Calling all Suzuki Vitara Experts
Submitted: Tuesday, Oct 10, 2006 at 12:29
ThreadID: 38393 Views:9110 Replies:7 FollowUps:11
I have a 99 Grand Vitara which is currently hardly running,
there is no power under any load.
We have replaced the catalaic converter and everything else seems to be in order.
One mechanic has put the car on a Dyno and suggested it is the head gasket ? but
there have been no other symptoms that would suggest this.
Any help or direction would be greatly appreciated, I don't know where to go from here.
Reply By: Shaker - Tuesday, Oct 10, 2006 at 13:11
Maybe start with the basics .... firstly a compression test!
AnswerID: 198542
Follow Up By: BlondOne - Tuesday, Oct 10, 2006 at 13:23
Sorry... I should of filled you in.
Compression is down only a little bit and not much diff between cylinders, manifold vacuum's is also a bit low, squeezing the fuel return line (to up fuel pressure) doesn't help either... its a bit of a curly one???
FollowupID: 457232
Reply By: Kiwi Kia - Tuesday, Oct 10, 2006 at 13:23
PCV valve PCV valve PCV valve. Yep, I am that certain :-))
AnswerID: 198548
Follow Up By: BlondOne - Tuesday, Oct 10, 2006 at 15:48
Ok will check it out and let you know
Thank You :-)
FollowupID: 457266
Reply By: GaryInOz (Vic) - Tuesday, Oct 10, 2006 at 15:16
Is there any check engine light on? Can you get any codes out of it?
AnswerID: 198575
Follow Up By: BlondOne - Tuesday, Oct 10, 2006 at 15:49
No - no engine check light on
Can't get codes
FollowupID: 457268
Reply By: BlondOne - Tuesday, Oct 10, 2006 at 15:55
Just another thought..
At first it was only an intermittant issue ie sometimes when you put your foot down there would be a big flat spot by taking your foot off the accelerator then putting it down again appeared to fix the problem. But it has steadly become worse and now it is near impossible to drive the car.
We initally thought it was the air flow meter, but we have replaced this.
AnswerID: 198582
Reply By: Alan W - Tuesday, Oct 10, 2006 at 16:46
Blocked air/fuel filters?
Do you do serious 4wding - Damaged read squashed underbody fuel lines?
I'm leaning towards fuel/air starvation.
AnswerID: 198589
Follow Up By: BlondOne - Tuesday, Oct 10, 2006 at 17:05
No - no serious 4WDing but your fuel/air starvation is right on the money.
ie there is no difference power wise from 1/2 throttle to full throttle
FollowupID: 457281
Follow Up By: Alan W - Tuesday, Oct 10, 2006 at 17:58
Check fuel pump for pressure and flow.
Drive around the block with fuel filler cap off. Is the fuel tank venting.
When was the last service, has spark plugs been changed recently. Could also be a plug breaking down under load, even a faulty new one. Maybe a lead or two also.
Tail pipe emissions? Is there any? What colour? At what revs?
As you can see I start simple then work up, but without actually looking at the vehicle, it's hard to diagnose.
FollowupID: 457303
Follow Up By: BlondOne - Tuesday, Oct 10, 2006 at 18:27
Hi Alan,
Thank you for your time on this, I appreciate how hard it is without seeing the vehicle and running the diagnostics yourself :-)
The last service was 2 months ago spark plugs were changed and have been checked and a faulty one changed since.
Tail pipe emissions are black not sure at what revs will have to check and get back to you.
FollowupID: 457309
Follow Up By: Alan W - Tuesday, Oct 10, 2006 at 19:57
If you've done the tests, or items I suggested to check are known to be ok, I keep giving you ideas.
Catalytic converter was replaced. Why, because in the fear it was collapsed and blocked. What about main muffler, could also/instead be collapsed.
Check air filter box, look in box and up all inlet & outlets. No obstructions such as mechanics rags. Look at air intake no shopping bags or the like blocking it. Make sure the hoses are not being sucked in with the engine running.
Check the timing, is it out due to belt skipping a cog. Is it time to change the belt.
Fill the tank with fresh fuel, put 98 ron into her. Put a bottle of fuel system cleaner in.
Now we're into spending money. Injectors, are they running correctly, good spray pattern etc. ECU, is it telling the injectors the right thing, check the codes make doubley sure there's no faults recorded. Could be the ECU itself thats at fault.
You menioned a mechanic has suggest it's a head problem, what made him say that. On what facts did he base his prognosis on. He maybe right.
Unfortunately I'm done at this stage. If I think of anything else, I post it here.
If you do find the fault soon, and I hope you do, please post the results. I bet it's something simple, it always is!
FollowupID: 457330
Follow Up By: GaryInOz (Vic) - Tuesday, Oct 10, 2006 at 20:43
I'm leaning towards a stuck open injector. This would explain the rough running, black exhaust fumes, and (I'm guessing) crap fuel economy. Other possibilities, bad spark lead (usually the longest one), bad distributor/ignion timing (failure of mechanical/vacuum advance mechanism), or failure of coil pack/leads (ECU controlled ignition if fitted)
Going on previous information, the block seems OK (compression test low but all equal consistant with old engine), head seems to be working (valves not leaking), no abnormal noises reported, timing belt seems reasonable (slipped would cause bad running, but not black exhaust). All the expensive bits seem OK.
FollowupID: 457343
Follow Up By: GaryInOz (Vic) - Tuesday, Oct 10, 2006 at 20:46
GET THE CODES READ or tell us precisely if there are no codes to be read. I cannot believe it would run as badly as it seems to be and not throw some codes.
Also worth checking all the little vacuum hoses are plugged in too.
FollowupID: 457345
Reply By: ed. - Tuesday, Oct 10, 2006 at 17:25
How does the coolant look?
Milky? brown?
AnswerID: 198597
Reply By: Bilbo - Tuesday, Oct 10, 2006 at 18:02
Is this Vitara fuel injected or does it have a carburettor?
I strongly lean towards the "fuel starvation" theory, but need more info.
One point worth mentioning is my wife's Suzuki Swift had similar symptoms and it turned out to be a very badly clogged fuel filter. So bad was it clogged that it actually sucked some crap into the idle bypass jet and blocked it - this was a carby model and not EFI. We were unable to clear this "jet" as the it was drilled into the aluminium carby body - even acid cleaning didn't shift it. It was not a removable brass jet. The car went like a rocket after changing the fuel filter but the slight flat spot stayed there until the day I sold it. The blockage in the idle bypass jet was causing the flat spot.
Bilbo
AnswerID: 198603
Follow Up By: BlondOne - Tuesday, Oct 10, 2006 at 18:12
The Vitara is fuel injected, however the symptoms are very similar to your description
FollowupID: 457304
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Oct 10, 2006 at 19:45
Bilbo, that was going to be my question too. The Maruti engined Suze here had a fuel and oi recirculation system. It wasn't meant to be, but the fuel pump leaked petrol to the sump, and filled it to overflow the mix back through the recirculating line to the tank. The result was a mix of fuel and sump oil in the fuel tank and also the sump!
The diaphragm was leaking both ways, the fuel was going down inside the engine from the distributer drive shaft cavity. The mix, as I said overflowed back again.
FollowupID: 457328
