2003 Prado Interchangeable rims
Submitted: Thursday, Oct 05, 2006 at 21:32
ThreadID: 38295 Views:1787 Replies:2 FollowUps:2
A couple of years ago I was forced to buy a second (spare) steel rim for a 2003 Prado. The reason for doing this was:
1. Couldn't afford another Mag.
2. Toyota, at that stage were the only source of 17" wheels.
Back in May/June of this year I had to use the second spare. In doing so, it became evident the nuts will not fully secure a steel rim. This is because the alloy designed nuts are not compatible with steel rims.
Therefore, if your in a similar situation, it's very important the nuts are checked at least three times within the first thirty minutes (particularly of rough and corrugated roads).
Also be aware that the rubber surrounding the front CV joints is subject to damage if the vehicle is used in very rough country.
Kim
Reply By: HGMonaro - Thursday, Oct 05, 2006 at 21:53
that's the situation with most alloys and steel rims, different nuts... pity someone didn't warn/advise you before having to have to use it.
AnswerID: 198017
Reply By: Muddy doe (SA) - Thursday, Oct 05, 2006 at 23:08
Yes I had the same situation on my Prado.
The factory alloys come with a flat faced nut and when I bought a set of ROH aftermarket alloys I found that the nuts were different and they require a tapered face nut. So I went of back to the place that sold me the wheels and politely asked why they did not check this out for me during the sale.
They apologised and promptly supplied 24 chrome capped nuts with the correct taper free of charge. I am all happy again but it does mean i carry two sets of nuts now as I use one of the factory alloys as a second spare.
Muddy
AnswerID: 198028
Follow Up By: ZUKSCOOTERX90(QLD-MEMBER) - Friday, Oct 06, 2006 at 06:11
That must be very difficult,having to carry around two sets of nuts.Where do you put them? :)
heer's Bob.
FollowupID: 456624
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Oct 06, 2006 at 06:49
Now days he knows they have to close enough to use em. No good just having a pocket for them ;-)
FollowupID: 456632
