KWatts in 2.5L TD
Submitted: Tuesday, Sep 26, 2006 at 12:59
Bill13
Just inquiring about the kw's in a 2.5L TD Range Rover and what sized van are they capable of towing comfortably. Would appreciate any imput.
Is there a Range Rover
forum on the net that anyone knows of?
Reply By: Shaker - Tuesday, Sep 26, 2006 at 13:08
Try www.lroc.com.au
196613
Reply By: Redback - Tuesday, Sep 26, 2006 at 14:54
Are you talking about the new Rangie 2.7lt TDV6, if so it will tow anything and has about 150Kw
If you have a Rangie that has been converted to the 2.5lt 300TDi engine then probably around 75Kw to 85Kw.
Yes there is a Rangie
forum, go to THIS LINK to find out more, or HERE TOO.
Baz.
196626
Follow Up By: Member - Graeme (NSW) - Tuesday, Sep 26, 2006 at 16:51
I think what Bill13 is talking about is the RR whichcame out with the BMW 2.5 6cyl TD which came out many years ago and of which very few were sold and as such are quite a rarity. Australia at that time was not ready for diesels in luxury vehicles.
Just my 2 cents worth.
Graeme
454973
Reply By: garrycol - Tuesday, Sep 26, 2006 at 21:15
Range Rovers have never had a 2.5litre diesel. Late 80s RR had a 2.4 litre italian marine diesel that was not very good. The current model RR has a BMW 3 litre straight 6 diesel (TD6) that has about 140kw. The Current RR sport has a v6 2.7 litre diesel (TDV6) as fitted to the Discovery 3.
The only 2.5 litre diesels are the 4 cylinder 200 and 300 TDIs or the 5 cylinder 2.5 litre TD5 but none of these were fitted to Range Rovers.
The 6 cylinder diesels are 140-150kw, the original 2.4 litre RR Diesel was only about 80 kw. The TD5 is 99 kw and the 200/300 TDs were between 85-80kw.
If the RR has a 2.5 litre diesel is is not original and has an engine fitted from another landrover model.
Garry
196702
Follow Up By: fisho64 - Tuesday, Sep 26, 2006 at 22:35
garycol- you got too much time on your hands
or you love British iron??!!
455106
Follow Up By: Redback - Wednesday, Sep 27, 2006 at 11:00
Putting what model it is would clear things up.
455173
Reply By: fisho64 - Wednesday, Sep 27, 2006 at 21:29
dont ya love it when people post a question then dont bother coming back to look at it?
Bill13 will probably come back now and roast me!
196860
Follow Up By: garrycol - Thursday, Sep 28, 2006 at 10:20
I came back and had a giggle at your follow up cause you state the obvious :-). Jags are good too!!
455323
Reply By: Siegucci - Wednesday, Sep 27, 2006 at 22:04
The LP Range Rover (95-02) actually came with a BMW 2.5L TD engine in europe.
There are some in Australia, all private imports of course. The engine was quite under powered for such a heavy vehicle, very thursty and noisey. Most models were sold with a manual g/box which as
well was BMW sourced.
I would not recommend towing with that vehicle due to lack of power and the fact that they did overheat quite often under heavy load. (Thats in europe where the climate is a bit different than here.)
196864
