salt in ice blocks
Submitted: Sunday, Oct 08, 2006 at 20:01
tojo
Goin fishing soon and have to make some large ice blocks, i've heard adding salt to the
water will make it last longer.Any one know how much to add before l start using all the bosses salt from the pantry. thanks tojo
Reply By: ferris - Sunday, Oct 08, 2006 at 20:19
Hiya Tojo,
Adding salt to
water lowers the freezing point. The old timers used to say that sprinkling salt over the ice made it last longer, I don't know if it was true or not, but certainly the oldies used to swear by it. I guess it's a case of knowledge lost to a bygone era.
Keep the shiny side up.
Ferris
198319
Follow Up By: Member No 1- Sunday, Oct 08, 2006 at 20:27
i'm gunna keep out this...being a fridgie and all
but i do this
freeze my own
water ...reason...bought ice is around -12 at best?...but freezing your own in a good freezer will get it down to around -20 or more
check the archives on this
forum...for more knoweldgeable advice for this subject from myself
456959
Follow Up By: Footloose - Sunday, Oct 08, 2006 at 20:53
Geez no 1, I thought you knew everything about cold comfort :-)
456966
Follow Up By: Member No 1- Monday, Oct 09, 2006 at 07:19
ahh yes ...a cold shoulder? what do you want to know...
457008
Follow Up By: michael & lisa - Monday, Oct 09, 2006 at 18:38
Puting course salt on your ice will lower the temp to freezing watch your xxxx gold and any other food in the eski or it will freeze to
457115
Follow Up By: Member No 1- Tuesday, Oct 10, 2006 at 08:00
adding salt to ice DOES NOT lower the temperature of the ice
we all know that adding ice to
water lower its temp....remember, standard
water freezes at 0c. and ice melts at 0c
....... if you add salt to
water you have altered its freezing point... it becomes lower... say -10c...and therefore its its melting point (once frozen of course) is also -10c (this temp depends on salt qty) ....
applying this to a freshwater ice slurry where the ice was at say -20c the ice will now begin to melt when the
water temp reaches -10 c (or higher of course)instead of std temp of 0c
adding salt to
water which has a satisfactory/suitable quantity of ice in it will lower the temperature of the
water content only.
457187
Follow Up By: Footloose - Tuesday, Oct 10, 2006 at 08:36
Perhaps some are confusing adding salt to ice with adding salt to boiling
water ?
457189
Follow Up By: Member No 1- Tuesday, Oct 10, 2006 at 08:53
i have no idea what they think footy
457190
Reply By: Ianw - Sunday, Oct 08, 2006 at 22:23
Commercial fishermen make a slurry by adding ice to seawater. It keeps the fish at a temperature below freezing but not frozen, ie fresh. Adding salt to ice does indeed lower the temp but I think you will have trouble freezing salt
water.
198344
Follow Up By: PatrolBen - Monday, Oct 09, 2006 at 10:49
Totally off topic but when I worked on the boats we had a 3.5 cubic metre capacity brine
tank which was filled with sea
water, we chilled it down as far as it could go and just kept dumping salt in it until we got the temp down to around 14 below ( at which it was still liquid). Crate of prawns go in, about 60 seconds in and are snap frozen as if they were doused in liquid nitrogen and then into a big freezer and off to the markets on return to port. A chemical was also added to the ice to prevent the flesh rotting but cant for the life of me remember the name.
The problem with freezing seawater (for eskies) is that whilst ity may freeze at a lowert temp it will also return to a liquid at a lower temp. Every time I've gone up
the beach I take four 3 litre frozen milk bottles (with
water in em :) in a 90 litre down under esky add seawater (1/3 full) when arrive and keeps bloody cool for around four days. However the fish do not sit in the
water but are put in ziplock bags and then dropped in as submerging them in an ice slurry for a few days would not be a wise move as they would bloat up and go mushy. Keep them dry but cold.
457027
Reply By: slammin - Sunday, Oct 08, 2006 at 22:45
Tojo, Aaah an interesting and much often debated question by chefs.
We have our display trays or ingredients loaded up on ice and some prefer to sprinkle salt over the ice, it initially melts the ice then quickly refreezes turning the crushed ice into a solid conglomerate. Basic thing to remember is that it melts the ice....
After many vociferous and heated debates we timed it with salt and without, the unsalted lasted considerably longer. NB picture the red faces at the bar buying beers!
As to wether salted frozen
water will last longer, salt
water needs a lower temp to freeze so therefore the converse applies, it will also melt earlier than
water.
I beleive this theory is proven : in colder climes than ours where salt is spread on paths, roads etc to melt the ice.
: by the ocean, when it does freeze, (pack ice etc) the concentration of salt in the frozen particles is less and resulting unfrozen now saltier ocean
water drops lower in the ocean creating a cycle of currents.
: in a salted ice cream I tred to make last month that i couldn't even get to freeze!
I'd be very interested if you find otherwise.
198350
Reply By: fisho64 - Sunday, Oct 08, 2006 at 22:56
frozen salt
water is difficult to keep "solid" and tends to get slushy when thawing. We used to use either for chilling longline tuna and swordfish. But if you make a saltwater slurry with saltwater ice, the temp will be around -4, enough to freeze the extremities of a tuna and the Japs would devalue the fish as they take samples from the tail area for inspection.
A slurry made with freshwater ice, the ice stays solid til thawed. Saltwater ice it slowly goes slushy.
198353
Reply By: Member - extfilm (NSW) - Sunday, Oct 08, 2006 at 23:02
Hey Tojo
A funny question this one.....
In Canada they use a mixture of gravel and salt on icy roads to melt the ice and give extra grip
198354
Follow Up By: Member No 1- Monday, Oct 09, 2006 at 07:26
salt
water freezes at a lower temp than fresh...hence salt
water melts at lower temp than fresh
water...its very simple really.... aint it
the extra thermal storage of the sea
water and ice mass is not worth worring about compared to benefits of using fresh
water for ice..eg you can drink it if need be
457011
Reply By: Member - Duncs - Sunday, Oct 08, 2006 at 23:55
I have one of those wine cooler type eskies. It has space for 4 bottles of wine seperated by shaped containers that you fill with
water and freeze to keep the wine cold.
One of my brothers intelligent friends has the same esky. He used to put salt
water in his on the basis that it froze colder and therefore kept the wine cooler for longer.
I fill
mine with fruit cordial (cottees, golden circle etc) as the cordial melts it provides an icy cold drink for the kids. It still keeps the wine
well and truly cold enough for me.
I figured that if you fill it with salt
water it's useless when it melts and the temp differences are so minimal that in reality they don't matter
That's my 2c worth.
Duncs
198358
Follow Up By: Member No 1- Tuesday, Oct 10, 2006 at 09:03
eh?.."He used to put salt
water in his on the basis that it froze colder"..???
Stick 2 identical buckets of
water in the freezer...add salt to one...as much as you like.
measure the temp of each as they pull down to temp....they will both be at same temperature...and i dont care how long you leave them in there..they will both be the same
once in an esky the ability of each bucket to maintain its temperature over time is not worth worrying about......but refer to above for ice slurries in a esky for beers around the BBQ...but this is not practicable for extended excursions in the bush
457192
Reply By: Bware (Tweed Valley) - Monday, Oct 09, 2006 at 01:48
It's one of the great mysteries of life LOL
I don't know about freezing salt
water, but I have added salt to ice twice with interesting results.
The first time was on Christmas day a couple of years ago. An average size esky, beers, ice to cover and loads of salt. No idea how much but it was our first attempt after hearing the theory. At a guess; 500gms. The next day, after an overnight low of about 25c or more, the ice had become one solid block that had to be broken up to access the beers.
The second time was just recently while in
Tenterfield and Glen Innes. I had put 500 gms of salt over 5kgs of ice in a 95L ice box. The ambient temperature over the next few days was between 5c and 15c. The ice turned to slurry but still solidified in clumps. We had vegies in a large tupperware container to keep them out of the water/ice and we had to throw some away because they froze! Also some things in jars etc in the slurry froze, like yoghurt, jam etc.
I've never experienced this before. The ambient temperature wasn't blow zero.
There is no way a slurry of 'normal' ice will freeze things.
Not a scientific experiment, draw your own conclusions.
198360
Follow Up By: Member No 1- Tuesday, Oct 10, 2006 at 09:10
"There is no way a slurry of 'normal' ice will freeze things" true.....
but really cold ice in enough quantities will!...try it...fill to the top a good esky with ice from your freezer.....not commercial bought crap...from your frezer which should pull it down to better than -20...it will freeze your a beer or two....wont crack it ( i havnt been able to yet) but it will freeze
457193
Reply By: Robin - Monday, Oct 09, 2006 at 06:48
Hi Tojo
I wouldn't rip into the bosses supply , salt costs so little in big bags these days.
Some swimming pool salt from supermarkets is down to $6 for 25kg.
Everyone agrees that adding salt lowers the temperature that the mixture freezes at and this offers the potential for it to last longer provided you put the cold energy in first (I.E. you actually freeze the mixture in your fridge).
But - never use it myself though as that's not really the mission.
My mission is instead to keep the food fresh, and the key point about ice / dry ice and various mixtures is that the cold energy is nearly all concentrated around the mixtures freezing temperature.
So if its ice this is zero , and if salt ice it might be -15c (depending on concentration). Dry Ice around -70.
So if I put my lettuce/ tomato's in a esky at zero they will survive without damage.
If I put them in salt ice esky at -15c they will be damaged etc.
This is the crucial point - even if I freeze a
water ice block to -15 in fridge if does
not hold a lot more cold energy than if it was at -5 and will rapidly come up to
it nominal freezing temperature 0 and then be safe for the food I need to keep fresh.
Robin Miller
198366
Reply By: rolande- Monday, Oct 09, 2006 at 12:10
G'Day Tojo,
Been through all this, not worth the effort. Best bet is to find the size container you want and freeze this as low as it will go. Out of interest, if you pack some of those techni-ice type packs around the container in the freezer you can actually get it to go lower than the freezer setting itself.
Cooling efficiency occurs at "phase change", that is how your fridge works, compressor changes gas to liquid, as liquid turns back to gas, cooling occurs.
So, in your esky, put in the size blocks you want. As the ice in the containers turn to
water put the
water in with your favourite scotch, boubon, etc and enjoy a cold drink as
well. (Cordial for the kids!)
Adding salt will do little more than waste the
water after the ice melts
Rolande
198394
Reply By: robak (QLD) - Monday, Oct 09, 2006 at 12:29
There was a long discussion about this on this
forum a few months back and came up with some good answers. Basically - adding salt to ice is useless. However adding salt to
water that you freeze will keep the temperature lower but not really longer.
I'll have do a search for you when I get some time.
R.
198395
Follow Up By: robak (QLD) - Monday, Oct 09, 2006 at 12:56
here:
Site Link
457049
Reply By: tojo - Monday, Oct 09, 2006 at 19:46
Thanks for all your responses seems like its not really worth the effort , but how do you stop large blocks from ballooning out when freezing them, sometimes they dont but more often than not they do and tend to crack and break.
thanks heaps Tojo
198431
Follow Up By: Member No 1- Tuesday, Oct 10, 2006 at 09:17
freezing
water makes it expand....to lower the expansion freeze smaller qty's
I use a blue tub from bunnings its around 300 x 400 x 150h filled 1/2 - 2/3(stamped proscon on bottom)...I have found these to be almost perfect fit in my 90l coleman esky
457194
Reply By: pauljohnston - Monday, Oct 09, 2006 at 20:10
To stop the ballooning don't completely fill your container(leave it an inch or so from the top). Then squeze the container to push the
water up to the rim, then screw the cap on. As it freezes in the freezer and the liquid expands you get a normal shaped container.
There is a very good post on here somewhere, type in ice brick or salty and see what comes up. It explaines the physycs of adding salt to
water. Basically yes it does lower the freezing temp of
water (we all knew that). So add the salt before freezing your brick. You will need a good freezer to get the temp down low enough. The beauty of doing this is that it keeps the temp low longer even though the solution has melted. The reason being that to increase the temperature of the ice takes less ambient heat than it does to increase it when it is a liquid. So if you have a liquid at -10c (which you can achieve by adding ice) it absorbs more heat energy to bring the temp up one degree than normal ice at -10C (approx twice as much from meory). This keeps the temp lower longer. Also it takes far more energy to convert ice to liquid, with a salt soltion this has to happen at far lower temps, helping to keep the temp lower longer. This is probably a poor explanation, search the threads to find a much better one. The guts of it is that adding salt, then freezing the solution does work.
198439
Follow Up By: pauljohnston - Tuesday, Oct 10, 2006 at 14:41
Made a mistake, where I have said, "So if you have a liquid at -10c (which you can achieve by adding ice) should be salt, not ice.
457252
