Heat exchangers
Submitted: Sunday, Sep 17, 2006 at 20:02
drinky
Hi all, this maybe a silly question but can you use
bore water through your heat exchangers.
Reply By: Member - Phil G (SA) - Sunday, Sep 17, 2006 at 20:37
I'd say Yep.
The shower
water goes thru copper tube, which resists corrosion.
194959
Reply By: Nick R - Sunday, Sep 17, 2006 at 21:07
You can, but, the poorer the quality of the
water the shorter the life of the heat exchanger. Corrosion isn't usually the issue, more commonly there will be a buildup of something on the inside of the heat exchanger. that something will depend on what is causing the hardness, usually calcium or iron or something.
the speed by which it will build up will depend on the hardness of the
water.
I have heard of people around Mt Gambier using hard
water in electric hot
water cylinders having to replace elements more often than yearly.
just something to bear in mind
NickR
194966
Follow Up By: Michael ( Moss Vale NSW) - Monday, Sep 18, 2006 at 08:18
YOu can always run a bit of Citric acid though them to get them spotless again, In fact its beneficial to do that to all heat exchanges to ensure the best transfer of heat. Michael
453100
Follow Up By: Member - Roachie (SA) - Monday, Sep 18, 2006 at 10:47
Would the use of citric acid or CLR product, affect the electric pump, do you think? I'm prepared to periodically circulate some of this stuff through my heat exchanger, but do not want to stuff-up the diaphram (or whatever) on the pump either.
Roachie
453125
Follow Up By: Michael ( Moss Vale NSW) - Friday, Sep 22, 2006 at 13:01
Roachie! i wouldnt know for sure about the CLR, that is i think Sulphamic acid, I would think the rubbber diaphrams in the pump should be ok, they would be some kind of synthetic material but the citric would be my choice and i would think that it would be ok in the pump. It is a weak solution you are using It goes into foods etc.. Michael
454092
Reply By: Snowy 3.0iTD - Sunday, Sep 17, 2006 at 21:22
You can if you want to severly reduce their life, personally I wouldn't, why do you think in the days of steam that at all the watering stops along the old ghan line they had big
water softeners. When I was living in the
Pilbara where the town was on
bore water the life expectancy of a hot
water service was around 12 months. Calcium and other minerals will be deposited on the inside of the pipes until they are eventually totally blocked. If you have to, as long as you can afford to treat the heat-exchanger as a disposable component then you could.
Snowy
194971
Reply By: Grungle - Monday, Sep 18, 2006 at 07:36
I have had a Glind system for 6 years now that has seen 2 vehicles. I have also used it with
bore water and periodically clean it once every 1-2 years. I use a method told to me by someone that is quite effective (on my website as
well).
Michael's Shower Tip.
Over time, the copper in the heat Exchange will tarnish and become covered in a layer of deposits. For the best heat transfer, the copper tubing needs to be as clean as possible. The
water in the fresh
water side is evaporated out from near boiling
water from the engines cooling system passing through the heat exchanger, leaving the inside of the tube exposed to the atmosphere for the 99% of time when it is not in use. If you have your heat exchanger removed for any reason, you can circulate Citric Acid through the engine side as
well as the freshwater side to remove any build up (it is important to have both sides clean). A solution of 100 grams of Citric Acid per litre of warm
water circulated for an hour or two will remove any build-up and leave
bright copper for maximum thermal absorption. Citric acid is very passive and will not attack copper, soft solder or silver solder and in the case of Glind and Piranha, will not attack the Glassfilled Nylon 66. There are many other acids that will clean at a much quicker rate but most are aggressive and not recommended. Citric Acid is a natural, mild acid obtained from citrus fruits and is used in many foods and drinks and can be purchased from Supermarkets in 75 gram containers for around $1.60 each.
David
195007
Follow Up By: Member - Roachie (SA) - Monday, Sep 18, 2006 at 10:43
I wonder whether that product called "CLR" would be okay to run through the clear
water side as
well on a periodic basis; especially if you've had to use
bore water for any reason?
453122
Follow Up By: Member - andrew B (Kununurra) - Monday, Sep 18, 2006 at 14:27
Gday Roachie,
I don't know of anyone who has had any success with that CLR.......stuf. We have a lot of calcium in our
water, and it is hard to get off glass if left for any period of time. CLR doesn't touch it, razorblades/scrapers have trouble, had to resort to cut and polish on a mate's windows that get overspray from retic. From our experiences, we would call it LR, as it didn't touch our calcium. It may be ok on the other 2 though......
Cheers Andrew
453167
Reply By: Member - andrew B (Kununurra) - Monday, Sep 18, 2006 at 07:43
As all have said above, It will reduce the life of the unit with buildup of deposits. From what a graduate metalurgist was telling me the other day, calcium is a shocker, something about it has a lot of +ve ions in it (??, I didn't do chem), so it adheres to thi inside of pipes etc very
well, helping iron etc do the same.
Our solar HWS got blocked a while back. It is the type that the
water is in the actual panels. aparently the type that has coolant in the panels and a heat exchanger in the storage
tank are better in hard
water area's, but then, aparently, you are mooving the problem into the
tank around the heat exchanger. The deposits (in my area) are very hard to remove. Where the hot
water comes from the panel to the storage
tank in my case there is about a 20+mm opening, which was reduced to about 5mm. A hammer and screwdriver was required to enlarge the hole.
IMO, periodical use of hard
water would be OK. Any chemistry experts out there may be of help here.......If hard
water lays the deposits with dissolved minerals, a period of pure soft
water would possibly dissolve the deposits????
Sorry, more questions than answers here!
Cheers Andrew
195008
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Monday, Sep 18, 2006 at 10:30
Unfortunately soft
water won't undo what hard
water did, but the cleaning advice above is good advice. Like all these things it all depends how hard, how long and how much heat. I wouln't worry too much if it is occassional usage,. If the performance degrades, or every year or so, give it a clean as above.
Dave O
453115
Reply By: geocacher (djcache) - Monday, Sep 18, 2006 at 22:44
Now that Piranha have bought McPauls (I'm pretty sure that's the arrangement) and are offering a "lifetime warranty" on the heat exchanger in the Power Shower, does anyone know if it's conditional on
water type or anything else?
195200
