FollowupID: 456484 Submitted:
Thursday, Oct 05, 2006 at 10:13
Member - Andrew (QLD) posted:
Peter, where exactly is this information incorrect? Back up your statement with facts! I have provided the link in good faith as i have found it an easy way to explain some of the basic concepts of water evaporation without baffling anyone with complicated formulas/tables.
Take away the fact that it is from a Pool Cover supplier, what is wrong with the info as you seem to have more knowledge that i'm not aware of. I never pushed the fact that you need a pool cover, i don't even know the business, just read the data and find the incorrect info......
I would be very surprised if you had a net evaporation loss of 100mm per year unless you live in a rather wet area. Highly unlikely to be the case in most
places in Qld, especially in these dry times.
As far as i know, the Qld Government wouldn't have "implemented compulsory pool covers", rather it be the Local Councils, as it is not compulsory where i live up North.....Do you have reference to where these "sources" knock figures. I am unable to recall such an instance, even though it may have been the case.
For the record, i own a 10m x 5m x 1.2m concrete inground pool in Mackay which will evaporate an average of 25-50mm per week in the months from around Nov-Mar (not taking into account rainfall).
Norm C, how does your solar heating system work? I would have thought that they have a cutoff/shutoff valve or similar to stop the system overheating the pool. I know that my system use to have a electronic controller which would bypass the heating pipes at certain temperature differentials. Yours may be different :-)
 Click Image to Enlarge |
| It may be that my sole purpose in life is to
serve as a warning to others!
