Ct towed by Hilux to Cape.
Submitted: Monday, Sep 18, 2006 at 20:11
ThreadID: 37819 Views:2428 Replies:6 FollowUps:1
Will my 3lt.diesel 01 Hilux tow a Ranger xct camp/o/ matic with tinnie on top to the cape and back without a turbo? If not, which turbo would help? My hair is starting to go gray so it doesn't have to be too fast.
Reply By: George - Monday, Sep 18, 2006 at 20:41
I would suggest investing in a quality difflock (if you haven’t got one already installed) instead. Given the age of the vehicle there is a good chance that your LSD is stuffed. As to the original question, I know of several less able rigs successfully making similar trip.
AnswerID: 195159
Reply By: geocacher (djcache) - Monday, Sep 18, 2006 at 22:26
Holden did the Cape with a couple of Adventra's - which means you can get there with a commodore.... if that makes you feel any better.
(Tongue in cheek but they did it.)
AnswerID: 195196
Reply By: Member - Stephen M (NSW) - Tuesday, Sep 19, 2006 at 09:14
If my old 2.8D can make it non turbo, you'l be fine, my mate did it in his old 2.7D navara only problem was his bull bar spit due to the corrugations but good old farmer joe welded her back up again and still ok. As long as its well serviced, and I would bleep off the toyota shockies for some good after market ones for the corrugations you'l have a great trip who's in a hurry anyway. Take care have fun and that hair dye will fix your graying problem lol. Regards Steve M
AnswerID: 195252
Reply By: TerraFirma - Tuesday, Sep 19, 2006 at 13:44
Off course it will..! Towing is not about speed and you wont need to worry about too much traffic when your cruising along.
AnswerID: 195306
Reply By: Batboy - Tuesday, Sep 19, 2006 at 18:39
Can't see you having any problems due to lack of speed, and power will only be an issue in sand and steep hills. Not much sand at the cape and what there is, is avoidable if you must. Only really steep section we came across is on the Bloomfield track through to Cooktown which saw our non turbo 4.2 Diesel Patrol in to low range. Our trailer is around 750kg mark
Have fun
Jim
AnswerID: 195374
Follow Up By: Gerhardp1 - Tuesday, Sep 19, 2006 at 21:38
There are sections of sand on the old telegraph track which are not avoidable (unless you avoid the old telegraph track), and we experienced a long section of 40ks coming into Musgrave from Lakefield where the dozer had made a sandpit. This was a slog in the Jackaroo with Campomatic behind and would be a real pain in a diesel.
The Jackaroo (auto) went up the hill on the Bloomfield track in high range with the 850kg trailer on - so much for the legendary torque of a diesel :)
There is no other steep stuff that we saw on the rest of our Cape trip.
FollowupID: 453480
Reply By: crocket - Tuesday, Sep 19, 2006 at 19:19
GEORGE ,STEVE and others. Thanks for that positive info,I will go the new shocks but not the commodore.May look into the price diff locks, but my GPS is a great pusher, I will send her to gym a couple of monthes before the trip.About the hair dye, I will only get it if I start thinking about CARAVANS. CHEERS CROCKET.
AnswerID: 195381
