td5 help needed
Submitted: Tuesday, Oct 10, 2006 at 15:18
ThreadID: 38401 Views:1860 Replies:3 FollowUps:2
2004 defender that lives in broome - trouble starting - has had a new fuel pump (hp) fitted and filters replaced. new starter solenoid also fitted. the l/r shop has had it for a few weeks and is getting nowhere very quickly. now they have said it is the 'crank angle sensor'. are they having a lend or could this be the problem? starting trouble is same cold or hot. once running all is ok with plenty of go and not much fuel being consumed (normal). any ideas greatly appreciated. rgds
Slow down and relax......
Reply By: ed. - Tuesday, Oct 10, 2006 at 15:54
Might get a faster/more accurate diagnose on
www.aulro.com
Ed
AnswerID: 198580
Reply By: Alan H - Tuesday, Oct 10, 2006 at 16:33
Hi Maverick.
Wouldn't it still be under warranty at that age?
Alan H.
AnswerID: 198588
Follow Up By: MAVERICK(WA) - Wednesday, Oct 11, 2006 at 09:42
ha ha.......try and get any sort of warranty done outside a major centre. rgds
FollowupID: 457411
Reply By: Cannon - Tuesday, Oct 10, 2006 at 20:12
Hi Maverick,
Does you mechanic have testbook? If so, the computer will indicate if there is a problem with the crank sensor.
Have the mechanics categorically gone over all the fuel lines for any air being sucked in? Is the fuel pump noisy, like whining? What is the fuel like? Is it just this particular tank of fuel that you are using? TD5's hate crap fuel.
AnswerID: 198632
not mine and even thou8gh i once did i no longer live up there....have passed all on to the owner. rgds
FollowupID: 457412
