Wheel Bearing Grease???
Submitted: Sunday, Sep 24, 2006 at 18:04
ThreadID: 38004 Views:14159 Replies:9 FollowUps:2
What grease do others use in 100 series wheel bearings? Manual says lithium based wheel bearing grease. Castrol HTB is clay based , Castrol APXT is lithium based but doesnt state ok for bearings.
Thanks in advance
Reply By: HJ60-2H - Sunday, Sep 24, 2006 at 18:24
Castrol HTB. I believe that all greases are clay basd. Lithium is one flavour.
AnswerID: 196254
Reply By: Member - Duncs - Sunday, Sep 24, 2006 at 19:24
You could try the local Toyota dealer.
Price some name brand HTB Bearing grease at the local auto accessories first so you have a base line to work from. You may be pleasantly suprised by the price from Toyota.
Duncs
AnswerID: 196264
Reply By: Peter 2 - Sunday, Sep 24, 2006 at 19:38
Don't use HTB in Landcruiser wheel bearings, the hubs don't get hot enough to melt the grease unless you drive like a loony and absolutely hammer the brakes.
Most drivers will suffer from premature bearing wear if it is used. Landcruiser wheel bearings should last the life of the vehicle unless subject to poor maintenance, wrong grease or water/dirt ingress.
I've used Castrol APX for the last 20 years with zero problems.
AnswerID: 196272
Follow Up By: Longreach - Monday, Sep 25, 2006 at 16:36
Perhpas they should last that long but I just had my LC100 in for its 120,000km service at a major Adelaide Toyota dealer who rang me to say the rear bearings had to be replaced. As for your checklist, its regularly been serviced at Toyota dealers and I've brought it to their attention if we've done water crossings. Guess I should have asked for the old ones but didn't think about it till later.
Cheers.
FollowupID: 454703
Reply By: Member - Doug T (W.A) - Sunday, Sep 24, 2006 at 21:16
I sorta like this stuff mate , hope the link works ok ,it's a pdf
www.wynns.net/assets/MSD Sheets/MSDS 50220.pdf
" target="EOF" class="lbg">www.wynnswa.com.au/menu5.html
Doug
AnswerID: 196301
Reply By: LastAussieWorker - Sunday, Sep 24, 2006 at 22:42
dow corning lithium grease made for wheel bearings
used 30 yr no failure
AnswerID: 196316
Reply By: 3.0turbob - Monday, Sep 25, 2006 at 09:39
Have a look at the Castrol website, there is some good info on this grease. It's ideal for wheel bearings. Prefer not to use HTB grease.
AnswerID: 196367
Reply By: Craigww2 - Monday, Sep 25, 2006 at 10:32
I have looked at doing my bearings, can someone please direct me to any info on how to do them on a LC100. I started to do the front ones on the weekend but I shyed away as I was not 100% certain.
Thanks in advance
AnswerID: 196372
Follow Up By: Member - Phil G (SA) - Monday, Sep 25, 2006 at 11:33
LCOOL technical site
FollowupID: 454640
Reply By: Bob Y. - Qld - Monday, Sep 25, 2006 at 11:31
Shell Retinax LX2 works okay.
AnswerID: 196377
Reply By: Member - Phil G (SA) - Monday, Sep 25, 2006 at 11:38
Interesting.
I've used Castrol HTB for 20 years. They make it so it doesn't melt in high temp environment, but people here suggests that it would be good if the grease melted when hot. Can't say I've had a problem - its all sitting in the bearings when I regrease them.
Might use the other stuff next time.
AnswerID: 196378
