GPS on Lap Top in Car
Submitted: Monday, Oct 09, 2006 at 20:15
ThreadID: 38377 Views:2443 Replies:9 FollowUps:15
I wish to run moving maps on my lap top ,I require information on what GPS I require ,Will a Mouse Style GPS on Roof work ok, I have very good Lap top with DVD player Can any one give me direction , the more I read the more I get confused
Have a great Day
Reply By: Member - John C (WA) - Monday, Oct 09, 2006 at 21:00
Colin, I use a Garmin Etrex - inexpensive and does everything you need.
AnswerID: 198448
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 10:11
Hi John
Thanks for the Information
I had a great respond to my request
Now its time to make up my mind
Colin
FollowupID: 457202
Reply By: Old Scalyback & denny - Monday, Oct 09, 2006 at 21:04
goodday colin
yes the mouse will do, when i thought my gps had packed up i was looking into the mouse style and it will work with the oziexplorer software and transmit direct to the maps
steve
AnswerID: 198450
Follow Up By: Old Scalyback & denny - Monday, Oct 09, 2006 at 21:07
ps if you contact gpsoz on0299992313
they are pretty good and will talk about the products if you need more info
steve
FollowupID: 457161
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 10:14
Hi Steve
Colin
FollowupID: 457204
Reply By: John R (SA) - Monday, Oct 09, 2006 at 21:17
A can of worms Colin. There's a multitude of options!
You can use your laptop. You can get the gps signals in via GPS mouse, via conventional GPS with a data lead, via a bluetooth gps mouse sitting on your dashboard (Lucy will shed some light on the benefit of these gadgets).
OziExplorer is a well respected program that will display digital maps (obtained seperately), will allow you to create/manipulate etc waypoints, tracks etc etc and it will accept data from your gps and be used as a moving map. It won't give you turn by turn directions.
There are other programs available, but this is the one I use, and like.
Maps in a digital format are a bit . . . varied, but certainly available.
In my limited experience, the Natmap Raster map of Australia is a good general map of the entire country. Have a look through the store here at exploreoz, also try gpsoz, the oziexplorer australian website or google: digital maps site:au
and you will find maps which vary in detail. More and more are hitting the market all the time.
I favour a BT338 bluetooth gps sitting on the dashboard. It's small, doesn't require cables to talk to the laptop or pda. It does need charging, but gets ~ 12 hrs or more per charge.
I sometimes use a Garmin II+ with external aerial, but it gives me the curries because there are cables all over the place (aerial - gps, gps - laptop - power outlet).
I have picked up off ebay a 10" touch screen monitor, so the laptop can sit somewhere else (and most importantly, not have space around the dashboard used by keyboard).
The laptop gives a bigger viewing area which is good if I'm in new territory, but cumbersome and rarely used.
The pda is easy to mount & use. This gets a lot more use.
Hopefully this has been of some help. A bit ambiguous, but I didn't want to get into specifics (too much), and get bogged down.
AnswerID: 198455
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 10:16
Hi John R
Colin
FollowupID: 457205
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 11:24
Hi John
Sorry to trouble you
I have tied to find Lucy in search on Explor Oz or am I just dumb ,as I am 70 & need plenty of direction LOL
(Lucy will shed some light on the benefit of these gadgets). you wrote
Colin
FollowupID: 457212
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Oct 10, 2006 at 15:27
Colin, don't be too concerned to wait for Lucy, as she is an old LC Troopy whose driver talks in riddles about the particular advantage of a certain Bluetooth GPS mentioned above. There are heaps of others.
If you are looking at new GPS receivers look for Sirf chipset ones where they are faster to acquie information and log onto more satellites at once - they have more data transfer channels, giving you a better fix in difficult conditions. Mine is a Holux brand, where as Lucy has that BT one above, there are plenty of people with each one
I also have a Magellan Meridian Colour with Australia Streets and Tracks loaded on a 512 meg SD card and it has a capability to hard wire to the Dell X50v PDA system or whatever. I use a Dell.
It is mentioned below that the GPS Mouse is a receiver. They all are! The GPS mouse has no direct readout but relies on a computer of some sort to tell you where you are. A Bluetooth GPS is the same and relies on the information getting to a computer. There is a place for the old style cheaper GPS in your kit too, like my Magellan or a Garmin.
FollowupID: 457259
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 16:14
Gee Thanks John
I was thinking i was getting close to the nursing home, looking for Lucy
Iwill go for the mouse you suggested as other have ,also will purchase a touch screen as well, connect to my lap top wich is new as my last one kicked the bucket in the Simpson.
Have a Great day
FollowupID: 457273
Reply By: Trekkie (Member - WA) - Monday, Oct 09, 2006 at 21:46
If you are not too interested in the features on the GPS itself, then the GPS really does not matter - so buy the cheapest best option that will run the laptop. I have a Garmin III+ I got it cheap from a friend who never used it. I run OziExplorer and the software interfaces with heaps of GPSs. My GPS has an antenna attached and in all my travels I have only lost "contact" on afew occasions (there again in WA we dont have too many mountains and trees)
I have hard wired the unit, so I dont have to worry about batteries and the cables are out of the way
!MPG:10!
AnswerID: 198460
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 10:21
Hi Trekkie
I will advise on my action I take.
Colin
FollowupID: 457206
Follow Up By: Member - Davoe (Nullagine) - Tuesday, Oct 10, 2006 at 14:28
Only thing I would say is that it may be a worthwhile advantage getting a gps that can have an external ariel fitted (It is an option for the one pictured) Most gps will work ok onthe dash with the normal ariel but an external is better especially as some gps have problems finding sattelites while moving when on the dash (once they lock they are fine)
FollowupID: 457249
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 15:31
Thanks Davoe
I have 3 external Ariels now ,1 for UHF,1 for the Internet ,1 for CDMA Phone, Thats why I thought the mouse type thats is attach to the roof outside might suit, I am still putting all the information recieved together,any help is a great
Have a Great Day
FollowupID: 457260
Reply By: Chaz - Monday, Oct 09, 2006 at 22:08
Colin,
If you only want to use it on your laptop, a USB mouse is a cheap option, unless you want to go walkabout with it. They can be had on ebay for under $100 and if you get one with the latest Surf chip, they do 20 satellites at once. I am running one on my car PC and it never drops out, even when I’m parked in the shed. It’s positioned under the windscreen and velcro’d to the dash mat.
AnswerID: 198464
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 10:22
Hi Chaz
Colin
FollowupID: 457207
Reply By: Groove - Monday, Oct 09, 2006 at 22:12
GPS mouse is a great option when using a laptop, they are cheap, they dont need batteries or a additional power plug becuase they are powered by the usb port. When you turn the computer on the GPS turns on at the same time. I got mine on ebay for $70 and it works great even in my garage which surprised me. It gets a lock very quickly
AnswerID: 198466
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 10:23
Hi Groove
I still like the mouse BUT________________
Colin
FollowupID: 457208
Reply By: Batboy - Tuesday, Oct 10, 2006 at 06:03
Mouse style GPS will work well with moving map software if you have it on all the time and your software records your track. If you are like me and don't want to have the laptop running all the time but still want to record your travels or sometimes need to find where you are and how you got there then a normal GPS is better. Just have the GPS running on the dash and download the waypoints to the lappy when you are ready or need them. I maybe wrong but i don't believe mouse GPS units record waypoints.
Cheers Jim
AnswerID: 198487
Follow Up By: Member - Colin C (QLD) - Tuesday, Oct 10, 2006 at 10:25
Hi Batboy
Colin
FollowupID: 457209
Reply By: mfewster - Tuesday, Oct 10, 2006 at 07:26
Lots of questions for the experts.
I have an old Magellan GPS 4000XL plus external antennae and data communication module. ie it isn't a mapping unit. Is it possible to connect this to a laptop with maps installed and get a mapping/tracking outcome?
I note from previous posts on this thread that a GPS mouse may not store waypoints? Can these be stored on the computer however when the mouse is connected to the computer?
Thanks experts.
AnswerID: 198494
Follow Up By: John R (SA) - Tuesday, Oct 10, 2006 at 12:25
While we wait for the experts to pop up . . . .
Yes, you can use the Magellan 4000XL with a laptop (ozi certainly seems to accept this model) and get a moving map.
As with Colin, if you load maps into a program like ozi, it will in turn take the gps data from your Magellan and tell you where you are on the map.
I don't know much about the GPS mouse, but my understanding is that they're simply a receiver. It will allow your laptop to receive the gps data and again, tell you where you are.
You can then create waypoints, tracks, and a myriad of other things on your computer. The main difference between the mouse & the magellan is that you can send data from the laptop to the magellan. So, if you want to find a waypoint and you need to walk a few hundred metres from the nearest road, you can take the magellan with you. Or, if you want to mark a waypoint somewhere off the road, you can take the magellan, mark the point then return to the laptop and upload that to the computer.
FollowupID: 457222
Reply By: mfewster - Tuesday, Oct 10, 2006 at 12:44
Many thanks John R. I will give this a go.
AnswerID: 198536
Follow Up By: CLC50 - Tuesday, Oct 31, 2006 at 07:35
Many thanks to all.
Colin
FollowupID: 461439
