Sun power solar panels
Submitted: Saturday, Sep 23, 2006 at 17:53
MartyB
Can anyone tell me where to buy connectors to suit the Sun power brand solar panels?
The panels have 2 cables that have a connector similar to a large bullet connector.
Reply By: Notso - Saturday, Sep 23, 2006 at 18:42
Dick Smith Or Tandy have a range of these things, you might find one in one of the bigger stores.
196148
Follow Up By: MartyB - Sunday, Sep 24, 2006 at 07:58
Thanks Notso, I will try but they look a bit specialised for Tricky Dicky to stock.
Marty.
454413
Reply By: MartyB - Sunday, Sep 24, 2006 at 08:01
I found a picture of the connectors I want, pity it is on a US site.
Site Link
I will keep looking & see if I can buy them in Australia. If not I will cut them off & use other connectors.
Marty.
196188
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Sep 24, 2006 at 21:15
Have you tried ABR
196299
Follow Up By: MartyB - Sunday, Sep 24, 2006 at 21:24
Hi Derek,
Ok I give up, which page?
from Marty.
454543
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Sep 24, 2006 at 21:30
Derek is always available to help should you need technical advice even if it is not a product that we sell. We will happily negotiate a price if we have the item in stock and should you have any special needs we will use our contacts in the trade to assist.
196305
Follow Up By: MartyB - Sunday, Sep 24, 2006 at 21:35
Thanks Derek,
I had better go & send ABR an email then.
from Marty.
454544
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Sep 24, 2006 at 21:40
They are called MC cables and are available in different lengths and configurations.
Male / female 1m, 2m, 5m, 8m, 12m 15m
40cm male only
40cm f/male only
There are also branch sockets 2f & 1m or 2m & 1 f
This is why I prefer to sell the '
Junction Box' type of panel.
Regards Derek.
454547
Follow Up By: MartyB - Sunday, Sep 24, 2006 at 21:55
Hi Derek,
I just sent you an email.
I will probably cut these connectors off & use another type of plug & socket.
from Marty.
454552
Follow Up By: Mainey (WA) - Thursday, Sep 28, 2006 at 21:33
What model SunPower panel do you want information on ??
You can have various lead connections installed on SunPower panels!!!!
Simply ask your retailer to change to the actual connection you want fitted.
What state are you in?
455479
Follow Up By: MartyB - Friday, Sep 29, 2006 at 20:27
Hi Mainey,
I am trying to setup a secondhand set of 90w SunPower panels. They will be used on a camper trailer setup.
We have 2 panels, 2 double male adapters, 2 double female adapters and a male & female cable that has been chopped approx 400mm long.
Original setup had the 2 panels monted beside each other and one pair of cables to the reg.
I want to set them up with individual cables from each panel to the reg.
I was hoping to buy a couple of connectors & mount them onto existing cables but it looks like I can only buy pre terminated cables with these connectors on them.
I will probably just cut the MC connectors off the short cables on the panels & use a more readily available connector, possibly an inline hella socket. I have been onto Derek for some connector options.
Marty.
455671
Follow Up By: Mainey (WA) - Saturday, Sep 30, 2006 at 08:42
Marty, simply remove the existing cables from
the junction box and replace it with a new cable the correct length with out any connections at all, run the cables as short as possible, go from one panel to the next last then to the regulater.
I have my two panels done this way and I assure you it works.
455720
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Sep 30, 2006 at 08:58
Some panels don't have
junction boxes.
The wires are sealed directly onto the cells.
455722
Follow Up By: MartyB - Saturday, Sep 30, 2006 at 11:49
Hi a bit more info.
There is a
junction box on these panels, I looked at disconnecting the wires from there but could not work out how to disconnect. They seem to be a spring loaded type of connection, they looked a bit fragile so I decided not to try disconnecting the cables. Having a connector close to the panel is handy as it is a lot easier to set up the panel and then simply plug in the cable.
Disadvantage of using one cable is this means both panels must be mounted together. Camper trailer has a mount above the draw bar to mount 1 or both panels horizontally but depending on location we might want to mount 1 panel horiz and one panel on the ground angled.
Camper trailer has existing multiple anderson pole solar inputs.
A friends set-up has hella sockets on the panels therefore solar cable has hella plug one end & Anderson pole the other, Probably best off having this set-up the same.
455740
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Sep 30, 2006 at 14:34
Just fit Anderson plugs.
$9.00ea
455746
