Timing Belt on Hyundai Terracan
Submitted: Monday, Oct 09, 2006 at 16:37
ThreadID: 38367 Views:11443 Replies:4 FollowUps:18
I have a 2003 terracan and recently the timing belt jumped 6 cogs. Has anyone had a problem with the timing belt slipping when the car is under load or in soft sand? Any info or suggestions would be greatly appreciated.
Thanks Terra
Reply By: Jimbo - Monday, Oct 09, 2006 at 17:03
Terra,
This is not a ptoblem that I have heard of.
Did it do any damage?
You might also ask this question at www.terracan.australia4wd.com
ATB,
Jim.
AnswerID: 198412
Follow Up By: Terra-I-Cant - Monday, Oct 09, 2006 at 19:37
Have heard back from the Dealer this arvo. They said there is water in the engine and that was what made the timing belt slip. We went through about 3inches of water about 30 km from where it broke down. How can that be possible? This was the first time we have taken it on the beach. Plenty of dirt tracks but maiden trip on the beach.
Is it possible we could drive 30 km after crossing (basically) a puddle?
Thanks for all you input.
Terra
FollowupID: 457137
Follow Up By: GaryInOz (Vic) - Monday, Oct 09, 2006 at 20:13
Unless they can clearly identify it as "seawater" then in all possibility it could be radiator fliuid caused by a sudden rupture of the head gasket. Go down there and have a look at it, and take some "sneaky shots" (camera or phone cam) of the top of the cyl block/mating surface of the head, and if it is still aound the actual head gasket. Should give you good clues and evidence should you need it...You are looking for water/rust tracts from the water jacket holes to the cylinder. "Play dumb" about it when you are having a look.
Water would have caused imediate problems if it was ingested, unless there is a dependant loop in the inlet manifold (VERY UNLIKELY). Any water should have been stopped in the airfilter in the first instance. After 30 km or so there should have been no water left in the inlet tract anyway (evaporation due to airflow and engine heat).
Water in the oil does not necessarily mean you have had water in the cylinders, and water in the oil will not in itself cause hydraulicking.
The case they are putting forward sounds suss. They've seen a bit of salt spray under the vehicle and are trying to use that as an excuse. Pay for and get an RACV/RACQ (or whatever) inspection done now while it is in the dealers and apart.
FollowupID: 457141
Follow Up By: Terra-I-Cant - Monday, Oct 09, 2006 at 20:46
Thanks for the tips, will do and let you know.
As you probably can tell love cars with a bit of grunt but no a lot of knowledge under the bonnet - use to leave that to the dealer but now will have to do some research me thinketh.
Terra
FollowupID: 457153
Reply By: Terra-I-Cant - Monday, Oct 09, 2006 at 17:06
The repairers said it bent the camrods but are unsure of how it happened. So lots of $$$ till they can work out what happened as say not a warrenty problem.
Terra
AnswerID: 198413
Follow Up By: GaryInOz (Vic) - Monday, Oct 09, 2006 at 17:09
If it is still under warrany and the vehicle has been properly serviced, etc., THEN PUSH IT. IT IS A WARRANTY ISSUE IF IT WAS NOT CAUSED BY MISUSE!!!!!.
FollowupID: 457096
Follow Up By: Jimbo - Monday, Oct 09, 2006 at 17:16
I agree with Gary 100%.
FollowupID: 457097
Follow Up By: Terra-I-Cant - Monday, Oct 09, 2006 at 17:21
Misuse - that is the question.
Do you think taking a 4WD on soft sand is misuse?
Terra
FollowupID: 457100
Follow Up By: Jimbo - Monday, Oct 09, 2006 at 17:26
Of course not, it is a bloody 4wd. It is sold as a 4wd, low range etc. Sand is more than reasonable 4wd use.
Mine has been over lots of soft sand and went like a beaut.
Jump on the Terracan forum, join up and message me.
ATB,
Jim.
FollowupID: 457102
Follow Up By: GaryInOz (Vic) - Monday, Oct 09, 2006 at 18:01
Quit simple, never trust the advice of dealers as to what is covered by warranty and what isn't. Go to your state consumer affairs, automobile chamber of commerce, or motoring organisation for clarification of EXACTLY where you stand. Take the information back to the dealer IN WRITING.
FollowupID: 457109
Follow Up By: Exploder - Monday, Oct 09, 2006 at 18:32
Don’t tell em you were off-road.
I have heard of this happening to other Hyundia Models as well as belt’s breaking before the scheduled change time, so it is know to happen but I wouldn’t go as far to say it’s a common problem
How many K’s do you have on yours, it’s probable that the belt has stretched enough to allow it to slip, but 6 cogs gee I would be looking at the tensioner.
You probably bent a few Valves and maybe damaged a piston or 2, I wouldn’t go paying for any new camrods thou as they don’t exist, there may have been a communication error on that.
Cheers.
FollowupID: 457114
Follow Up By: GaryInOz (Vic) - Monday, Oct 09, 2006 at 19:08
It actually depends on the design of the engine, if it is an "interference" design then it is possible to do damage, but if it is a non-interference design then the dealer could well be "Value adding" at your expense.
Nothing a dealer likes more than a "remove/inspect/replace" to generate a bit of extra cashflow from unsuspecting customers. In effect getting paid to do nothing.
If it is still under warranty, as a said, PUSH IT!!!.
When it is no longer under warranty, never go near a dealer again. Find a decent knowledgable guy that has better customer satisfaction motives.
Reality: the overpriced services that dealers charge are to offset the extra square footage rent they pay for their car yard. Unsold cars do not generate income and depreciate with time. You do not get any better service or knowledge from a dealer than from an independant mechanic (good one anyway).
FollowupID: 457124
Follow Up By: GaryInOz (Vic) - Monday, Oct 09, 2006 at 19:11
"...bent the conrods..."
PAY THEM A VISIT and get them to show you, and your engine should also look like it has been completely pulled doown too....
FollowupID: 457127
Follow Up By: Member - John R (NSW) - Monday, Oct 09, 2006 at 19:18
What's a "cam rod"? Is this a Korean thing?
FollowupID: 457130
Follow Up By: GaryInOz (Vic) - Monday, Oct 09, 2006 at 19:23
Prolly means "conrod".
FollowupID: 457131
Follow Up By: Terra-I-Cant - Monday, Oct 09, 2006 at 19:41
It has 70,000 km on the clock and see above what the dealer said.
Terra
FollowupID: 457138
Follow Up By: Exploder - Monday, Oct 09, 2006 at 20:58
Well 100,000K is the change over point for the timing belt if I am not mistaken, so it is possible that the belt had stretched unsatisfactorily.
The failures I have heard about where the timing belt has broken/-skipped teeth has been around the 80k mark.
Once agene not saying this is a common problem just that it does happen and I would push for warranty.
FollowupID: 457156
Follow Up By: Member - Axle - Monday, Oct 09, 2006 at 21:04
I think Exploder is on the money!!!, Belt tensinor failure.
Design fault, like all relativey new things on the market
Axle.
FollowupID: 457158
Follow Up By: Terra-I-Cant - Monday, Oct 09, 2006 at 21:25
How do we tell that it was a Belt failure if the belt is still in place?
Terra
FollowupID: 457164
Follow Up By: Member - Axle - Monday, Oct 09, 2006 at 22:51
AS you mentioned or somebody did , it skipped some cogs, if no teeth are missing and the timing is way out, then the belt tensioner must be very sus!!.
Axle.
FollowupID: 457173
Reply By: Member - Duncan W (WA) - Wednesday, Oct 11, 2006 at 20:21
Terra go here www.terracan.australia4wd.com we'll look after you. If your Terracan has done in excessive k's it could be due to have the belt changed. I think it's changed at the 75,000 service (not cheap). Log into our Forum and browse the past posts or sign up and post a question somebodies bound to have an answer.
Cheers Dunc.
Dunc
AnswerID: 198803
Reply By: Truckster (Vic) - Wednesday, Oct 11, 2006 at 21:44
speak with RACV Legal department or NRMA or who ever it is in your state.
AnswerID: 198820
