Another back burn out of control
Submitted: Tuesday, Sep 19, 2006 at 08:54
ThreadID: 37834 Views:2118 Replies:5 FollowUps:5
This work of course needs to be done but does anyone check the weather reports before they start these back burning areas. With all the technology behind them the DSE needs to become more professional. Hope they get it out soon but don't like they chances with these strong winds and more winds forecast.
Reply By: Member - DOZER- Tuesday, Sep 19, 2006 at 08:58
Where abouts???
AnswerID: 195246
Follow Up By: Member - Rotord - Tuesday, Sep 19, 2006 at 09:42
Was it a back burn or a fuel reduction burn ?
FollowupID: 453340
Follow Up By: Truckster (Vic) - Tuesday, Sep 19, 2006 at 09:56
Vic firefighters battle Mallee blaze
Firefighters backed by water bombing aircraft are battling to contain a blaze which is likely to threaten farms in Victoria's remote Mallee country late today.
The fire, which began as a fuel reduction burn, has ripped through about 3,000 hectares of Mallee scrub in the Murray-Sunset National Park at Berrook East, north of Murrayville, 510km north-west of Melbourne.
Department of Sustainability and Environment (DSE) state duty officer Graeme Davis said today the blaze was likely to affect privately-owned wheat farms later today.
"The fire is likely to spread because we are expecting extreme fire weather before a change later today," Mr Davis told AAP.
"We'll have a very strong northerly wind and relatively low humidity, certainly for this time of year.
"The westerly change will be blustery. We've had some fuel reduction burns in the area so we are trying to manage the fire into those areas."
Three fire-bombing aircraft and two helicopters will support 65 DSE firefighters on the ground, Mr Davis said.
"There's no private property under threat at this stage, but it is likely the fire will possibly spot on to private property later in the day.
"It's wheat country and it's all green crops at this stage, so it's unlikely to cause significant damage. There are no towns or settlements in the area, it's all broad-acre farms.
FollowupID: 453344
Reply By: Shaker - Tuesday, Sep 19, 2006 at 10:15
Here we go again!
AnswerID: 195268
Reply By: Member - Mike DID - Tuesday, Sep 19, 2006 at 10:34
A Hazard Reduction burn is fire lit to remove fuel when the danger f a wildfire is low.
A Backburn is a fire lit near a wildfire to remove fuel in its path to control the spread of wildfire - without using water.
AnswerID: 195278
Follow Up By: Member - Duncs - Tuesday, Sep 19, 2006 at 16:59
That's correct Mike.
They can both be a useful tool but need to be used very carefully.
I can only guess but I would imagine weather conditions in Murray Sunset would be similar to here. (Broken Hill). Hot with strong N winds.
We have an Extreme Fire Weather Warning in place today for the Lower Western weather district which borders Victoria close to Murray Sunset NP.
I would have been very reluctant to light any fire under today's weather conditions.
It's just my 2c worth
Duncs
FollowupID: 453424
Reply By: Old Scalyback & denny - Tuesday, Sep 19, 2006 at 17:12
goodday fellas
if you have a look at the dse site you see they have several fires going or they did 2 nights ago
steve
AnswerID: 195354
Follow Up By: GaryInOz (Vic) - Tuesday, Sep 19, 2006 at 19:30
Sh*t load more now.......should have looked at the longer term forecast................... (or at least looked a bit further than outside the office window)
FollowupID: 453444
Reply By: Inspector - Tuesday, Sep 19, 2006 at 21:42
Don't see anything on this thread that indicates the hazard reduction burn was lit by DSE.
Maybe this was a farm burn or private HR that escaped, that could have been lit weeks ago and was considered out.
AnswerID: 195421
Follow Up By: Pajman Pete (SA) - Wednesday, Sep 20, 2006 at 08:25
This fire was lit by DSE as a hazard reduction burn and was listed as such on the DSE website on Monday. Now they just list the fire, not who started it:
Site Link
Pete
FollowupID: 453544
