gear oil
Submitted: Tuesday, Oct 03, 2006 at 22:03
ThreadID: 38242 Views:4920 Replies:6 FollowUps:4
Want to change Transfer, gear box, front & rear diff oils in my 04 3 ltr turbo diesel Hilux. Had a look at archives. Seems that some recommend Catrol VMX. Castrol site suggests Multitrax.
Anyone have anything to recommend?
Reply By: cowpat - Tuesday, Oct 03, 2006 at 22:16
EPX 80/90 in the diffs. Syntrax 75/90 for the gearbox and transfer, or VMX if you can't afford/justify Syntrax. I wouldn't use VMX, Multitrax or Syntrax in the diffs. Others will have different favourites. Casper
AnswerID: 197712
Reply By: Jimbo (WA) - Tuesday, Oct 03, 2006 at 22:32
Twinkles, go to Castrol and on the left hand side go down to "Toolkit" and "Lube Guide" and then find your vehicle.
Mobil and other company's have a similiar service if you want to try other brands.
Hope this helps,
AnswerID: 197714
Follow Up By: Member - Peter H (NT) - Wednesday, Oct 04, 2006 at 12:08
G'day Jim,
I did alot of homework on the vehicle that would suit us for our retirement. I settled on 100 series L/cruiser. My brother-in-law was visiting us up here in the territory and he convinced me to regulary change the engine oil, which I'm now doing. Reading this forum has brought to mind wether I should attempt to change gear box oil, and if so is the process difficult or could I feel confident with trying to do it myself?
FollowupID: 456327
Follow Up By: Jimbo (WA) - Wednesday, Oct 04, 2006 at 13:16
Peter, doing your own gear box oil-change is not hard - but can be messy if you don't get it right. All you need to do is find the drain bung on the bottom of your gearbox, and the filler plug which should be about halfway up one side and make sure you have a correct fitting socket or spanner to fit. (A tip - always undo the filler plug first; that way if you can't get the drain plug undone you have no immediate problems - as opposed to the other way around).
You can purchase a drain pan (or use a cut down 20ltr oil drum) and filler from places like repco etc.
It's handy to have the workshop manual so you know quantities etc, but not necessary.
I do my own gearbox, diffs, transfer case and engine oil changes to a regular schedule so that at least I have peace-of-mind that all the basics have been done, and done properly - unlike most services with Toyota!
FollowupID: 456332
Follow Up By: Member - Peter H (NT) - Wednesday, Oct 04, 2006 at 17:14
Thanks Jim,
I'll print this off and put it in my owners manual.
Thanks again mate.
FollowupID: 456370
Reply By: Member - Phil G (SA) - Tuesday, Oct 03, 2006 at 22:35
Yours has the same R151F gearbox as the Prado and 1Hz LandCruisers.
The cold changes are not good with Multitrax - I used it once for 5000k on a 2002 Prado, and had to change it.
The other options are better - I've used Valvoline Duratrax 75/85 ever since and its been good. In Castrol, the VMX-M is supposed to be best.
AnswerID: 197715
Reply By: Member - Doug T (W.A) - Tuesday, Oct 03, 2006 at 23:47
Try this one
www.fuchs.com.au/html/localnonflash.html
www.datateck.com.au/lube/fuchs_au/
AnswerID: 197728
Reply By: Member - extfilm (NSW) - Wednesday, Oct 04, 2006 at 08:36
Twinkles,
How about simply go to toyota and get the oil they sell???????????? That way warranty will not be void because of a foreign oil..... Its simple really. I serviced my hilux myself throughout the warranty period and never had a problem fighting for warranty repairs because I used oils purchased from Toyota. The gearbox was repaired during warraty as well.
AnswerID: 197748
Follow Up By: Member - Phil G (SA) - Wednesday, Oct 04, 2006 at 10:15
Just curious as to why did you gearbox need a repair under warranty?? Are you suggesting Twinkes use the same oil as you did???
I agree with you about buying manufacturers oils can be a good move - I've done that for years with Nissan. But with Toyota, you have to be a little careful - their diesel engine oil for example is 20W50, which is thicker than you want for a 1KZ-TE. Also, the workshop oil they use is invariably different to the stuff in the spare parts dept.
Problem with gearbox oils is that cold shift problems are common with this gearbox when you use many of the recommended oils. Theres been many a gearbox repair done because of poor shifting, when all that was required is a different oil.
FollowupID: 456307
Reply By: Member - extfilm (NSW) - Wednesday, Oct 04, 2006 at 10:41
Layshaft bearing went on it, Which I have since heard happens every now and then with that model. It was an 03 model. It is not a common problem but I now have a nissan and hope that I do not have to do any warranty work on that. I only keep my cars for 100 000ks. Got the nissan 3 mths ago and have already 20 000ks on it.
AnswerID: 197765
