GQ - Mav ** Idler Pulley
Submitted: Friday, Oct 06, 2006 at 20:37
Maddmav
I have just gone through the a mamoth effort to replace the idler pulley on the Air/Con drive on the Mav 4.2 Oiler
I got a price from "Genuine Part" and woke up an hour later after telling me the pulley is $320.00 complete or I can buy the bearing only for $34.50.
I ended up getting one of the shelf (same part identical) pulley & bearing complete at a bearing
shop for a more breathable price of $22.80 - Ol` Mate says he sells heaps of 'em (wonder why).
Now this is the grooved pulley type not the roller type - thought I would clarify that.
The adustable shaft broke (too much kellogs) when fitting - so I had to go "Genuine Part" here and had to pay $77.95 for shaft & nut as bolt shops don't sell them and was told it would hve to be specially made - they know how to get ya.
A note for anyone doing this repair:
The "Geniune" shaft is shorter than original (oops Mr Ford)
The nut will not fit back into the pulley without some machining of the retainer bush
Here I had to counter-
bore the retainer bush to allow
the nut to fit inside.
10mm counter-
bore of the retainer bush is enough to allow
the nut to nip up on the pulley bearing.
Started Monday - Finished Friday (an hour ago)
All back together now and no screeeeching!! and running much quieter
Vinnie
Reply By: Willem - Friday, Oct 06, 2006 at 21:12
Yeah I bought a pulley through a friend who got it from an airconditioning mob for $31.00 including freight. The pulley had seized on the shaft but I managed to remove the shaft and fitted it all back together again. My truck is a 94 model Datto. Didn't know there was an issue with the shaft.
198147
Follow Up By: Maddmav - Friday, Oct 06, 2006 at 21:16
Only if you use too many pounds with the spanner
456777
Reply By: Member - Jeff H (QLD) - Saturday, Oct 07, 2006 at 01:42
Maddvac, (or Vinnie, whatever comes first)
Bleep buddy, you went through all that bleeping bleep, and you still didn't bleeping swear.
Congratulations. And more praise to David and his Boss for keeping this site clean.JH.
198165
Follow Up By: Maddmav - Sunday, Oct 08, 2006 at 18:26
Oh there were a few Bleeps on the job Jeff. SWMBO had to close some doors and windows as
well as wear ear plugs. LOL
456937
