240 blitz
Submitted: Thursday, Sep 21, 2006 at 10:30
Member - Miles P (VIC)
Am I right in thinking the lightforce 240 blitz are too big for the factory steel winch bar on a GU?
Reply By: Truckster (Vic) - Thursday, Sep 21, 2006 at 10:48
come and try
mine if you want.
195657
Follow Up By: Member - Miles P (VIC) - Thursday, Sep 21, 2006 at 13:30
Trucky did you have them on your nissan bar before you changed?
453819
Follow Up By: Truckster (Vic) - Thursday, Sep 21, 2006 at 13:51
Na, I matched them up to the bar, they looked like they would fit, but it would have been REAL close... pretty much blocking most air flow thru the center.
453824
Follow Up By: Bonz (Vic) - Thursday, Sep 21, 2006 at 20:43
I got 240's XGT's on my Nissan factory bar
453942
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Sep 22, 2006 at 10:55
Got Blitz on
mine too.............
454068
Follow Up By: Larry01 - Saturday, Sep 23, 2006 at 15:03
Are you happy with them? what other lights have you used?
454324
Follow Up By: Truckster (Vic) - Saturday, Sep 23, 2006 at 22:26
got hold of some cibie oscars to try a set of HID conversions off ebay on.. Shall see how they go :D
240's rock comparing against my old Rally 4000, or 2000s...
454385
Reply By: Member - Roachie (SA) - Thursday, Sep 21, 2006 at 11:49
I think you'll find they'll fit but may poke out in front of the line of the bar (when viewed from the side profile). So, it depends on whether the law-makers (that's if you give a toss about what they reckon.....I don't!!!) consider is safe. Given that they present a "softer" landing for a poor pedestrian (than the steel bullbar cross member), I believe there is no downside to having them protrude in front of the bar. But, as we all know, that would be the common-sense approach, so don't expect the do-gooders to see it that way.
195671
Reply By: Alan S (WA) - Thursday, Sep 21, 2006 at 14:04
Miles
They Fit. However you will need to put spacers under the bracket between it the bull bar to raise the level about a inch. This means the botton of the lense doesnt stick out past the rubber pads of th ebar. The top of the lights do stick out in front of the top of bar slightly (as the bar slopes backward)
If you dont put the spacers you may have to drill holes closer to the front of the bar, then your lights will stick out. You will need longer bolts as
195711
Reply By: Graeme - Thursday, Sep 21, 2006 at 15:01
I have 240 Blitz on my GUII with an ARB winch bar. They are a good fit, but as has already been said, they do protrude very slightly in front of the bar, but are just awesome lights. Apart from some lowlife relieving me of my first set the current ones have been there for over 3 years and I have not had to re-aim them, nor have they contributed to any overheating. I have the 3.0ZD.
Graeme
195722
Reply By: Member - Sam (NSW) - Friday, Sep 22, 2006 at 07:52
They fit without an issue. No need for spacers or re-drilling or anything. Its just a matter of taking the mounting brackets/bases off the light unit and reversing them.
This moves the light forward to give it just enough clearance to clear the tubing without protruding in front of the bar either.
I have had them fitted to my truck for almost a year now.
You may be able to make it out on my rig photo.
195875
Follow Up By: Member - Sam (NSW) - Friday, Sep 22, 2006 at 07:53
I just read the post again and realised its the Blitz you are referring to. I have the XGT's.
My apologies.
454028
Follow Up By: Member - Miles P (VIC) - Friday, Sep 22, 2006 at 09:05
Well then apart from the extra $120 are the xgt's better than the blitz?
454046
Reply By: Member - Miles P (VIC) - Friday, Sep 22, 2006 at 08:55
Thanks for your info guys, I think I'll go ahead and grab a set from Outbak proven.
195899
Follow Up By: Truckster (Vic) - Friday, Sep 22, 2006 at 10:35
screw em on price, $330 about cost on a pr.
454059
