HELP on AA & AAA batterys.
Submitted: Thursday, Sep 28, 2006 at 17:51
ThreadID: 38125 Views:3814 Replies:17 FollowUps:15
I've just been into my local Coles store to buy some batterys, and was confronted by 1/4 acre of them. Some were filled with Unobtainium, others powered by Krytonite- or other chemical concoctions. After reading the labels and claims, I walked out thoroughly confused.
All I wanted was some AA recharchables for my lo-tech Sony digital camera, some AAA for the handheld UHF, and some normal AAA for the remote of the home VCR.
Whats the go?? Is there good ones and not so good ones?? Is there a code that I've missed??
Reply By: Member - uncle (NSW) - Thursday, Sep 28, 2006 at 17:56
We've used the Fuji brand batterys in our camera for 3 years and still going, we have just started to try some new ones now called Chamelion, whole kit from Super dodgy was 49 bucks, includes a car charger too, so far they have been great!
AnswerID: 196998
Reply By: ZUKSCOOTERX90(QLD-MEMBER) - Thursday, Sep 28, 2006 at 18:19
I would not bother with Unobtanium!!!!
I don't think you can get them.:)
Cheer's Bob.
AnswerID: 197003
Follow Up By: Member - Bware (Tweed Valley) - Thursday, Sep 28, 2006 at 19:38
Hahahahahahahahaha!
FollowupID: 455437
Reply By: Mad Dog - Vic - Thursday, Sep 28, 2006 at 18:25
The more they cost the longer they last.
AnswerID: 197008
Reply By: Mike Harding - Thursday, Sep 28, 2006 at 18:29
>I've just been into my local Coles store to buy some batteries,
I feel the same when I try to buy shampoo or toothpaste! :)
For rechargeables try Jaycar, don't go for the highest Ah ratings but get 2000mAh NiMh instead - issues with some of the "supposedly" high capacity stuff coming out of China.
For the UHF CB I suggest Duracell alkalines (Energiser are good too). You could use cheaper alkalines but they won't last as well.
For the remote - the cheapest alkalines you can buy, probably Jaycar again.
Mike Harding
AnswerID: 197010
Reply By: Mr Fawlty - Thursday, Sep 28, 2006 at 18:41
I'm using the Camelion ones Ni-MH in AA & AAA & they seem to outlast the Energiser rechargeables of the same capacity....Jaycar has a good recharger as well...
AnswerID: 197017
Follow Up By: Jimbo - Tuesday, Oct 03, 2006 at 13:39
Agree Basil,
The Camelions leave the Energisers for dead.
FollowupID: 456125
Reply By: GaryInOz (Vic) - Thursday, Sep 28, 2006 at 18:44
NiMH Rechargeable for the camera and UHF (Kmart have a reasonable range), and alkaline batteries for the remote. Avoid Duracell alkaline, old tech, not the same capacity as Eveready.
No need for Lithium in normal use, BUT, if you want to buy a set for the camera for use as a backup if you run out of rechargables in the bush it is a good idea. Ditto for the UHF radio. Lithium have a very long shelf life so are ideal as a "just in case" backup, but too expensive to use day-to-day.
AnswerID: 197018
Reply By: Member - Phil G (SA) - Thursday, Sep 28, 2006 at 18:54
I've had a great run out of Energiser NiMH rechargable AAs. Never seem to run flat in my power hungry camera. They are Japanese made cells. Cost $20 for 4 from Coles, and are 2500 mah.
I'd steer clear of the Chinese cells based on past experience.
AnswerID: 197020
Follow Up By: Mad Dog - Vic - Thursday, Sep 28, 2006 at 19:24
Yes Energiser rechargable are as good as any, good price and easily obtainable. I have quite a few AA and AAA''s and the performance is very good.
FollowupID: 455430
Follow Up By: LastAussieWorker - Friday, Sep 29, 2006 at 12:43
Choice mag tested all nimh battery
Energiser came up best
been using Energiser for years
no failures
bought some jaycar on special and crap
jaycar staff told me they were crap as told them chucked them away
they say should have brought them back and replaced
in the bush you cannot be with dud gear that fails
now only buy Energiser
FollowupID: 455589
Reply By: Road Runner - Thursday, Sep 28, 2006 at 20:34
I’ve tried AA’s branded Energizer, Power Base, Power Tech but would have to say that the batteries that give me the best performance (about double the photographs per charge) would be Duracell NiMH 2300 mAh.
I bought the Duracells and a 30 minute rapid charger in the USA last year but they are made in Singapore and would probably be available locally. Only one snag ... the Energizers, Power Base and Power Tech won’t charge in the Duracell rapid charger. For some reason they come up with a fail warning. Maybe the Duracell have more robust internals that can cop the fast charge.
AnswerID: 197040
Reply By: Member - Ben H (NSW) - Thursday, Sep 28, 2006 at 22:29
Hi Troop-a-dour
One of the guys mentioned this before but I thought that I would explain why the different types of batteries and why they are required. There are 5 main types of batteries, there are more but these are the most commonly used today.
• Alkaline (just your normal "AA" & "AAA" and "C" size ect)
• NiMh (most common use these days in digital cams)
• Ni-cad (good for kids toys and torches ect)
• Lithium AA non rechargeable (high power long lasting single use, you will have seen the adds on TV)
• Lithium rechargeable (these are supplied with most digital cams these days, a special battery for the type of camera, shaped to fit, it will not work with any other devices but your camera.
All these types of batteries can be put simply into 2 categories for most people to understand what they need for each device.
Alkaline & Ni-cad when used behave in a similar way, both have what is known as voltage drop, put them into a torch when new and the torch shines bright as they go flat the torch gets dimmer until it goes out.
Lithium rechargeable, Lithium AA non rechargeable and NiMh batteries all have constant voltage output, put simply, place these batteries in a torch and the torch will stay at a similar brightness until near the end of the batteries life when it will just go out.
Lithium rechargeable, Lithium AA non rechargeable and NiMh are the best type of batteries for you digital cameras because they need constant voltage output. If you have ever put normal AA's in you digital camera and only been able to take a few shots before the flat battery sign comes up, you would think that the batteries are dead, they are not, just put them in a torch and you will find some life left in them. Its just the voltage has dropped below the level required by your camera to operate, they are very hungry little suckers for power these days.
When looking for lithium or NiMh batteries the milli amp hours (1200, 2100, 2400 ect) will be marked on the battery this is an indication of the level of power (amount of shots) the battery has, the more milli amps the more shots you can take, Generally speaking the lithium will have lower marking on the side and will be a smaller battery but will last longer than its NiMh "AA" counter part will. Example a small lithium battery with 1200 mah will probably out last set of 4 "AA" with 2100 mah in a similar camera. The one advantage of the "AA" style of battery has is that in and emergency you can put a normal AA battery in its place if your rechargeable are flat.
So in summary normal "AA's" and Ni-cads are best suited in toys, radios, torches ect, Lithium and NiMh go with your new generation high power devices.
Sorry for the long post but I used to be the National Trainer/Head Photographer for Olympus cameras and when I start talking on these subjects it just keeps flowing.
Thanks, Ben
AnswerID: 197063
Follow Up By: Member - Phil G (SA) - Thursday, Sep 28, 2006 at 23:18
Ben,
I agree with a fair bit of what you say, but Alkalines and NiCads are very different. The voltage discharge curve of the Nicads is very flat so they suddenly die. Alkalines reduce their voltage gradually, so you have warning that they are going flat. Nicads can also deliver much higher current.
NiMH are similar to NiCads in that they have a flat discharge curve, but are less likely to suffer voltage depression from incomplete discharge(so-called "memory effect"). Both can deliver high amps, which makes them more suitable for high current applications.
For torches these days, LED technology is taking over - low power consumption, long battery life means the alkaline will again be the battery of choice. Nicads and NiMH will disappoint because of their higher spontaneous discharge and flat discharge curve (suddenly go flat) in this application.
FollowupID: 455508
Follow Up By: Mike Harding - Friday, Sep 29, 2006 at 06:27
Spot on Phil.
Additionally, alkalines have a terminal voltage of 1V5 whereas NiCd/NiMH are 1V2.
Another point about NiMH is that they have a very high self discharge rate so if it's more than a few days since you charged them they will be noticeably down on capacity.
Mike Harding
FollowupID: 455539
Follow Up By: hl - Saturday, Sep 30, 2006 at 07:08
Hi...
And be careful with Nicads in toys. They can supply enough current to make things go up in flames very quickly (as when a motor jams), hence the warning on many toys not to use them.
That is also the reason the higher capacity nicads have a recessed button so the don't work in many applications.
Nimh can not supply nearly as much current when shorted and seem to diminish in current capabilty after just a few cycles.
There is a new type of NiMh made by Sanyo which claims to retain 80% of capacity after 12 months storage.
FollowupID: 455713
Follow Up By: Member - Phil G (SA) - Saturday, Sep 30, 2006 at 09:25
Hi hl,
With respect to current, the gap between Nicads and NiMH has narrowed considerable. My son works in the R/C electric car and plane business, and races them for fun. The sub-C NiMH cells he uses now have unbelievable numbers compared to the NiCAD cells we were using 5-10 years ago. The IR and V are measured at 30amp discharge.
I haven't measured the common AAs though.
FollowupID: 455730
Follow Up By: hl - Saturday, Sep 30, 2006 at 12:29
Hi Phil,
You will find that the commonly available AA's are not nearly as good.
I use them in radios and after a few months and actually not that many cycles, they seem to only manage about 1 or 2 amps when short circuited. I have 10 year old nicads that will do double that!.
This also applies to what I consider good quality cells like Sanyo 2000 and 2300mAh cells.
Nicad cells however, are pretty much on the way out as they are toxic waste when disposed improperly.
FollowupID: 455742
Reply By: Member - Doug T (W.A) - Thursday, Sep 28, 2006 at 22:32
Troop-a-dour
What the #ell is wrong with these manufacturers and suppliers today,and it's not the fault of the store,they don't make and pack it. Consider this, you need 2 batteries for the torch,only bluddy 2 but you have to buy 4 ,I wanted a comb just recently, best pack I could find ....4 only wanted 1 , need a cake of soap, yeh but you have to buy 3 ,and the mongrels put up the price of fuel before a long weekend ,well I reackon we should have the right to say ....what price was it yesterday and when they tell you how much you then say well thats how much I'm gonna pay you today like it or lump it .
Doug
AnswerID: 197065
Reply By: Member - Jeff H (QLD) - Friday, Sep 29, 2006 at 03:14
A COMB Doug? So where did I transgress?
Watchim Dusty, bloomin nits, eh .
AnswerID: 197080
Follow Up By: RichieK - Friday, Sep 29, 2006 at 06:08
Very happy with Varta batteries and charger from Dick Smith/Tandy
Cheers and beers
Rich
FollowupID: 455538
Reply By: Kiwi Kia - Friday, Sep 29, 2006 at 07:03
The short answer is in two parts;
(a) Don't get nicad batteries - old technology, they have been superceded for a reason!
(b) Get several Nickel Metal Hydide and remember to cycle them through the charger.
Having only one type of battery means you only have to use one setting on the charger (nicad & nickle metal hydryde have different settings on your charger).
I have used NiMH batteries in all of my gadgets; gps, prs, mp3, led torchs, cameras, transistor etc. for years. I try and use only AA and can swap batteries between devices as required.
AnswerID: 197082
Follow Up By: Troop-a-dour - Tuesday, Oct 03, 2006 at 13:10
Thanks for your response,
Whats the go on "cycling batteries"..??
Do NiMH batterys have a memeory?? Do they have to be fully discharged before a full charge?? If so- how do you fully discharged them- safely??
Troop-a-dour
FollowupID: 456118
Follow Up By: Kiwi Kia - Tuesday, Oct 03, 2006 at 13:51
The 'new' technology NiMH batteries do not have to be 'cycled' so do not need to be discharged before being re-charged.
A 'top-up' charge can be done at any time. As previously mentioned, fast chargeing sometimes can cause excessive heating but they seem to take it ok.
Dickie Smith and others have the Varta chargers that can use either 230 or 12 volt input which is useful for chargeing when on the road.
FollowupID: 456128
Reply By: Groove - Friday, Sep 29, 2006 at 12:00
Also remember that the faster the charger the hotter the battery will get, this will reduce the life of the battery. I think that a half hour to charge a 2500mah battery is a bit fast.
However it is more convenient to fast charge them so its up to you. i have some NIMH batteries that have been going for 5 years and are still going strong. I bought a charger from Jaycar that will work from 240v or 12v for use in the car on extended trips.
AnswerID: 197129
Reply By: Member - Mozza (NSW) - Friday, Sep 29, 2006 at 13:22
toppy..
i use AA batteries in my digi cam... they are INCA brand .. and are 2600amph.. they last ages.. i did a 4 week trip arond Europe recently and they only went flat on the 4th last day .. and i've got over a 1000 photo's from that trip.
highly recommended.
got them from my local JB Hi-Fi store, with a 240V and 12V charger... so can charge at home and in car... bout $70... but well worth it.
AnswerID: 197137
Reply By: res.q.guy - Friday, Sep 29, 2006 at 22:59
The best batteries I have come across are Powertech AA Ni-Mh from Jaycar.
I purchased about 20 of them about 3 years ago, and use them in digital cameras and handheld uhf radio's, they just seem to last for a long time. Their capacity is 1650mAh which was the highest avail at the time. They are still going just as strong today. They are now avail at $3.59 ea or $3.15 for 10+.
There are also larger capacities avail - 2000mAh at $4.25 ea or $3.75 for 10+
2400 and 2500 mAh are also avail, but as said on a previous post I have heard that some are of suspect quality.
Neil
AnswerID: 197231
Reply By: Mike Harding - Saturday, Sep 30, 2006 at 06:31
One point which may catch some people (equipment) is that many (if not all?) AA cells greater than 2000mA capacity are 0.2mm larger in diameter than cells of 2000mAh and below. A more stupid, and unpublicised, change of an international norm/standard I have yet to see!
Mike Harding
AnswerID: 197248
Follow Up By: Member - Norm C (QLD) - Sunday, Oct 01, 2006 at 13:43
I've been caught be this one Mike. .2mm doesn't sound much, but the batteries I bought would not fit in my mouse. Very frustrating!
FollowupID: 455862
Follow Up By: Jimbo - Tuesday, Oct 03, 2006 at 17:27
Same problem with my old flash.
Bugger me dead, after reading this I stumbled across some Duracell 1700's in the Supermarket and Bingo, they fit.
FollowupID: 456167
Reply By: EdzGQ - Sunday, Oct 01, 2006 at 11:13
2 other points not mentioned here that are worth knowing.
1. In the book that came with my handhelds, it stated that the range is reduced by about 25% if you use rechargeables due to the lower voltage 1.25v compared to non-rechargeable 1.5V batteries, so I assume this applies to a lot of handhelds.
2. A lot of rechargeables have a shorter tip on the positive end, meaning they don't make a connection in some devices (my olympus cameras had this problem). You can get around it by carefully trimming the plastic off the top lip and remove the little cardboard ring, but be careful you don't short them out with the blade when doing it (or buy ones with longer tips).
btw - have used a lot of different Jaycar rechargeable batteries for about 6 yrs now, and they are ok, but the name brand batteries always seem to last a lot longer (both between charges and over the years). Ed
AnswerID: 197352
Follow Up By: hl - Tuesday, Oct 03, 2006 at 14:48
That shorter tip is there for a reason. It is there so you DON'T use them in appliances not designed for them. These batteries (they would be high capacity Nicads) can supply much more current than a dry cell or lower capacity Nicad.
This can be dangerous if the device develops a fault (the device may catch fire or the battery may burst)
FollowupID: 456141
