Site Search
Section Image
12v Set-up
Submitted: Tuesday, Oct 03, 2006 at 14:54
Member - Matt B (WA)
Hi All,
Need a hand/some ideas. I have a 97 80 series with a twin battery set-up. I tow a 17ft Coramal Seka van and want to set it up for extended stay's away from power. I have a chargemaster(O/L) battery charge controller. I have been told that if I add another battery to my caravan I will be able to charge this battery as well. What I would also like to do is this. I have a 1500w nominal, 3500w surge invertor that I want to mount in the van. Which when connected up to the car will have 2 battery's to draw off(Aux in car and Battery in van). Instead of getting a generator(as I already have the large sized invertor) I would prefer to get a petrol engine battery charger. Then when I am getting low on power I can just flash up the battery charger and all will be good. I was hoping to have some type of direct plug in arragement from the charger. Does anyone have any experience with a setup like this? Pro's or Cons greatly appreciated. Also has anyone used these chargers? I have seen the add for them in 4wd monthly.
Matt
Click Image to Enlarge
Ok I'll go first
Advertisement
ThreadID: 38228 Replies: 5
Views: 1109 FollowUps: 15
AnswerID: 197638   Submitted: Tuesday, Oct 03, 2006 at 15:20
Mike Harding replied:
If gen noise is not an issue then I suggest a cheap 2 stroke generator and a 2 or 3 stage 10A to 15A battery charger.
Mike Harding
Reply 1 of 5
AnswerID: 197639   Submitted: Tuesday, Oct 03, 2006 at 15:28
dj Patrol replied:
Why not just get a generator as they have 12volt set up and come with leads to charge your batterys also you did not mention about a solar panel which you will need ,Mabey you should talk to a Solar Expert or do some homework.
www.solaronline have a guide.
My Coromal Capri Van setup is,
All 12 volt in van lights,TV,led down lights,Fan,CD,
125watt Kyocera solar panel- Roof Mounted
64Watt Uni-solar panel backup-Portable
20amp Regulator
1x105 amp AGM Battery
Honda 20i Generator (runs anything in the van inc Air/Cond) as req
Reply 2 of 5
FollowupID: 456150   Submitted: Tuesday, Oct 03, 2006 at 15:37
Member - Norm C (QLD) posted:
dj, this may not apply to all generators, but I understand the 12V outlet on many generators is not good enough to charge batteries. I only puts out about 12.6 to 13 V, which is great for running 12 V appliances, but not good enough to effectively charge batteries.
It would be OK for running the charger through an inverter though, if you don't mind the inbuilt inefficiency. The other advantage is that with a gennie you have 240V if you need it.
New 70 Series and Kedron Van Oh What a Feeling
Not so Grey Nomads. Now travelling this great land full time, towing our home behind us.
Norm C
AnswerID: 197641   Submitted: Tuesday, Oct 03, 2006 at 16:07
RosscoH replied:
Hi Matt,
I have the (O/L) chargemaster controller in my patrol with second battery under the bonnet and 4 x 125a/h 6 volt batteries in the camper trailer, the batteries in the camper are coupled up into 2 banks of 12 volts and when pluged into the patrol are in parralell to the second battery under the bonnet, this setup works fine while driving and when set up I have 2 x 80 watt Solar panels set up with a regulator that plug into the plug that is normally plugs into the patrol. No need for battery charges or generators. Hope this helps.
Cheers RosscoH
Reply 3 of 5
AnswerID: 197642   Submitted: Tuesday, Oct 03, 2006 at 16:11
GaryInOz (Vic) replied:
Matt B,
The main issue I can see with trying to use the van battery and the vehicles second battery in parallel is thet you are going to be carrying some pretty heavy currents quite a distance (front of vehicle to middle of van), even then with the voltage drop at that legth the vehicles second battery would not be contributing much apart from heat in the strap to the van battery. At 1500 Watts and about 80% efficiency the total current draw would be in the order of 130 Amps.
A bit of a guide:
Site Link
you would be looking at 35+mm^2 (0 AWG) as an absolute minimum to carry the current
Reply 4 of 5
FollowupID: 456157   Submitted: Tuesday, Oct 03, 2006 at 16:36
Gary, I charge the AGM in my camper trailer in parrallel with the two deep cycles in my vehicle and it works fine. Unless the caravan battery was at the rear of the van, I don't think the run would be much further than mine. I ran 25mm squared double insulated welding cable through the chassis of the vehicle and through the draw bar of the trailer. Using my digital voltmeter, at worst I get .01V drop. The reason I say 'at worst' is it sometimes measures as zero voltage drop.
I used 175Amp Anderson plugs as the cable was much too big for 50Amp plugs. Also to handle the possible current draw as I set up to carry 2 x 120 AH AGMs in the trailer and they will take a high charge current if they are run down and it is available.
Norm C
FollowUp 1 of 14
FollowupID: 456168   Submitted: Tuesday, Oct 03, 2006 at 17:31
GaryInOz (Vic) posted:
"...at worst I get .01V drop..."
The devil is in the detail. How much current were you drawing at the caravan end when you measured your voltage drop???? Try flattening you van battery then meauring the voltage drop while the battery is charging (remember to measure both the positive wire and negative wire drops along the lengths of the cables). If you are not actually drawing any current along the wire you could get the same results from using a piece of wet string...
To the original question.
A bit of maths (sorry) from the site I quoted
135 amps x .73 mOhm/metre x 10 metres = 1 volt loss with 25 mm^2 cable at the full 1500 watt output of the inverter or 15% of the power lost in simply getting from a to b. This will lead to an unbalanced discharge of the batteries (van first)
FollowUp 2 of 14
FollowupID: 456174   Submitted: Tuesday, Oct 03, 2006 at 18:22
Member - Steve Y (NSW) posted:
I agree with every thing said about voltage drop, length of wire etc.... but one point not added to this thread is that you may want to consider a 24volt inverter as they wire length verse voltage drop is halved at a 24volt rate (Approx) The real interesting thing is that the plugs them self can add to 1volt of drop when they get hot so try to direct connected where possible. I know its a pain to move appliances if they are hard coded but the benefits to us for example were about 7 hours additional running time on the fridge.
Solar is getting there with a 65 watt panel (65 / 12 = Amps) or 5.41 amps for about 650$ maybe an option, two will be the same price as a good generator (No Air-conditioning though but you can run the fridge and a few lights and never have to start the generator. If all goes pear shaped then at a pinch you can run the car, not perfect but only diesel's have an issue with that.
Anyway there is some great info here so hope my two bobs worth helps
Steve
FollowUp 3 of 14
FollowupID: 456180   Submitted: Tuesday, Oct 03, 2006 at 19:06
Gary, I'm not going to challenge your maths. You are probably much better at it than me. Similarly I am far from an expert on 12 V systems.
In the interest of my continued learning, I'm prepared to take this discussion a touch further.
In real life nobody (that I know) constantly draws 135 Amps. I know I don't do it at all (other than cranking) as every fuse and circuit breaker I have is rated well below that level. I have never measured the current flow during charging, but I doubt the current going to my CT battery is often above 30 Amps and of course this drops as the battery gains charge. It can not be anything like 135 Amps as my alternator isn't capable of that (quite apart from the circuit breakers).
In discharge mode (which your calculation seems to be using), my fridge draws 5 or 6, add a couple of lights, occasionally the water pump, I suspect (but have not measured) that at most, I draw 10Amps, but more typically 5 or 6 (and 1 or 2 when the fridge is cycles off). Even using the limited data from the initial post, it will be only a fraction of 135 Amps.
Now to the resistance of the cable. The internet is notorious for the variation in answerers to questions, but my research shows that 25mm squared is close to 4AWG (4AWG is actually a bit smaller at 21.1mm sq) and it's resistance according to the site below is .000815 Ohms per metre, not .73 Ohms per metre. My run is around 8 metres, so by return length is 16m. Providing the site I have used is accurate, my cable resistance is less than .013 Ohms (my cable is thicker than 4AWG), not the .73 Ohms you have calculated,
www.bepmarine.com/PDF/Volt_drop.pdf
But more important than this to me is practical experience. When I go on an extended trip and return home, I put my batteries on my 3 stage charger. If I've had a long last day of driving, within minutes, the 3 stage charger goes to the 3rd stage. To me, this suggests they are at least 80% charged, which would be quite impossible with the voltage drop you suggest.
As always, this subject draws some rather diverse views. That's why, in the end I resort to real world experience. I'm happy that my system works far, far better than your calculation suggests is possible.
As far as the theory goes, I'm happy to continue learning so I can improve my system further over time.
Norm C
FollowUp 4 of 14
FollowupID: 456182   Submitted: Tuesday, Oct 03, 2006 at 19:17
"...that you may want to consider a 24volt inverter ..."
Not plausible unless you have a 24 volt alternator,(plus 24 volt solar panel?), and 24 volt battery, IN ADDITION to the 12 volt system he is currently running fo standard crank/running of vehicle, and existing 12 electrics in the van. Waaaaaaay too much hassle, better/cheaper/more convenient to carry a generator.
Best option is to use as many 12 volt appiances as possible (minimising losses throught the 12-240-12volt conversions), LED lighting wherever possible (very low power consumption - 3 watt led light = ~60-75 watt incandecent brightness), and minimizing 240 applications to those devices that have NO OTHER OPTION. This also means that you are not left high and dry if the (one and only) inverter packs up in the middle of nowhere. It also means you can get away with a smaller inverter, or even two smaller inverters for redundancy (better option than one big one anyway).
FollowUp 5 of 14
FollowupID: 456184   Submitted: Tuesday, Oct 03, 2006 at 19:26
Yea, agreed. However, running that many amps in a parallel config is going to drain the closest battery first as suggested I was thinking of this option for the the inverter only. To run a series configuration, 24 volt would possible limit that drain and while it would take some additional cable I think it would do the job. The idea of the 25mil welding cable is best though, especially with the l;long cable run. Many get that wrong.
Good pick up.
Steve
FollowUp 6 of 14
FollowupID: 456189   Submitted: Tuesday, Oct 03, 2006 at 19:43
PS. Two Batteries in parallel make 24 volts so two charged simultaneously at 12 volt is possible if you have enough amps in the alternator. Batteries running series make 24 volt. There are inverters that take that input.
PS you can weld with them as well if you cleaver, Looks a bit rough but I have done it (After removing the batteries from the truck though as hydrogen explosions weren't on the menu.
Again, the drain on a 24 volt system converting to 240 is more forgiving if cable length than 12 volt. It all depends on position, right ???
Generators stink, make noise and are banned in many National parks. Better to try and get around the need, Use Solar. Two 65 Watt panels @ 650AUD each are enough to run a lot of gear. You are camping after all, hopfully
FollowUp 7 of 14
FollowupID: 456194   Submitted: Tuesday, Oct 03, 2006 at 19:59
Norm C
Please read again, 0.73 milli Ohm (mOhm) per metre was what I said for 25 mm^2 wire. I will use your example of 0.815 milli Ohm per metre.
Your maths was correct and I will use the 0.013 ohm total resistance
The original question posted was about running an inverter, potentially at 1500 watts max., drawing off two batteries as equally as possible (would have to design for that for safety, given the potential for excess heat to cause a fire). Inverter uses 130 amps-> half that is 65 amp
I will use your lengths of wire run as a working example (seems to be the direction the original post was taking).
V = I x R
= 65 x .013 = .845 volts lost in the 16 metre run to power ("half") a 1500 watt inverter at full power, assuming equal load sharing. working it out further that equates to about 55 watts power dissipated in the wire as heat, ie one standard low beam headlight!!!
You will charge your battery in the van, but at a slower rate and probably not to 100% (effectively current limited by the resistance of the cables. By looking at the above equation it is reasonably obvious that if you are charging the battery at about 30 amps at the normal charging voltage at one end, you are going to get about 0.4 volt (ie. about half the above value - straight maths...) below what you would like at the van battery's terminals for a full charge at the other end of the wires (90-95% charged???).
FollowUp 8 of 14
FollowupID: 456195   Submitted: Tuesday, Oct 03, 2006 at 20:05
Steve Y,
Just wrong....
Two batteries paralleled up is still only 12 volts, but with the CURRENT CAPACITIES added ie 48 amp.hr and 60 amp.hr equalling a total of 108 amp.hr.
Paralleling the batteries is what you do when you jump start another vehicle, and you don't blow everything up by doing that....
One thing worse than bad advice is wrong advice.....
FollowUp 9 of 14
FollowupID: 456198   Submitted: Tuesday, Oct 03, 2006 at 20:08
Steve Y,
Ignore last post, I misread yours...::embarassed::
The original post was talking about using the van and vehicle 2nd battery paralleled, not two under the bonnet...
FollowUp 10 of 14
FollowupID: 456202   Submitted: Tuesday, Oct 03, 2006 at 20:20
Gary, You are right though and trying to set this all up is getting out of control. I wouldn't even try my own suggestion but it is real and I was just trying it relay that.
To every one else. Every one is right and it does depend on how you use your gear. I use a Gas fridge as a second fridge so my daily amp draw is low. We head out to Knowing for a week at a time with a drive here and there and it is all OK. The temps in Summery are 38c, the beer lives in the Waco as we all know that 3 Way fridges don't deal with that but you can get them low over night and limit opening and ------Well I'm out of breath.
FollowUp 11 of 14
FollowupID: 456203   Submitted: Tuesday, Oct 03, 2006 at 20:23
PS I meant Series as well. To many beers to write this... Sorry I confused every one. me included :-)
FollowUp 12 of 14
FollowupID: 456223   Submitted: Tuesday, Oct 03, 2006 at 21:33
Member - Matt B (WA) posted:
Thanks for all the constructive criticism. Maybe a petrol battery charger isnt the way to go. I havent had anything to do with solar before thats why I didnt even consider it. It sounds as if it will do the same job for around the same price. I will do some more reseach and have a look. Thanks
Matt
Ok I'll go first
FollowUp 13 of 14
FollowupID: 456241   Submitted: Tuesday, Oct 03, 2006 at 22:26
We all have reading problems tonight Gary. Missed the m in mOhm. Sorry about that.
Anyway, my system works well for me, but might not for someone else who has high curent drawing devices at the back end.
Enough confusion for one night I think.
Norm C
FollowUp 14 of 14
Activities Index
QDeck QDeck
Gold Coast - QLD
QDeck takes you to the highest point above the Gold Coast for stunning 360 degree views from the sur
Social Yacht Racing - Saturdays Social Yacht Racing - Saturdays
Sydney - NSW
An afternoon of fun and excitement on board a fleet of luxury yachts for the popular Saturday Social
Aerobatic Warbird Flight - YAK52 -  Archerfield Aerobatic Warbird Flight - YAK52 - Archerfie
Brisbane - QLD
Be a WW2 fighter ace, feel the thrill of high 'G' manoeuvres, looping and rolling through the skies
Day Spa Facial & Massage For Men Day Spa Facial & Massage For Men
Brisbane - QLD
Calling all men in need of pampering - it's time to be spoilt!
Book Now - Things To Do
AnswerID: 197759   Submitted: Wednesday, Oct 04, 2006 at 10:08
LastAussieWorker replied:
mate if you want to set it up for extended stay's away from power then learn from others that have done it
trying to stay charged and pumped up with generator is hopeless
many places dont allow generators and if other campers there can cause problems
cost me a lot to learn along the way
now have solar. started with 1 85w panel and new van fitting 3 85w panel
man just love that solar power
Reply 5 of 5
