GQ patrol hoses
Submitted: Friday, Oct 06, 2006 at 09:37
pedro the swift
Hi all, great
forum.
Just wanted to impart so info.
Just replaced all the small
water hoses on my 1990 GQ patrol(4.2 petrol auto). Have been losing 1 or 2 cup fulls of
water every trip. Noted that the hose under the carby had some evidence of leaks so decided to bite the bullet and replace them all.
I had been putting it off because I had visions of me having to remove the inlet manifold to get at the connections etc.
Finally decied I could stall no longer and removed carby and found that by removing crankcase breather fitting Icould get at most of the connections.
Well after a lot of struggling underneath the carby (working by feel) I managed to remove the old hoses and check the connections for corrosion. All seemed ok so I replaced the hoses (all 3) and installed new hose clamps(the jubilee strap type, I dont like the double loop originals, they tend to cut the hoses).
All went back together. Refilled radiator with demin
water and looks ok. I wiil reflush and refill with demin
water and inhibitor at next opportunity(tonight?)
Note: you dont have to remove the inlet manifold to replace these hoses, as long as the steel fittings are ok( not corroded)
Use only distilled or demin
water and flush a couple of times if changing from tap
water etc. I use 4 ltrs Castrol anti-boil,antifreeze with inhibitor to give 50% concentration. This was recommended to me by a friend who knows his chemistry and says this will help prevent corrosion in the mixed metal cooling system.
Reply By: Trevor R (QLD) - Friday, Oct 06, 2006 at 21:29
Hi Pedro,
welcome to the site, can I presume you were having heating probs or was this just done for a maintenance reason to stop the
water loss?
If it is a bugger of a job and it was to save
water loss then there is also a sponsor on this site selling low
water alarms in case you forget to refill one time, could save you plenty if you are a tad forgetful like me LOL.
Cheers, Trevor.
198150
Reply By: pedro the swift - Saturday, Oct 07, 2006 at 22:54
Hi Trevor,
No overheating, just
water loss nearly every trip to town. Although I did a run to Rocky and back with no problems. Eventually decided it needed attention before it really lost the lot.
It was actually easier than i first expected but still a bugger to do.
I have looked at those
water level alarm sytems and may fit one or design one myself. I will see if I can make something up that uses the existing temp sensor to set off an alarm on overheating.
Its interesting to note that loss of coolant is the biggest killer of engines ever yet very few(if any) cars have both alarms and gauges fitted for
water level and temp. Should be standard equipment on all vehicles.
As an aside, whats the biggest killer of nuclear power stations? Loss of coolant! as per Chernobyl, Three Mile Island and others over the years.
198256
