Terrano TD27 Shocks
Submitted: Wednesday, Sep 20, 2006 at 13:09
Lucky Pierre
I need to replace the front shocks on my 1990 Terrano and have found the recomended EFS shocks to be to short by 15mm so I have settled on the slightly longer OME shocks.
Has anyone had similar experience ?
Reply By: suepajero - Wednesday, Sep 20, 2006 at 13:21
Hi everyone we have just got our 2004 np pajero exceed which we love so far .We tow a caravan and want to put a boat loader on the paj ,we are looking at the Rhino rack and boat loader as its a lot of money we are trying to get as much information as we can.Has anyone got the same car with that set up cheers sue
195503
Follow Up By: Shaker - Wednesday, Sep 20, 2006 at 17:12
........ and the relevance to the question is?
I think you meant this to be a new thread!
453643
Reply By: kev.h - Wednesday, Sep 20, 2006 at 17:27
Hi Pierre
Should all be much the same as they copy the original specs there may have been confusion if they looked up Terrano 11 as the front end is different also are the shocks original? sometimes when they raise the front with the tortion bars they have been known to fit slightly longer shocks and put lower profile bump stops in to get wheel travel back.
where are you located? i have a great contact on the
Gold Coast Qld for parts if you need
Regards Kev
195544
Follow Up By: Lucky Pierre - Wednesday, Sep 20, 2006 at 17:58
Thanks Kev,
I'm in Bris and would appreciate a good spare parts contact, their was no confusion about the make and model.
I think the original shocks were replaced before arrival in Aus as the shocks are Jap and are not connected to the ride adjustment switch between the front seats.
You may have a point about the change to longer shocks as the Jap shocks are 50mm longer than the EFS.
P
453653
Reply By: SantaAus - Friday, Sep 22, 2006 at 17:52
I have just replaced the shocks on my Terrano, I have installed low profile bumpstops (Front) which give a slightly better articulation in the front. I bought my shocks from TJM (XGS) The ones that are quoted in thier book are slightly shorter than the standard ones. (For some reason the shocks on the WD21 Terranos are longer than the WD21 Pathfinders, which they don't realise) I ended up getting a shock that is meant for a Toyota Surf. I had to add a shim to reduce the bolt size in the eye of the shock from 25mm to 16mm. Also had to trim of some of the rubber bush in the eye of the shock. Other than that the shock fits perfectly.
The part is either: (I can't remember which is the front and rear numbers)
650GAS12088
650GAS12636
SantaAus
195992
Follow Up By: Lucky Pierre - Monday, Sep 25, 2006 at 12:36
I fitted the OME L/T gas shocks on the weekend and had to shave the nylon bush to fit within the lower mount, the bolt size remains the same and fits ok.
Thanks for the info.
P
454655
