Do We take a second spare
Submitted: Tuesday, Sep 19, 2006 at 13:52
ThreadID: 37845 Views:3542 Replies:20 FollowUps:19
Hi This Saturday i am fitting 5 new Goodyear Silent Armours to The Gu and they are 17" what a pain, We are planning on going to the Flinders and doing a couple of seld guded treks one being Skytrek plus heading to Arkaroola then of to oodnadatta, the question is i am planning on taking a second spare one of the original tyres that i am replacing do i purchase a steel rim for this or do i just take the carcass?????
Dave T
Reply By: Truckster (Vic) - Tuesday, Sep 19, 2006 at 13:54
The standard tires arent that strong from previous threads, i'd be buying anothe GYear for added security... and taking carcass...
AnswerID: 195308
Reply By: Willem - Tuesday, Sep 19, 2006 at 14:05
You should not get any punctures where you are going. All pretty tame stuff though very scenic. Take a spare carcass.
AnswerID: 195309
Reply By: Robin - Tuesday, Sep 19, 2006 at 14:08
Hi Dave
Wouldn't take either (2nd spare or 17in Rim ).
I think the arguements for 2 spares are marginal , and
revolve around time and convience and can be applied to
taking 3 spares instead of 2, almost as easily.
In this case your not going particularly far away from the ability
to get a flat repaired or replaced even a 17".
Assume of course you carry tubes , bead breaker and stuff needed to
do reasonable repairs up to and including sidewall damage.
If you really were concerned about 17in availability , then thinking laterally, just take an old 15 or 16 in rim , and you can always get a tyre to fit it in an
emergency. You can always drive slowly with odd sized wrong wheels/tyres
ok if pushed, espically if adjust pressures to roughly equalize diameter.
(Check rim fits first though)
Robin Miller
AnswerID: 195310
Follow Up By: Wizard1 - Tuesday, Sep 19, 2006 at 14:16
Robin,
I'd be interested to know how many times you've done a tyre hundreds of KM from somewhere you can get a repair or replacement? The whole of Australia does not have the same level of services as the city. Indead you may be held up a while if that little outback garage doesn't stock 17 inch tyres.
I lived in the NT for several years and almost everyone that does any decent off road work carried two spares.
Yes it may take up room and weight but it is like any type of insurance policy, sometimes it is better to have it than not in some situations.
FollowupID: 453382
Follow Up By: Robin - Tuesday, Sep 19, 2006 at 14:48
Hi Wizard
Had a few punctures outback but can't recall a situation where
I have been unable to repair and need 2 spares.
And Dave T is not going to be that far from trodden tracks anyway.
I like the "Give a person a fish, or teach him how to fish"
senario other wise why take 2 not 3 spares?
My suggestion of a spare junk standard size rim, is practical
if your really concerned as it weighs only 1/2 as much (11kg) and
takes up half the space of a spare.
I like your insurance policy analogy, but remember the policy
holders are net loser's.
Similarly I think if we had all the data we would find that carrying
an extra spare, particularly those on a carrier at back of car has in net
done more damage than good by overloading the rear of car with
a typical extra 70kg leveraged a meter out from axle.
Robin Miller
FollowupID: 453391
Follow Up By: Wizard1 - Tuesday, Sep 19, 2006 at 15:06
Robin,
I think your suggestion that people would carry 3 or more spares is missing the point a little.
No one suggested that yuo should carry an extra wheel assembly on the rear door. I carry mine on a roof rack.
Most people would not be competant to carry out a full wheel repair or carcass replacement. I certainly do not want to, although I've done it in the past, fix a tyre on the road side in the dust and heat which could take quite a while if not praticed at it. Changing the wheel is also a lot quicker.
If you want to sit on road side fixing your flat...............
FollowupID: 453396
Follow Up By: Robin - Tuesday, Sep 19, 2006 at 15:36
Hi Wizard
Why is it missing the point ?
While there is a clear logical reason for carrying 1 spare wheel as opposed to none.
There is no logical difference in the arguements between carrying 1 or 2 and carrying 2 or 3.
Its the same arguement with just different limits as set by how comfortable each of us feels.
In fact I'd go further and say that if you have so destroyed 2 tyres on a track that you need your 2nd spare then its likely that you have gotten something wrong somewhere and there's a reasonable chance you'll do it again, if you don't look for the real source of the issue.
Robin Miller
FollowupID: 453410
Follow Up By: greydemon - Tuesday, Sep 19, 2006 at 17:44
There is a lot of difference between talking 2 instead of 3 spares, or 3 instead of 4. If the chance of getting one puncture is 20%, then the chances of getting 2 might be 5%, getting 3 might be 1% so you make your own choice of acceptable risk.
I carried 2 spares for 3500kms and the only punctures I had on the whole trip were in the space of 20kms on the Gibb River road where I had FIVE of them - one tyre totally destroyed, three plugable, one not. (Odds probably about 0.25% but sometimes you get unlucky!)
Yes I know that there is enough traffic on the Gibb for me not be in any danger, but changing wheels and doing a bit of plugging then getting to Kunnunurra under my own steam was a minor inconvenience. Having to get lifts backwards and forwards while leaving my wife and three daughters by the roadside would have been a major issue and holiday spoiler.
I took two spares and a carcass down the Gunbarrel to Alice, then back down the Great desert road, and didn't need any of them. Ya pays ya money and takes ya choice.
FollowupID: 453429
Follow Up By: Member - Doug T (W.A) - Wednesday, Sep 20, 2006 at 00:47
I would doubt very much if the Pink Roadhouse would have 17" tyres yet, mind you I did say doubt,
FollowupID: 453521
Follow Up By: Groove - Wednesday, Sep 20, 2006 at 13:07
I dont think the maths work that way Greydemon
If the chances of getting your first puncture are %20 then surely the chances of getting a second pucture are still 20%. The likelyhood of geting a puncture does not depend on when you had your last.
Does that make sense or is my mind disolving.
FollowupID: 453591
Reply By: Wizard1 - Tuesday, Sep 19, 2006 at 14:09
Have carried two spares for years. Every trip we get at least one puncture, one being the Oodnadatta Track, the other was Roper Bar to Booraloola. I was always secure in the fact I still had another fall back as well as a Safety Seal repair kit.
Better to be over prepared than under...Some may contrary my thoughts. But when your heading down the road with the knowledge the tyre on your door is now punctured and useless how secure would you feel when anything can happen and your still 200 km from civilisation?
Just a thought.
AnswerID: 195311
Follow Up By: Mike Harding - Tuesday, Sep 19, 2006 at 14:13
That's what HF radios are for. But I suppose, if you have space, 2 spares are better than 1 and 8 spares are better than 7...? Where to stop?
Mike Harding
FollowupID: 453381
Follow Up By: Wizard1 - Tuesday, Sep 19, 2006 at 14:26
Mike,
I'm sorry but I'd rather spend 20 minutes changing a tyre that cost me $50 for the extra rim and re-use a replaced tyre carcas rather than the $2000 odd for a HF.
I think spending 20 minutes changing a tyre and be on your way again is better than waiting god knows how long for help to come with a tyre after making a HF call.
But I suppose there will be those that will continue to provide reasons why you shouldn't carry and extra you either do or you don't.
FollowupID: 453386
Follow Up By: Mike Harding - Tuesday, Sep 19, 2006 at 14:46
Fair point.
What will you do if you don't get a puncture but your water pump packs up?
Mike Harding
FollowupID: 453390
Follow Up By: Wizard1 - Tuesday, Sep 19, 2006 at 14:55
Well I suppose based on the theory of probability, you are more likely to get punctures than stuffed water pumps.
I don't disagree with having a means of communication for emergencies and breakdowns. I also think that drivers need to be responsible, within reason, for their own ability to get going again rather than having to rely on others to help them.
You can't predict a water pump going or any other major component of the vehicle and I guess that's the time you use the HF or SATPHONE.
FollowupID: 453393
Follow Up By: Willem - Tuesday, Sep 19, 2006 at 14:59
I always carry an extra spare.
On our last adventure I managed 7 punctures/stakes and used up 16 plugs on them. The extra spare never came off the roofrack.
I suppose it is always best to be over prepared but you then tend to carry a lot of stuff which adds more weight to the rig.
FollowupID: 453394
Follow Up By: Member - Bill F (VIC) - Tuesday, Sep 19, 2006 at 16:15
Wizard1
"I was always secure in the fact I still had another fall back as well as a Safety Seal repair kit."
Do you carry spare tubes as well or are you in such a hurry to get where you are going that you Need also a safety seal repair kit as well as two complete spares?
Ps. what type of rig are you using?
bill f
FollowupID: 453420
Follow Up By: Wizard1 - Thursday, Sep 21, 2006 at 13:27
Bill F and those that can't accept that 2 spares might be a good idea,
We have a 95 series Prado TD fitted with Cooper AT. We do a lot of off road caravan towing and general 4WDing. All punctures have been screws, etc on dirt roads like the Oodnadatta Track and Roper Bar! I also carry a second spare for the caravan as well!
If the tyre is that bad (eg. side wall stake) then I guess we fit the spare. If it is repairable using a safety seal plug, then fine. The thing about Safety Seal is you only need a compressor, no other specialist tools and the ability to read the instruction leaflet.
I considered getting Bead Breakers, etc and perhaps carry tubes and other repaitr kits, but for the cost and hassle it didn't seem practical. I already had a spare good quality tyre caracass, so a $50 investment in a rim seemed better than the $80 for a bead breaker.
Having said that, who's to say on our next trip we will probably stake two tyres through the sidewall...then I guess I'm stuffed. If we intend doing any really remote trips then I guess we'd consider spare tubes and bead breakers.
I see a second spare as a no brainer insurance to lessen the possibility of disaster. Most people are unskilled at tyre repair on the side of the road or find the whole exercise as something to avoid. It has nothing to do with being in a hurry.
I've changed plenty of truck and 4WD tyres, slit rims and standard steel rims, using the traditional methods by hand. So its not as though I need a right of passage for tyre repair. If I don't have to do it I won't!
As I've said, if you want to sit on the road side and repair a tyre then knock yourself out.
FollowupID: 453817
Follow Up By: Bonz (Vic) - Thursday, Sep 21, 2006 at 20:51
Stop at 4 Mike
FollowupID: 453947
Reply By: Member - Stan (VIC) - Tuesday, Sep 19, 2006 at 14:20
It's a Murphys' law.... If you don't take the second spare - you'll need the second spare. ;) As others said just take the carcas with you.
AnswerID: 195315
Reply By: Member - Beatit (QLD) - Tuesday, Sep 19, 2006 at 14:38
Haven't been in that neck of the woods so don't know what is on offer but regarding carrying extra spares and repair gear I'm all for that. Had this lesson in Weipa a few years ago, did a tyre going to Cape Melville and wanted to replace it in Weipa as we were still travelling up. OK, Weipa I would not describe as very remote so shop around town, couldn't get a tyre like I already had, no problem we can get one in from Cairns on the truck in a few days. We were doing the sights so no problem, tyre day rolls around (sorry for the pun) and guess what the tyre was left off the truck so we ended up with a non like replacement.
So what you might say, I got a tyre and it can get me out of trouble but I paid top price for a tyre I would replace on my return. The point is, carry an extra case if you can (presuming you have the equipment to fit it - or at least have it done somewhere where they can). The piece of mind this gives is worth the trouble.
Kind regards
AnswerID: 195323
Reply By: Steve63 - Tuesday, Sep 19, 2006 at 14:55
Hi Dave,
If you have the $$ get the second rim. Changing a tyre is less hassle than fixing one. Take some tyre repair gear (plugs etc) as well. I have rolled up in Oonadatta with both rear tyres going down. Both had been pierced by shards of quartz used in some road repairs. No probs I thought, Ill get Pink Roadhouse to fix them (just slack I suppose). I then found out that two of the three places were closed (sick rels in the city etc) and the third was leaving for Adelaide in 40 minutes. I got them fixed or I could have done it myself. Do not rely on services in the towns to the point where they are your only option, the people who run them also get sick, go to hospital, have sick rels etc. I normally try to use the service as if no one uses them they tend to close down and regional Australia needs to have its services supported. That does not mean they are my only option.
Steve
AnswerID: 195324
Reply By: Member - Phil G (SA) - Tuesday, Sep 19, 2006 at 15:16
Just my 2c as to why you need a 2nd spare on a rim:
#1 Punctures are frequent on Flinders tracks and oodnadatta track - sharp stones. Most punctures are preventable with low pressures, slower speeds and less weight, but many don't take notice of this.
#2 If you damage your single spare, you'll be anxious about the next puncture and won't enjoy your trip.
#3 If you can find a 17inch tyre up north, it will be the wrong brand, wrong size and you'll pay $500 for it.
#4 Your 17" Patrol rims are mags, and if you do your own repairs, you will scratch them up with the tyre irons, not just the beadbreaker.
I am happy with a single spare when travelling in a group where we share spares. But travelling alone, its worth having a second mounted spare. last time I needed the second spare was 7 years ago. I don't know when the next time will be, but I care for tyres better than I did in the past, and like you, I like to use a quality tyre like the Goodyears.
AnswerID: 195330
Reply By: Member - Andrew W (SA) - Tuesday, Sep 19, 2006 at 15:24
I'd guess you'd be waiting a while for a 17" spare anywhere North of Port Augusta, except perhaps Alice.
The carcase if it were me, would be mandatory for 17" in particular. You won't get them at Ark, Ood or even Angorichina.
Whether or not you take a rim, depends on how lazy you are.
Andrew who has had two spares sitting on the back for about 60,000ks without taking them off - touch wood.
AnswerID: 195331
Reply By: Member - Ian S (NT) - Tuesday, Sep 19, 2006 at 16:03
Hi All,
I try to have alternatives, I carry HF and satphone, I carry two spare wheels. I had two stakings in 2 minutes on the approach to Madigan on the new bypass, both plugged.
These folks that say carry a carcass is good idea for weight, but learn and practice tyre changing at home before you get here. You may have the truck in a foot of water or mud!! I would go for the spare.
Many outback punctures result in a destroyed tyre wall because the driver didn't detect it quickly enough when driving fast on a dirt road. Then they get stressed when they don't have another spare and the second hand tyre isn't quite right in brand, size or wear. If its the only outback trip you are going to do - OK, if not invest in your future and buy a 6th wheel that suits your car - at city prices.
Today a couple wanted to cross the Simpson Desert with 115lts of diesel. I advised them that the average 6 cylinder diesel uses 110 ltrs in good conditions and it is recomended that he carry 150ltrs to have a margin. That is what the whole story on outback, remote area travel is about - having a margin, be that an extra tyre, mechanical spares or sufficient fuel. With a margin you have an additional chance, it is an unforgiving country afterall. Yes, they did choose to buy more fuel!
Enjoy
Ian@Mt Dare
AnswerID: 195337
Reply By: StephenF10 - Tuesday, Sep 19, 2006 at 16:17
The first time I did Skytrek I had a puncture at the homestead before even starting. I wasn't going to do the track with no spare so a whole day was wasted with a trip to Port Augusta for a new tyre (old one was unrepairable). I now carry a second spare everywhere.
Stephen.
AnswerID: 195341
Reply By: downtools - Tuesday, Sep 19, 2006 at 16:34
Hi Guys,
Everyone has a different view and thats healthy!!
We spent 2 years travelling around oz and left Sydney in a landcruiser with alloy wheels and 1 spare.
After some time (and 2 staked tyres) in the gulf I decided to carry 2 spares. I bought and carried a spare carcass in Darwin and didn't need it although the "main" spare was repaired twice.
Carrying a spare carcass is fine but wheels can be damaged too, what if the alloy (or steel) wheel is destroyed as well as the tyre?
If you have 6 of the same wheels and tyres and rotate them all then nothing is lost IMHO.
See ya
Nifty
AnswerID: 195345
Reply By: Richard W (NSW) - Tuesday, Sep 19, 2006 at 17:35
Most of the times I carried 2 spares I didn't need either. The times I didn't carry a second spare I could done with one as a rock punctured the side wall. I've even punctured two tyres on the one day but was able to plug them on site.
Murphys Law as whats been said.
AnswerID: 195364
Reply By: Philip A - Tuesday, Sep 19, 2006 at 18:36
Of course theextra 30-40 Kgs of an extra spare may increase the possibility of a puncture due to the extra weight on the wheels. Moreso if you are the prudent type who also takes numerous other "just in case " spares.
I always go as light as possible, while recognising what will stop you. I have two alternators and batteries as with an auto, you cannot push start.
Regard sPhilip A
AnswerID: 195373
Reply By: Mike Harding - Tuesday, Sep 19, 2006 at 19:17
From the combined wisdom of this thread it is now quite obvious to me that I need to carry 10 spares and that will, virtually, guarantee I never need to use any of them!
Mike Harding :)
AnswerID: 195379
Follow Up By: Moose - Wednesday, Sep 20, 2006 at 13:40
G'day Mike
Yeah, but to carry that many spares you'd need a trailer. So how many spares do you think should be carried for it? :-)
Cheers from the Moose.
FollowupID: 453601
Follow Up By: Pajman Pete (SA) - Wednesday, Sep 20, 2006 at 15:33
And then what if you break the draw bar or springs on the trailer. You will need another trailer for the trailer spares!
FollowupID: 453620
Follow Up By: Moose - Wednesday, Sep 20, 2006 at 15:43
Me thinks it may be easier just to carry a puncture repair kit and a couple of tubes (and know how to repair a tyre). And remember to play with pressures as required and drive sensibly. I'm in the don't carry a second spare camp.
FollowupID: 453624
Reply By: Hairy - Tuesday, Sep 19, 2006 at 21:49
Just take an extra spare, or carcas if your prepared to change it!!!!!
AnswerID: 195424
Reply By: SA_Patrol - Wednesday, Sep 20, 2006 at 07:32
Hi DavidT, for where your going many Commodores drive that same road except the Skytrek, just carry a carcass.
AnswerID: 195457
Reply By: Pajman Pete (SA) - Wednesday, Sep 20, 2006 at 15:36
I had two spare carcasses behind the shed from my last tyre change. I went to grab one to replace a damaged spare and found that a sucker from the neighbour's cherry tree had come under the fence and grown up through the centre! It is now 4" thick and we got cherrys from it last season too. Now what do I do?
Pete
AnswerID: 195519
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Wednesday, Sep 20, 2006 at 19:23
If I was travelling in the Flinders or anywhere else in outback Oz with 17inch tyres I'd definitley carry 2 spares.
AnswerID: 195563
Reply By: DavidT - Thursday, Sep 21, 2006 at 09:42
Thanks everybody for the advice i have ordered another rim not very much dollars to save the time & money on the trip.
Dave T
AnswerID: 195643
Follow Up By: Wizard1 - Thursday, Sep 21, 2006 at 13:29
David,
I guess the arguements for the affirmative were a lot more convincing than against....
FollowupID: 453818
