tires by wrong tire pressure , NOT because of the spring rate.
453012
Follow Up By: Member - John (Vic) - Sunday, Sep 17, 2006 at 18:53
I would be loath to believe anything that you see from the Pink Road House.
In my personal experience its also not the case having had Air Bags for quite some time have found them to be excellent.
And I assure you they have done some pretty corrugated roads in their time with no ill affects.
If your friends did tyres on 4 vehicles then I would suggest that their tyre pressure was to high or the tyre was unsuitable for the conditions.
453014
Follow Up By: Pajeroman - Sunday, Sep 17, 2006 at 18:58
First you need to understand that the people I saw were not my friends just acquantances. All I am saying and I have seen it personally on a number of occasians particularly with heavily laden vehicle, not overloaded.
Think about how th air bags work. Basically they stiffen up the spring restricting the speed and amount they can compress. Hence the tyres have to work harder to do the work of the spring. Yes tyre pressure is definately the most important thing but not the be all and end all.
453015
Follow Up By: Member - Jeff M (WA) - Sunday, Sep 17, 2006 at 19:25
Bah humbug. Air bags do not work my restricting shock absorbtion.
The work by squeasing between the different coils of the spring to 'stiffen' the spring so that it is harder for the spring to compress, it's just like using HD springs instead of normal springs except you can adjust them as you need.
It's a common missconception that air bags work by pushing upwards pressure and using air to do the work of the spring/shocky. It is not the case, if it were the air bags would go POP.
I've been running the firestones on
mine with 2" raised HD king springs for years and never had a problem, even in the harshest terrain. We are on the verge of being overloaded, but correct tyres pressure make almost any journer acceptable.
!MPG:14!
453020
Reply By: 98Jack - Monday, Sep 18, 2006 at 09:47
I've got the Firestones from Truckspring USA fitted to my Jackaroo. (yeah I know, its not an 80!!!) but one thing my mechanic did when installing the airline was to slip a length of brake hose over the airline to prevent it from rubbing on any metal, thus preventing it from cutting the airhose. He placed the brake hose where the airhose runs through the top of the spring housing and the chassis.
It also helps it stop being kinked accidently.
98jack
195030
Follow Up By: Member - Jack - Monday, Sep 18, 2006 at 19:55
That sounds like a good tip. I was a bit concerned about it kinking if I was on some rough stuff. Thanks for that.
Jack
453248
Reply By: Middle Jeff - Monday, Sep 18, 2006 at 13:02
I have them fitted to my 80 which has a 5 inch lift on springs the bump stop comes out put a heavy ruber hose around the air line, I have to have spacers on
mine you should be able to use the standard kit. I have
mine set up so I can adjust from inside the cab with a duel needle gauge and I set them to the conditions so I watch that they never go over 30 psi and the whole thing just works.
I can go extrem one day and go to the cape the next and the CD player never skips a beat.
Have fun
195071
Reply By: TD100 - Monday, Sep 18, 2006 at 18:04
3 weeks ago i fitted coil rites(firestone)bags to my 100 series and instructions said remove bump completely and open top hole anywhere from 12mm to 25mm to give air line clearance and was supplied with sleeving to go over incoming line!cheers Paul
195121
Follow Up By: Member - Jack - Monday, Sep 18, 2006 at 20:00
Yep - the fitting instructions on
mine are to cut the bump stop, but then thread the air line through the bump stop and the hole. My guess is that the air line keeps the bump stop in position. I have a pair of blue spacers with my kit, which I guess go on top of the air bag. Obviously once the airline is through I can't then re-attach the bump stop with the bolt, and given it is not a huge bolt hole, I figured some drilling would be needed.. I think the 25mm would give me enough free space to make it work fine.
Many thanks ... I think you have solved the mystery. The instructions are pretty good, but the little things tney miss out on with
mine are a bit annoying.
Jack
453250
