Caravan braking systems
Submitted: Friday, Sep 29, 2006 at 19:38
ThreadID: 38154 Views:15476 Replies:10 FollowUps:9
We currently own a 21ft Jayco with electric brakes.....I am thinking about buying a GEIST XK630 which has overide brakes....the vans are (almost) the same dimensions except the GEIST is lighter and the dual axles are centrally located, and the towball weight is 100kg as opposed to >170kg on the Jayco. I would welcome comments regarding the efficacy of the overide braking system (with this particular van)......should electric brakes be considered ?......Mal Hughes
Reply By: ACDC - Friday, Sep 29, 2006 at 20:07
Mal,
How much does the van weigh?
AnswerID: 197209
Reply By: Member - Charlie M (SA) - Friday, Sep 29, 2006 at 20:12
I wouldn't consider anything but electric brakes, independently operated by either brake pedal or manual override. Override brakes only work when you are braking under load or desperate to stop in a hurry
My van has brakes on both axles.
Charlie
AnswerID: 197210
Reply By: Angler - Friday, Sep 29, 2006 at 20:15
I thought override brakes went out of fashion for vans back in the 60's.
Electric brakes have a few advantages like being able to set braking power and action.
I change mine in towns to be a bit agressive compared to highway travel.
So easy with a prodigy.
Geist vans are substantialy lighter build than most aussie vans and are also more expensive. Only time will tell if they stand up to our roads (tracks).
Pooley
AnswerID: 197211
Follow Up By: honestjohn - Saturday, Sep 30, 2006 at 05:21
hey angler have you had any trouble with the prodigy i'm thinking of getting one
FollowupID: 455710
Follow Up By: Angler - Tuesday, Oct 03, 2006 at 12:58
Honest John,
No trouble whatsoever, can't say the same for the voyager I had before, it kept putting on the brake lights even when the car was parked in the driveway with no one in it.
Prodigy is the best ever however it is a little more exoensive. Most definately worth the extra dollars.
FollowupID: 456115
Follow Up By: honestjohn - Tuesday, Oct 03, 2006 at 19:43
i went and bought one angler could you tell me what yours is set at ,and do you
mean aggresive in the city as having the boost activated would be interested to hear mate
FollowupID: 456190
Follow Up By: Angler - Tuesday, Oct 03, 2006 at 19:58
When you first start out on a trip you may want to set the voltage a little lower than reccommended as there will probably be some rust on the drums and they can be a bit sudden until it wears off. I then set it at about 7 volts on the meter for normal cruising. On arrival at a town I go up two clicks to the second boost setting. when again on the highway I go back to the original seting.
I have the prodigy mounted exactly horizontal or flat on the centre console in front of the auto gear lever. Works for me. Easy to see the display to check on conection etc.
Your van may be diferent as will the brake adjustment so find your own settings by trial and error. I have never adjusted the brakes on my van as I feel they are fairly well adjusted when new. I had the vayager at first and had lots of trouble setting the adjustment however that may well have been dirt etc on the drums. I managed to get it rght eventually and then the brake light problem surfaced.
FollowupID: 456193
Follow Up By: honestjohn - Wednesday, Oct 04, 2006 at 05:07
thanks very much mate i will give it a go.we have a17ft viscount sportz
so should work all right,yeah we had the same problem with the voyager
trying to keep it adjusted will hear from you again mate
FollowupID: 456267
Reply By: Member - Vincent A M (NSW) - Friday, Sep 29, 2006 at 20:17
Electric brakes should be considered as over rides are pretty crap & normally only work when the trailer has already push the back of the tow car about & are realy bad in the wet (most people never get them adjusted right as they change with the load & road conditions & should realy be called a hand brake as most only work at this point) most trailers of any type tow better with a bit of weight to the front as long as the tow vehicle can handle it as it stops that see/saw affect that normally starts the dreaded sways, cant help you on the van don't no it, but i bet the one with electric brakes & axles a little back tows a lot better & is easier to stop.
Don,t tow any vans much But i tow every couple days from 250 kg to 4500kg
AnswerID: 197212
Reply By: Ray Bates - Saturday, Sep 30, 2006 at 09:11
Go for electric brakes every time. I have a 17'6" Jayco and they are good.
I fitted a set on my son's work trailer a couple of years ago and he has never looked back. One advantage that they have is that they can be applied independently of the towing vehicle. They are good for straightening up a caravan or when going down a hill.
The kit for my son's trailer cost $1500.00 (fitted by us) and includes drums, backing plate complete with shoes, a holding plate that has to be welded onto the axles. Necessary bolts, nuts & washers, brake controller and brake magnets and new wheel bearings.
The axles need to be removed from the vehicle and completely stripped and then reasembled with the new gear. None of the gear that is removed is re-usable on the new assembly. The kit that I used was for a tandem axle that had rectangular shafting.
AnswerID: 197257
Reply By: SunWizard - Saturday, Sep 30, 2006 at 13:32
Mal you are a brave person to buy a Geist or have to much money for your own good. If you are staying on the main highways like Europe it should be ok
Have seen 2 that looked like the old Aerolite with backside droop.
Would never consider a van with override brakes. My personal safety is worth more than crap braking system that is not adjustable by the driver. You would not be brave enough to go on gravel or poor bitumen roads with a Geist so proper brakes may not be an issue.
Fact of life small things break in caravans and with good Aussie built van you can get parts most towns. With your Geist you are beholden to the dealer. Check out Geist spare parts prices and availability and see if how your blood pressure handles the shock. There is one insurance company that will not touch Geist.
AnswerID: 197273
Reply By: 4X4Treker - Saturday, Sep 30, 2006 at 20:54
Mal
I have owned caravans with both overide and electric brakes and now I would not have anything less than electric brakes, much more control over the braking of the towed vehicle and less load on the towing vehicles braking system.
I am about to install electric brakes onto my off road camper trailer as I am so impressed with the electric brakes on my off road caravan.
Treker
AnswerID: 197308
Reply By: Old Scalyback & denny - Sunday, Oct 01, 2006 at 17:21
goodday folks
correct me if i am wrong but dont you have to have a proper braking system on any van over a certain weight (750kgs) and a breakaway system over 2000kgs and it either has to be electric or hydraulic i am not sure that override comes into this catergory although it did 20years ago before electric /hydraulic units
steve
AnswerID: 197373
Follow Up By: Member - Charlie M (SA) - Monday, Oct 02, 2006 at 23:04
Override brakes can be used up to 1999kg, 2000 kg and over must have brakes on ALL axles and be driver operated independantly from the brake pedal.
Charlie
FollowupID: 456045
Follow Up By: Member - Charlie M (SA) - Monday, Oct 02, 2006 at 23:07
Forgot
Up to 1999kg only need brakes on one axle
Charlie
FollowupID: 456047
Follow Up By: Angler - Tuesday, Oct 03, 2006 at 13:00
In qld,
Under 750 no brakes required.
Over 750 must have brakes.
Over 2000Kg ATM must have breakaway system as well as brakes on both axles.
Pooley
FollowupID: 456116
Reply By: robnliz - Monday, Oct 09, 2006 at 20:04
Hi Mal, we are in the same position as you except we are looking at a XK535, single axle, 17'6" with the same non electric breaking system. I'm sure if electric brakes were needed then they would be law in Europe after all as soon as you get off the motor ways in any European countries the roads are equally as bad or worse than many of ours and they also have real mountains.
I guess if the Aussie van builders could produce something with a modern airy interior with the flexibility of the Geist and at similar prices we would not be forced to consider imports. Nothing we saw at the Sandown show over the past weekend offered the sleeping flexibility. Two singles or a giant double as well as two bunks for kids. We are confused because it seems that no one is able to give a truly unbiased opinion on the Geist. It seems that the Australian caravan industry is reluctant to change, although A-Van at least seem to be trying. Can anyone give us an unbiased opinion on the Geist?
AnswerID: 198437
Follow Up By: Mal Hughes - Monday, Oct 09, 2006 at 23:06
Thanks for your response.....I would also like to have some unbiassed feedback regarding the GEIST. You are quite correct regarding the roads in Europe, and they also have weather condistions that we don't. The agent for the caravan is based in QLD and is coming to WA on 23rd October to officially launch a new dealer. I gather that a number of people will be available to answer questions etc. In addition, the caravan has been reviewd by a number of caravan magazines and the results of those reviews will be made available. From what I can gather the results are extremely interesting. I think that you are correct, the Australian manufacturers are not keeping up with overseas developments....such as lighter and more modern construction (monocoque bodies etc) and the provision of more usable amenities both inside and outside the caravan....time will tell I suppose....after I have been to the presentation on the 23rd I will drop you a line to update you.....Mal Hughes
FollowupID: 457176
Reply By: robnliz - Tuesday, Oct 10, 2006 at 20:01
Thanks for the follow up Mal. I had an interesting phone conversation with a dealer today, I rang about a traded 2004 Golf Linwood and asked him why I should consider this ahead of a Geist LV535. He could not give me any logical reason to take it ahead of the Geist. He indicated I would need a Landcruiser or Patrol to tow it comfortably and it was still two bunks short and had a ball weight of 275Kg versus 100Kg. He was European and explained that electric brakes are illegal in Europe (interesting!) and are useless on icy roads.
The heavy chassis suspension so popular here was discontinued in Europe in the 60's in favour of monocoque construction, just like it was with cars. So why is it still used here?
We have read a couple of the local Geist reviews and they are certainly very positive mainly for the reasons we like them...ease of towing, weight, interior design and spaciousness. Looking forward to hearing from you after your dealer meeting with Geist...regards RobnLiiz
AnswerID: 198630
