First Biodiesel Tank
Submitted: Thursday, Oct 05, 2006 at 19:13
F4Phantom
I just got my first
tank of B100 today. I knew it would not harm the engine & have less power but thats about it.
Well so far the power is the same, but there are some amazing side effects. Mainly the lubricating qualities of the stuff. The engine is so quiet and smooth now. At 60km/h in 3rd gear it used to feel like the engine was going to explode, but I took it to 70K/h and it was smooth, balanced and quiet. Amazing. I feel like the engine is having a good time drinking the stuff and my opinion is that it is being cleaned out too. It seems a little looser and therefore also feels like it has more power. The engine temp guage is also lower but I wont attempt to understand why. So anyway, cool as.
Reply By: Member - DOZER- Thursday, Oct 05, 2006 at 19:49
Be aware...that all the gunge in your tamks will get cleaned out with this and subsequent tankfulls, so when power does deminish, change the filter...it will block up doing as it should....now would be a good time to get an adapter and some CAV filters@ $7 each :)
197985
Follow Up By: Trevor R (QLD) - Thursday, Oct 05, 2006 at 19:59
Beat me too it D, I was about to say I hope you have the spare filters ready. But after that it is all good from what I hear.
Sadly I have just gone the other way, bought a car running on b100 and have had to run it on normal diesel since I bought it and I can notice the difference. Now black smoke and I consider it to have less power than when I first bought it :-(( So that's a big vote of confidence on my part for the b100.
Cheers, Trevor.
456556
Follow Up By: Member - Jeff M (WA) - Friday, Oct 06, 2006 at 10:03
Yeah I've heard that, but I've done nearly 20,000kms on straight B100 and only just changed the filter the other day (only because it was due, no other reason).
456653
Follow Up By: Zapper - Friday, Oct 06, 2006 at 13:28
Member - Jeff M (WA) where do you get your 100 % BioD from in WA? Are you in
Perth?
456681
Reply By: F4Phantom - Thursday, Oct 05, 2006 at 20:06
By way of information and interest
crops diesel (canola, mustard) generally get 8% less range than dino diesel (provided you have a perfectly tuned engine)
and cow juice tuned into diesel (tallow) has more power/range than dino diesel.
In my case I would have loved to use a dB meter before and after, and I think the freeing up of the engine is adding to lost power over the years. It seems as though the fossil diesel really does lock the engine up with crap.
197992
Follow Up By: F4Phantom - Thursday, Oct 05, 2006 at 20:08
www.melbournebiodiesel.org/
456558
Follow Up By: Member - Jeff M (WA) - Friday, Oct 06, 2006 at 10:05
I'm not sure where their figures for an 8% decrease is... I got an improvment after I reset my ECU as BD has a higher cetane level. (the equiv. of higher octain in ULP). Perhaps the 8% decrease is for engines that have not been tuned for it and or are in colder climates.
456654
Reply By: Member - Cruiser (NSW) - Thursday, Oct 05, 2006 at 20:32
What I want to know is what effect is there on the vehicle if you start using biodiesel whilst driving locally where there is a good reliable source, then suddenly have to resort to fossil diesel if biodiesel isnt available whilst travelling.
Can you alternate between the 2 sources without any ill effect or do you have to carry spare fliters and keep changing them.
I dont have any biodiesel outlets anywhere near me and would love to try it, but am not prepared to try a
tank whilst in the big smoke if it means that I have to go to the expense of a new filter cause it flushes out all the gunk in my system. This cost (if necessary cause of 1
tank) would not seem to be very economical to me, or have I got it all wrong.
197998
Follow Up By: F4Phantom - Thursday, Oct 05, 2006 at 20:37
I think once the engine is reasonably clean it would not clog up for a while. Switching would not present any problems. I have only this one
tank and no reliable source either but will be getting it as much as possible from here on. The guy who gave it to me wacked a sticker on my rear window saying "I prefer Biodiesel".
Well after getting home in the car tonight I now agree with the sticker, but I cant always have it.
456565
Follow Up By: Member - Cruiser (NSW) - Thursday, Oct 05, 2006 at 21:11
How many tanks of biodiesel would you expect to use before the filter would need to be changed.
I am off next week to Qld to pick up my new van and was thinking that I might try a
tank whilst up there and then fill up for the trip home. If the cost of flushing out the system is 1 fuel filter then it might be worth it, but then due to no reliable source locally I would have to go back to fossil diesel.
456575
Follow Up By: F4Phantom - Friday, Oct 06, 2006 at 08:50
I would say the first full
tank will produce the most sludge and then it would tail off quickly. I cant see a problem with one
tank, change your filter and then it should be ok. If the stuff is cheap you could do what I am doing and get a few pastic tanks and take some with you so you at least get a good run instead of only 1
tank full. I can get it at 200L a time. I even know one guy who takes around 200L in his diesel pug to travel interstate as its a BD only vehicle.
456646
Follow Up By: Member - Jeff M (WA) - Friday, Oct 06, 2006 at 10:06
A couple of times over the last 6 months I have had to stop ont he way home from a trip at put $20 bucks of dino diesel in, no effect whatsoever, you'd never know the difference other than the black smoke instead of white smoke when you turn the key.
456655
Follow Up By: Member - Andrew W (SA) - Friday, Oct 06, 2006 at 11:36
one thing to watch is that because this is a solvent process, the higher the temp the more effective the "cleaning".
Consequently, run it for a long time on a hot day or very hot day is going to clean more out ... so wait until you have a hot day before replacing your filter.
Andrew.
456666
Follow Up By: Member - Cruiser (NSW) - Friday, Oct 06, 2006 at 12:07
I was thinking of filling up in
Brisbane (seems like there is only 1 outlet selling Biodiesel in
Brisbane) and then again about a week later when I am bringing my new van home (about 550K) and then changing the filter when I get home.
Just in case it needs replacing on way home, I will carry a spare.
Hopefully a
tank and a half will do the job.
456671
Follow Up By: Member - Andrew W (SA) - Friday, Oct 06, 2006 at 12:32
Usually a few tanks would be necessary at least, to really get most of the gunk.
If you're carrying a spare (in case it does clog up) and you have no need, I would wait until I had done a few hotter weather tanks.
Andrew.
456673
Follow Up By: Member - Cruiser (NSW) - Friday, Oct 06, 2006 at 12:35
OK, thanks for the info, will give it a go.
456674
Reply By: hoyks - Thursday, Oct 05, 2006 at 21:08
It's no problem at all. I chop and change al the time with no issues.
198006
Follow Up By: Trevor R (QLD) - Thursday, Oct 05, 2006 at 21:28
What, no changing filters going from bio to normal diesel?
How long do you run on normal diesel before going back to bio?
My understanding is the "normal" diesel puts crud on the inside of fuel lines and then the bio comes along and cleans it out again, but this crud ends up in your filter. maybe it takes years of "normal" diesel to build up enough crud to be of problems when changing between the two fuel sources. If so I may be able to try bio in my GU after all??
Good reliable source of b100 in Willow Tree (1/2 way Bris-Syd), also good reliable source up here in Brissy but nowhere else to my knowledge and I travel all over the east coast regularly so I would have to go between the two fuels if I went the bio option.
Thanks for any info you can give me.
Trevor.
456576
Follow Up By: Member - Jeff M (WA) - Friday, Oct 06, 2006 at 10:07
Nah the "sludge" is normal from YEARS of build up, not a couple of tanks here andt here. You will have no problem whatsoever mixng, matching and swaping BD with DD.
456656
Reply By: hoyks - Thursday, Oct 05, 2006 at 21:44
I buy
mine 300L at a time from a plant in Maitland.
Caltex is going to start selling it in
Newcastle soon (announced on the local news this week) but I think it is going to be a 2 - 5% blend.
And yes the gunk is a build up over time so it's not like it reacts and makes gunk out of nowhere or gunks up in a matter of weeks.
I first started running it in the Terrano after I had owned it for 2 years and didn't have any problems with filter clogging, but changed it 5000km later anyway. I also fitted a CAV filter before the factory filter to save a few $$ on filters.
198012
Follow Up By: Member - Jeff M (WA) - Friday, Oct 06, 2006 at 10:09
pfft, 2-5% why bother! At least Gull over here are doing B20 at the bowser. Personally I stick to the B100 as long as it's chepaer (it's getting close at the moment to the Gull B20, paid $1.25 per litire at the Gull bowser to top the tank up before my next delivery of B100 arrives. B100 is only about 5cpl cheaper at the mo.
456657
Follow Up By: F4Phantom - Friday, Oct 06, 2006 at 18:57
In terms of using less fossil your right, 2% is a crap idea. But I think it punches above its weight level in emissions. I haveent got a source but something I read once seemed to say that adding a little bio reduces emissions for example by 20%, way above the 2% added. I think it could have been higher than 20% tho. Still I cant see a lot of value, I think B50 minimum.
456746
Reply By: Member - TonyG (Qld) - Friday, Oct 06, 2006 at 10:10
Does anyone know if it is available in Brissie, or more specifically the Redland Bay area QLD?
TonyG
198066
Reply By: Barty - Friday, Oct 06, 2006 at 15:56
look at what i found any one in oz doing this " target="EOF" class="lbg">www.homebiodieselkits.com/hobikit.html
198094
Follow Up By: Tim HJ61 (WA) - Friday, Oct 06, 2006 at 23:58
Barty,
There are lots of BioD homebrewers in Oz. This site isn't the best place to find them, try this link instead for a start. Site Link
This link shows someone in
Perth with a similar setup to the link you gave.
Site Link
Tim
Running on new or used Vege, BioD 100%, Dino at a pinch - whatever makes it go.
456804
