LDS OIL 140
Submitted: Monday, Sep 18, 2006 at 19:51
ThreadID: 37818 Views:6282 Replies:9 FollowUps:4
Anyone, can you help with my Limited Slip Diff Oil in Patrol 99 TD4.2T my manual tells me that the oil is 140 grade but I cant find it anywhere its not 85-140 it says 140.So what is everyone using.
djpatrol
Reply By: Member - Ed. C. (QLD) - Monday, Sep 18, 2006 at 20:17
If the book says 140, then 85w-140 will do nicely,IMO...
I'm using Castrol LSX 85w-140 in mine (same model as yours), and have done since I purchased the vehicle new... No problems to report...
Confucius say.....
AnswerID: 195157
Reply By: 120scruiser (NSW) - Monday, Sep 18, 2006 at 20:50
Hi dj
I have been using LS85/140 from here www.gulfwestern.com.au/
Have been for years and no dramas.
I service their own vehicles and they put their own oil in them so must be alright.
The only thing is the web site states it is only available in 205 and 20 litre drums but I buy it in 1 litre packs as well.
Hope this helps
120scruiser
AnswerID: 195165
Reply By: Member - Doug T (W.A) - Monday, Sep 18, 2006 at 21:23
Crankcase
TITAN ULTRALUBE 1540 or TITAN UNIVERSAL HD 15W40
Service Refill Capacity: 10.5* Litres (See Note 348)
Manual Transmission
TITAN GEAR 75W90
Service Refill Capacity: 3.8 Litres
Differential
TITAN GEAR LS 140
Service Refill Capacity: 2.1 Litres
Power Steering
TITAN ATF 4000
4WD Transfer
TITAN ATF 4000
Service Refill Capacity: 1.9 Litres (See Note 152)
4WD Differential
TITAN GEAR HYP 8090
Service Refill Capacity: 5.4 Litres
AnswerID: 195173
Follow Up By: Member - Phil G (SA) - Tuesday, Sep 19, 2006 at 20:45
What brand is that Doug :-))))))))))))
FollowupID: 453462
Reply By: Member - Doug T (W.A) - Monday, Sep 18, 2006 at 21:28
Here check this one out ,,,Oils aint Oils ya know
Site Link
Doug
AnswerID: 195175
Reply By: joc45 - Monday, Sep 18, 2006 at 22:50
I used to use a BP LS140, but no longer available in the quantities I required (a 200 litre drum was a bit much for my needs).
I rang Nissan in Melb, and they assured me that Castrol LSX 85W/140 or equiv was fine for the rear diff.
Gerry
AnswerID: 195203
Reply By: Robin - Tuesday, Sep 19, 2006 at 08:27
Prefer Sythetic Oils here djpatrol, always after the extra horsy.
Used to use Mobil 1 SHC 80w-140ID , this has been known
to improve operation and smoothness of diff / LSD combination.
After fitting rear locker I can now use one common oil
in transfer, gearbox and both diffs Mobil 1 SHC 75w-90
Robin Miller
AnswerID: 195237
Reply By: PhilZD30Patrol - Tuesday, Sep 19, 2006 at 08:48
Hi djpatrol
The Nissan LSD oil specification is SAE 140 oil PLUS their LSD additive for a very good reason, i.e. nothing else will do.
I have used a multi grade LSD gear oil in my GU Patrol with bad results. I started to get what seemed like a very minor clutch shudder (in an automatic?) when starting slowly from a standstill and turning on full lock.
Asked around at my local 4wd club and was told very clearly to use 140 LSD oil only, as specified by Nissan.
The Nissan oil and additive is available from your dealer.
The major oil companies also supply a huge range of oils, check out their web sites on Google for 140 LSD gear oil.
I replaced my LSD oil with Penrite Limslip Gear Oil SAE 140 API GL5/6 Heavy Duty plus the Penrite LSD additive. The "clutch" shudder disappeared immediately. I emailed Penrite at penrite@penrite.com.au to find my local agent.
Hope this helps
regards
phil
AnswerID: 195240
Follow Up By: dj Patrol - Tuesday, Sep 19, 2006 at 10:42
Hi Phil,
You are spot on the money as I have excess shudder from the rear LSD as someone has probelly put the wrong oil in ONLY DONE BY NISSAN THOUGH mabey at Service when under Warranty,As I travelled a lot when new mabey done at some Remote Town.Will shop around for the 140 +
many thanks for supporting my theory,
dj patrol
FollowupID: 453352
Follow Up By: Member - Roachie (SA) - Tuesday, Sep 19, 2006 at 12:15
Strewth,
This could be what my shudder is too....thanks blokes!!!!!! Looks like a couple minutes will be needed under the trol this weekend.
Roachie
FollowupID: 453367
Follow Up By: Member - Phil G (SA) - Tuesday, Sep 19, 2006 at 20:52
Nissan prices are good for their oils/coolants etc
We own 5 Nissan vehicles - their 7.5W30 Engine Oil cost me $25 for 5 litres last week, and the Coolant was $43 for 5litres, but they take pity on me and only charge me trade.
FollowupID: 453464
Reply By: PhilZD30Patrol - Tuesday, Sep 19, 2006 at 09:53
Hi djpatrol
My 2nd response after searching the ExploreOz archives.
See Post ID 9625 January 09 2004 from Jimmy and the replies and follow ups which confirm my experience with the "clutch?" type shudder because of the incorrect grade or contaminated LSD oil.
regards
AnswerID: 195258
Reply By: desray - Thursday, Sep 21, 2006 at 04:55
I have also used the Penrite oil in my Patrol ,http://www.penrite.com.au/files/NFTWH519LK/COMPETITION%20DIFF%20OIL.pdf Penrite also do a new SIN 140 . The competition oil has the lsd addative in it and the diff works real good, like a locker but no judder.
AnswerID: 195622
