bull bag help
Submitted: Sunday, Sep 24, 2006 at 17:29
jondg
I bought a bull bag/ exhaust jack this weekend, so decided to test it (before heading off next weekend for some beach driving) on my drive way.
However when I use it, it fails to fully inflate under the car, so does not manage to lift the tyres off the ground. When it reaches a certain 'pressue' , a leak come around the exhaust and no more lift is generated. Is this normal? My exhaust pipe is in perfect condition (on a new prado).
I bought it from TMJ.
Is is not designed to be able to lift the car up properly? Should i return it?
Any help appreciated.
Jon
Reply By: Notso - Sunday, Sep 24, 2006 at 17:39
The lifting capacity of these things is limited by the size of the bag so depending on how much surface area you have on the top the pressure inside the bag has to be higher to lift the vehicle off the ground.
The pressure inside the bag must be exceeding the capacity of the push on seal.
So, you can push the hose on harder or get a bigger bag basically. The ones I had all had a tapered rubber connection that you shoved over the exhaust pipe I assume they are still the same.
196241
Follow Up By: Member - Bucky (VIC) - Monday, Sep 25, 2006 at 06:12
Be real carefull with these things,
They are only designed to lift side on, to the vehicle,,, or one wheel at a time
Do not try lifting the entire front, or back, of the vehicle, or you may find out what swivell is all about !
Bucky
454593
Reply By: Hairy - Sunday, Sep 24, 2006 at 17:39
YEH, return it mate, if its plugged onto your exhaust properly it should lift your car!
196242
Reply By: Member - Captain (WA) - Sunday, Sep 24, 2006 at 18:03
Hi Jon,
Many years ago I used to run a 4WDriver training company. When demonstrating airbags, most times the exhaust system of clients vehicles would leak before the vehicle would lift. This was most common in petrol vehicles and often occured in diesel vehicles.
An airbag will find ANY weakness in an exhaust system and can create a hole that wasn't there before. I found long ago that an airbag cannot be relied upon in an emegency for this reason. Even if it worked before, whats the chance of damaging the exhaust system when off-road? But when they do work, they are a great way to quickly lift a vehicle.
Captain
196250
Reply By: Robin - Sunday, Sep 24, 2006 at 18:09
Before you send it back Jon.
These things have a valve in them , often half way along where the bit of hose to exhaust pipe is attached.
It should make no difference to the bag if it "falls off the exhaust" as this valve prevents air from coming back out. THis allows for intermittant connection at the exhaust end
Test that it holds at pressure you can put into it.
I suspect operation of this valve, see them leak and on a friends I got a bit of mudflap material and made new washer and his worked a lot better.
Robin Miller
196252
Follow Up By: jondg - Sunday, Sep 24, 2006 at 19:20
robin,
it doesnt deflate at all when removed from the exhaust, but the problem is i cant get the damn hose to seal effectively on the exhaust pipe.
should i just take it to the
shop so they can demo?
454513
Follow Up By: Robin - Monday, Sep 25, 2006 at 07:49
Just another thought Jon
As other posters are saying , these things are high volumne low pressure.
They are easily upset by a kink in the hose. Quite often the long hose, before or after the valve can fold over making it a lot harder to get air to the bag.
The connection to the exhaust doesn't have to be the best but it has to seal. Sometimes I have had to hold end around the 45 degree angled exhaust with 2 hands in
mine.
If checked above then I'd take it back for a demo.
Robin Miller
454599
Reply By: Member - Vincent A M (NSW) - Sunday, Sep 24, 2006 at 19:31
bags work on high volume low pressure (max about 4 psi) so check the over pressure relief valve (if fitted), if it is dumping you have to much weight for the bag if not fix your leak note some have a car type valve as an extra you can inflate thru that but this will take extra time as tyre pumps are designed to pump high pressure not volume you can also use a std inflatable boat pump as most will pump to 4 psi & the double action hand pumps that do air beds etc will pump to 11 psi so if you do not want to rely on the exhaust there are a few other options
196268
Follow Up By: Robin - Monday, Sep 25, 2006 at 07:50
Never thought of using
hand pump as a back up.
Good thought.
Robin Miller
454600
Reply By: Kev M - Sunday, Sep 24, 2006 at 19:57
What revs are you running the vehicle when trying to inflate the bull bag?
You may need to increase the revs to allow a bit more volume to force the bull bag up to its correct inflation level.
Cheers Kev
196275
Reply By: Des Lexic - Sunday, Sep 24, 2006 at 20:59
Many exhaust tail pipes have been cut away at 45 degrees so they don't get crushed when 4wding. They can make it difficult to get a good seal around the tail pipe and exhaust jack. Also it may pay to read your manual especially if you have a turbo fitted as the back pressure could affect the turbo.
Now that it has been used, TJM may be reluctant to take it back. I'd argue that it failed to achieve what it was designed for.
196292
Follow Up By: jondg - Sunday, Sep 24, 2006 at 22:30
yes maybe its the 45 angle. (i have a petrol engine, no turbo).
surely a common problem?
454562
Reply By: JezW - Monday, Sep 25, 2006 at 07:51
Hi Jon,
Had exactly the same problem with my 2003 Prado Td, only difference was i was on
the beach and in need of the air bag at the time. The problem is the 45 deg angle of the exhaust and the 45 deg angle of the attachment cone. You end up with the cone sealing off the exhaust. The fix is simple, buy yourself an off cut of white PVC storm
water pipe, 45mm diameter from memory and about 300mm long, but double check the exhaust diameter size. This then slides neetly inside the tail pipe and the cone then fits over the square cut end of the PVC pipe. Worked a treat on
mine.
Jez W
196351
Follow Up By: jondg - Monday, Sep 25, 2006 at 23:03
sounds too easy to be true!
my exhaust is 65mm diameter. so you reckon a 65mm thick pvc pipe? will it seal enough? and how far do you need to push it in?
not had time to return to
shop yet!
jon
454822
Follow Up By: JezW - Tuesday, Sep 26, 2006 at 19:22
Hi Jon,
Just checked the size of
mine, 60mm outside diameter, 3mm wall thickness, 300mm long. The pipe fits inside the exhaust tail pipe and pushes up to the 45 deg bend and protrudes by about 100mm. I've got a feeling ARB actually sell these as "Exhaust Jack Extension Pipes".
Hope this helps
Jez W
455036
