Redarc
Submitted: Monday, Sep 18, 2006 at 22:45
ThreadID: 37827 Views:2819 Replies:9 FollowUps:6
I picked up a Redarc today and reading the instructions it says it "should' be mounted on a horizontal surface. It'd be easier for me to mount it on a vertical surface. Does anyone have theirs like this?
Also, how hot do they get?
Reply By: mike w (WA) - Monday, Sep 18, 2006 at 23:15
mines mounted horizontal, easier as that is where the bolt holes are and it stands vertical as it came in the box. I can only speculate as to why it states that it must be mounted on a horizontal plane, maybe something to do with the circuitry or internals?? Dunno. Perhaps you could make a bracket, L shaped that bolts onto your vertical plane, but allows the redarc to be mounted on a horizontal plane? Just a thought.
As for how hot, mine gets warm, and rightly so with all that currenty stuff that flows through it. They dont get "argh I cant feel my fingers" hot, but mine gets "hmmmm, that is warm and should let go now" hot.
I have had no problems at all with mine, Its great, easy to fit and wire, and then forget about it.
Mike
AnswerID: 195213
Reply By: Muzzgit - Monday, Sep 18, 2006 at 23:39
Try redarc themselves. They are well known for good after sales sevice.
AnswerID: 195218
Reply By: Member - uncle - Tuesday, Sep 19, 2006 at 06:23
Ours has always been mounted on a vertical surface in the Pajero and never had a problem, so far. It's been like that for 2 years now hope this helps.
AnswerID: 195227
Follow Up By: Squizzy - Tuesday, Sep 19, 2006 at 07:19
Ditto uncle, mine is vertical in the Patrol and has been since March last year without any problems.
Geoff.
FollowupID: 453327
Reply By: Member - MrBitchi (QLD) - Tuesday, Sep 19, 2006 at 08:00
Mines vertical too.
Hot? &*%#%$ I shouldn't have grabbed that %#$@%$#@$!!!!
AnswerID: 195234
Reply By: Time - Tuesday, Sep 19, 2006 at 08:43
This is how mine is mounted, made a bracket out of scrap beaten into shape and rivetted to the inner guard. It has been there two years and no problems so far. As for heat Redarc say
"QUESTION: My smart start gets very hot when operating. Is this normal?
ANSWER: Yes, it is normal for these products to run hot. A high current solenoid requires high power on the coil to ensure a good contact. This
results in heat dissipated in the coil body."
AnswerID: 195239
Follow Up By: Mainey (WA) - Thursday, Sep 28, 2006 at 22:24
When cables heat up, they are said to be too thin/small and cause loss of power??
FollowupID: 455496
Reply By: Member - Phil G (SA) - Tuesday, Sep 19, 2006 at 20:17
I prefer circuit boards to be horizontal. I have a theory (anecdotal) that components vibrate more if the board is vertical. I can only back it up with a couple of odd experiences where stuff failed when mounted vertical.
AnswerID: 195397
Follow Up By: Member - MrBitchi (QLD) - Friday, Sep 29, 2006 at 08:05
The circuit board is potted so makes no difference.
FollowupID: 455548
Reply By: Gerhardp1 - Tuesday, Sep 19, 2006 at 21:13
I fitted mine myself but didn't read the bit about horizontal, so mine is vertical.
Has done 10,000k with the trailer on and the trailer battery connected via Anderson plugs, and no problems. The 10,000 was to Cape York and back, so there was plenty of vibration for the Redarc to cope with!
Mental note - make an angle bracket and re-position it to vertical one rainy day....
AnswerID: 195412
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Sep 19, 2006 at 21:38
The Redarc is a solenoid and has a moving plunger. Friction and gravity will case wear in a vertical mount position. The resulting filings and rough edges can cause the Redarc to bind or not operate freely.
Regards Derek.
AnswerID: 195420
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Sep 19, 2006 at 21:39
Spelling. 'Cause' - Sorry
FollowupID: 453481
Follow Up By: Mainey (WA) - Thursday, Sep 28, 2006 at 22:19
Because it's a basic solenoid in operation, with a fancy name of course. The manufacturer (Redarc) tells you to install the product that way for the reasons Derek has stated, :-(
An electronic isolator they can be mounted anywhere, as they don't have the heavy solenoid moving inside them using their own battery power just to remain open...
FollowupID: 455495
Reply By: Upstart - Tuesday, Sep 19, 2006 at 23:37
Thanks for all the replies fellas. I installed it this arvy on a vertical surface in the engine bay close to the battery. It seems to be operating well so far. When I get some more time I will probably work out a bracket to mount it on a horizontal surface.
AnswerID: 195444
Follow Up By: Bonz (Vic) - Thursday, Sep 21, 2006 at 21:00
had mine vertical baside the battery for 5 years not a zot of trouble. Good bit of kit
FollowupID: 453954
