Prado UHF install
Submitted: Wednesday, Sep 27, 2006 at 20:00
Member - eerfree(QLD)
All
I am in the process of installing a GME uhf in my 2005 Prado I have got everything going real
well ----- except for connecting power, a direct connection I can handle , but I would like to hook it up thru the accessories position on the ignition switch has anyone done this? and can you point me to the appropriate wire to tap into and more importantly how to get to this wire!!!!
eerfree
Reply By: Andrew-rodeo - Wednesday, Sep 27, 2006 at 20:48
Not sure where you have mounted the UHF, but usually the cigarette lighhter power wire is a good option.
196844
Follow Up By: Member - eerfree(QLD) - Wednesday, Sep 27, 2006 at 21:26
Thanks, that was the cable I was aiming at, but after shredding about a square metre of skin, LOL I have still not found a way of getting to it ! --- and I also got into strife with the Good and Lovely for removing half the dash panels!!!
eerfree
455259
Follow Up By: Andrew-rodeo - Wednesday, Sep 27, 2006 at 21:41
or maybe a wire out the back of the fuse box??
455263
Follow Up By: Member - Jeff M (WA) - Thursday, Sep 28, 2006 at 15:41
I would go a battery connection myself, but an easy place to get accessory power would be at the back of the stereo. The stereo should be easy enough to get out if it is a standard jap stereo bracket, then just use your multimeter to find which wire on the connector has acc power and tap into that.
455376
Reply By: Member - eerfree(QLD) - Wednesday, Sep 27, 2006 at 21:28
I have mounted the radio under the passenger
seat and the remote head is under the ashtray.
eerfree
196859
Reply By: anglepole - Thursday, Sep 28, 2006 at 10:03
Hi eerfree,
GME usually recommends direct connection to the battery, why not their advice? Many vehicle manufacturers also recommend this, along with separating wiring from air bag and ABS wiring. There is a remote possibility that these can be compromised.
These radios only draw a few milliamps and wont flatten you battery unless left on for many days.
196920
Reply By: Troop-a-dour - Thursday, Sep 28, 2006 at 10:58
I've installed an extra mini fuse box (with 4 spade type fuses). Run one cable from pos. battery, and link one side of fuses together. Fuses for UHF/ Drive lights/ Reverse spot light/
HF radio. Save having spagetti off battery terminal.
196931
Reply By: Muddy doe (SA) - Thursday, Sep 28, 2006 at 19:02
I had my UHF wired to accessory power intially (paid somebody else to do it!) but within a month I was back getting them to rewire it direct to battery as it absolutely gave me the "tom tits" when it would shut off every time I stopped and restarted the car.
Nothing worse than somebody trying to call you on a club convoy trip and the radio went off 20 mins ago when you stopped for smoko and restarted. On my TD Prado the power seems to shut off momentarily when you engage the starter to fire up the engine (probably quite normal as it maximises power to starter and avoids power spikes to accessories). The radio (an Icom IC400PRO) would shut down in that time and not come up again. I did look at activating the auto on feature when power is available but then it would come on EVERY time I start the car and I do not use the UHF for the 90% of days when I just drive to work in
Adelaide where the airwaves are ruled by MORONS.
Now I have total control of when the radio is on or off. Leaving on overnight does not have any real effect on battery so that is no drama. Is good to pull up at
camp sometimes and leave it on if expecting other vehicles to call up without having to turn the radio on again or leave the ignition on.
Just points to be aware of.
Muddy
197026
Follow Up By: Member - eerfree(QLD) - Thursday, Sep 28, 2006 at 22:53
anglepole
My GME book tells me I can hook it up direct or via the ignition switch, maybe they have different instructions for there various products? Thanks.
Troop-a-dour
That is my next project!!
JeffM
I found how to remove the radio (and only lost a little bit of skin) and have connected the UHF to the back of the stereo.
MuddyDoe
Thanks for that info I have it all working now and we are away for a month at the end of next week so I will see how things go on the road.
eerfree
455502
