Overheating Surf
Submitted: Thursday, Sep 28, 2006 at 19:05
ThreadID: 38129 Views:6624 Replies:8 FollowUps:5
Hi all, a mate has asked me to put up a post for his mate (yeh I know about the mates thing), he has recently purchased a 2.8 Deisel Toyota Surf, im assuming that is an early one?, and it is overheating and they and the dealer have tried just about all they can think of.
NEW : Head, Head gasket, Radiator, Thermostate, Water pump.
When its nose is tipped up a hill it heats up pretty quick and blows some of the water out ?
Is there a regular problem with these things or is it an unusual problem for them?
I suggested checking the timing but have not heard back yet.
Any help would be appreciated, Thank You.
Cheers Pesty
Reply By: gazzagazza25 - Thursday, Sep 28, 2006 at 19:20
Hi Pesty ,
I have a 2.4 surf and i rebuilt it and then had the same thing happen . So i put a bleeder in the back of the head to bleed out same trapped air . I also fitted a thermo fan in front of the radiator and it has fixed the over heating ..
Cheers Garry
AnswerID: 197031
Reply By: howesy - Thursday, Sep 28, 2006 at 20:07
They usually have a thermostat housing that is an alloy unit that also has the radiator cap going on to it. If this is the one you have then I have seen with age the alloy goes powdery and it is almost impossible to get a good seal. We solved it by putting in the aussie radiator andthermo housing so the cap was on the radiator with an overflow bottle. This may not be the case but worth checking out.
AnswerID: 197036
Reply By: Member - Phil G (SA) - Thursday, Sep 28, 2006 at 21:07
The surfs were either 2.4 up until 1993, or 3.0 after.
Sounds lie he has the 2.4 which was noted for its head gasket/ cracked head stuff. The Toyota Surf email group on Yahoo have an archives that may offer some help.
AnswerID: 197048
Follow Up By: Member - Jeff M (WA) - Friday, Sep 29, 2006 at 00:19
Yeah, I don't think they ever released a 2.8 Surf, I sure as bleep havn't seen one.
Couple of things though.
1. Viscous fan. You gotta put TWO tubes of silicone in, not 1 as the manual says. Now I don't want to hear any crap from anyone who thinks they no different, just do it. :-)
2. Check for pressure leaks in the top and bottom radiator tanks, they are sometimes not visible. You loose pressure, you boil - simple. (mine was doing it when I bought it replaced the tanks and good). Oh and change the radiator cap.
3. Surf's (unlike the ozzie equiv. 4runners) have a REAR heater. It's just below the center console pointing towards the rear passengers. It's funny little peice of bleep has it has it's own heat exchanger. ie It flows hot coolant from the engine all the way back there, heats the air and then feeds it all the way back to the engine. When people flush the cooling systems, they never turn that heater on, ergo you get air locks and crap in there. Make sure BOTH heaters are on when refilling the coolant, or just simply cut the hose and join it (I never use the bloody thing, never cold enough to require TWO heaters!!). You'll see a big water hose come out the motor and go to the heater control valve on the fire wall, tapped into those hoses you'll see two little tiny ones, they are for the rear heater. A standard 1/3" barp joiner and two hose clamps will bypass it if you want.
4. Is it an auto? If so I'm going to make an assumption that the 2.4 has the same configuration as the 3.0 here. The gearbox in mine, as bloody good as it is (just amazing on and offroad, smooth, fast, great in low range etc) has the most bleep weak sized torque converter. It only holds about 4 litires of tranny fluid - ergo it get's bloody hot. Why does this cause the engine to overheat I hear you ask, because the ATF cooler is a heat exchanger (and a very efficiant one, too efficiant really) in the bottom of the radiator. As the coolant passes through it transfers the heat out of the heatexchanger/ATF and into the rad and then the radiator get's too hot and can't keep the engine cool.
How do you solve this?
1. Put an aftermarket ATF cooler behind the radiator. DO NOT disconnect the factory one or you'll cook your tranmission as the aftermarket coolers are not big enough/efficiant enough to keep the tranny cool, but the aftermarket will help take the heat out of the ATF BEFORE it goes into the radiator.
2. If you're going up long hills or doing boggy sand or towing, use the power ECT mode so the gearbox drops back faster and or turn the overdrive off. That will stop the torque converter slipping constantly heating up the ATF. It may seem odd at first, but I can rev the balls out of the surf all day and it won't over heat but at 2500rpms in the wrong gear I'll be at 110c before you say BOO! Let the engine rev and work, not the gearbox.
3. There is also a constriction in the bottom of the radiator, my guess is to slow the coolant down before it goes through past the heat exchanger, after you have fitted the aftermarket gearbox cooler you can remove that, it will allow the coolant to flower faster through the rad and consquently cool better.
FEW! Umm, I sure there's more things you can try, but that's the short storey! :-P
FollowupID: 455526
Follow Up By: Member - Jeff M (WA) - Friday, Sep 29, 2006 at 00:27
Oh and if he hasn't already, put a friggin aftermarket temp guage in. The bloody Toyota guage has 3 settings.
Cold (bottom of the guage).
Normal (half way or there abouts)
Your bleep ed (Once it leaves "normal" you're already doing AT LEAST 110c and it just flies to the red).
It is my FIRM belief that there were alot of cracked surf heads in both the 2.4's and 3.0's because of this guage alone! I mean if you're driving along a boggy beach the last thing you've got time to do is keep one eye ball glued to your temp guage and with these toyota guages by the time it's moved from half way you've more than likley cooked the bloody motor.
On my mechanical guage the factory guage moves to half way once the water temp reaches 60c. Running temp is 90c in mine, but of course the factory guage just stays half way between 60c and 90c. The factory guage does not even START to move of half until my mechanical guage reaches 110c.
FollowupID: 455528
Follow Up By: Member - Roachie (SA) - Friday, Sep 29, 2006 at 14:19
Jeff,
Quote: "On my mechanical guage the factory guage moves to half way once the water temp reaches 60c. Running temp is 90c in mine, but of course the factory guage just stays half way between 60c and 90c. The factory guage does not even START to move of half until my mechanical guage reaches 110c. "
Sounds like Nissan must use the same gauge as toyota.....cos that is EXACTLY what my Nissan gauge does (I have a VDO 'proper' gauge in the top radiator hose, which tells me the REAL temperature).
FollowupID: 455601
Reply By: RupertDog - Friday, Sep 29, 2006 at 13:03
Pesty
A Mate had the same problem with his Surf. It was a grey import, so don't know if that makes a difference.
He basically had overheating problems, that severly affected performance, and often left him in the middle of mess, with no power to get out.
After numerous visits to various mechanics, auto electricians, and cooling specialists, he fixed the problem by tradign it in on a 98 Land Cruiser. No overheating, no loss of power, and heaps more space!!
Don't know if this helps?
RD
AnswerID: 197135
Reply By: Moose - Friday, Sep 29, 2006 at 13:23
G'day Pesty
Mate of mine who was a used car salesman told me (when I was looking for a vehicle for my son) to be wary of the Surf's because apparently the radiator is too small and they overheat easily. So maybe a bigger radiator is the answer.
Cheers from the Moose.
AnswerID: 197139
Reply By: Member - Roachie (SA) - Friday, Sep 29, 2006 at 14:21
Pesty,
Tell him he should be able to pick up a near new 3L Nissan motor from just about any Nissan dealer and that it could be just the answer ......;-)))
AnswerID: 197147
Follow Up By: Member - 'Lucy' - Friday, Sep 29, 2006 at 16:17
Ignore him Pesty, and he will go away.
FollowupID: 455621
Follow Up By: Bonz (Vic) - Sunday, Oct 01, 2006 at 12:32
N o we wont
FollowupID: 455846
Reply By: The Boy - Friday, Sep 29, 2006 at 19:20
Pesty,
First have a good read of everything Jeff M has said, a lot of good points in there. Will add one more thing to it, make sure you do not have any kinks in the alluminuim oil lines between the tranny and radiator. This will cause a restriction in flow and heat build up in the tranny. Radiator can not remove the heat quick enough once its hot.'
My old man has a 3ltr Surf and have done lots of work to it trying to keep the temp down, it has worked for most of it but will still run hot when pushed hard. He tows a approx 2T van at the back and that normally gets the temp up.
I have changed the head, cracked due to overheating, added some silicone to the viscous hub and if the hub on the 2.4 is the same as the 3ltr you can adjust the opening temp of the valve inside of the viscous hub. This will allow the fan to kick in earlier, I myself noticed a huge drop in temp due to this change in the fan hub.
We replaced the thermostat with one from the prado, think the opening temp was about 71Deg from memory. There are three thermostats yopu can buy for my Fathers Surf, I did have all the Toyata part numbers but handed all the info over to Dad.
Check out the site below, lots of good info and the boys love to help you out in the forum.
www.toyotasurf.asn.au/forum/
The Boy
AnswerID: 197202
Reply By: Member - Pesty (SA) - Monday, Oct 02, 2006 at 07:30
Thanks everyone for your help, looks like it is a 2.4.
I printed this post and handed it on and much of the info will be of great assistance, thanks for your detailed responce Jeff.
Aparently its back at the dealers and the head is off again at the moment.
Cheers Pesty
AnswerID: 197417
