NISSAN 2001 4.2 TD - Gear box problem
Submitted: Saturday, Oct 07, 2006 at 18:07
Member - Prickle (SA)
Have a mate who has above vehicle and when motor is running and in neutral, gear box rattles, very noisily. Has only done 87,000km, however have done a fair bit of towing - caravan and some off road.
Nissan say that they have had no problems with the gear boxes for these vehicles.
Reply By: ACDC - Saturday, Oct 07, 2006 at 18:21
Prickle,
The clutch plate centre may be loose, but other than that it's normal.
198223
Reply By: DMH122 - Saturday, Oct 07, 2006 at 20:29
Its known as roll over noise, as far no problems with these gear boxes they did have a 5th gear issue.
198236
Reply By: Trevor R (QLD) - Saturday, Oct 07, 2006 at 21:51
Russ,
Nissan is LYING !!!
I've just rebuilt
mine (2000 model) with an almost flogged 5th ready to let go at the most inopportune time (as they do). Tell your mate to keep an eye on the colour of the gear oil. If it turns rusty brown he's in the poo and it's time to think seriously about how much he loves the truck as he won't get out for less than about 2 and a half to 3 grand for the rebuild plus a clutch if need be. This oil discolouration is common with most that have the 5th gear failure. Other than this and the running hot issues it is a great truck and very predictable in every situation.
Regards, Trevor.
198242
Reply By: Bilbo - Saturday, Oct 07, 2006 at 22:48
Prickle,
If it rattles in neutral, then rest assured it is NOT 5th gear on the way out.
My old Ford Maverick used to do it and it carried on doing it for years. It's something to do with the drive to the transfer case, but I'm not sure what.
Just ask yer mate to stomp on the clutch pedal real hard a couple of times and it should disappear.
But as Trev says, rusty gear oil and heavy towing with some of the post 1997 gearboxes didd result 5th gear stripping the mainshaft splines. Poor heat treatment and lack of lube to the gearbox mainshaft was the prob.
But this prob don't sound like 5th gear prob.
Bilbo
198255
Reply By: fisho64 - Sunday, Oct 08, 2006 at 00:55
quite likely to be input shaft bearing
198258
Reply By: dj Patrol - Sunday, Oct 08, 2006 at 18:44
A damm tough box to flog out mate they are built for trucks and are really tough.
mine is also a bit rattly has done 110,000 towing most of them a 2.5 ton van.
But drives nice and quite and has a good gear change so.
198310
Reply By: Member - Prickle (SA) - Tuesday, Oct 10, 2006 at 00:30
Thanks everyone for your responses, have passed them on for him to ponder over.
198480
