Splits and Crossplies
Submitted: Tuesday, Oct 10, 2006 at 21:11
ThreadID: 38414 Views:3220 Replies:7 FollowUps:10
After looking around for a while for Nissan split rims I met up with a bloke at a friends place last week and while we were discussing this and that, the rims question came up and he said, "How many do you want?" So I am going to collect them on Thursday.
This arvo I was chatting to my tyre man and he said "Your MRF's are here". Now I did'nt order them at all. We had just discussed the MRF Superlug 16ply. I said "I'm broke at the moment" and he said "Take them while you can as they are hard to get hold of.....we will work out a price later and I will put them on your account. Pay me when you have some money".........I just love living in the country where we can do deals like this.
Now I will have 5xCooper STT, 5x Eldorado ZTR, 4x MRF Superlug, 5x Dunlop Road Grippers and 4 Dunlop Road Gripper casings. Have had to re arrange the garage to fit them all in!
Reply By: Gramps (NSW) - Tuesday, Oct 10, 2006 at 21:13
LOL your tyre man will be getting worried about possible 'competition' with that lot in your shed hahahahahaha
AnswerID: 198642
Follow Up By: Willem - Wednesday, Oct 11, 2006 at 07:32
Al
Most of them came from his place...lol
FollowupID: 457393
Reply By: Footloose - Tuesday, Oct 10, 2006 at 21:40
I just threw some Toyo splitz away at the dump and it cost me money to get rid of em.
I'll be very interested in how your MRF's go on the tar. There's a lotta tar before I hit the good stuff :((
AnswerID: 198648
Follow Up By: Willem - Wednesday, Oct 11, 2006 at 07:37
Footy
Toyota splits do not fit the Nissan unfortunately. There are lots of them lying around here including the 5 stud ones.
The MRF Superlug is not unlike the old Jeep Service Bar Tread, but with an off-set lug
There are many gravel roads to take from where you live........ if you are heading into the sunset......:-)
FollowupID: 457395
Follow Up By: Member - Peter R (WA) - Thursday, Oct 12, 2006 at 10:50
Willem,
The stud configuration matches between Nissan & Toyota you just have to grind/ machine the centres out about 2mm.
You're one hell of a fella if you put plugs in side walls and then get back on the road?????? Very dangerous!
Nightjar
FollowupID: 457586
Follow Up By: Willem - Thursday, Oct 12, 2006 at 20:27
Nightjar
What is dangerous about it?
I have now travelled 10,000km since the last stake. One tyre started leaking again and I stuck another two plugs in it.
I cant see the problem.
The Nissan has small lugs on the hubs of the front wheels as well and old Nissan(G60) rims and Toyotas do not fit. This from experience.
FollowupID: 457669
Reply By: MichaelR - Tuesday, Oct 10, 2006 at 22:22
Hey Willem
What do you intend doing with the Superlugs? These are crossply tyres I presume so getting to where you want to use them may make the journey a little uncomfortable I should think. They would no doubt be fairly puncture proof if used off-track. Or do you use other tyres to get you to the off-track area (you do seem to have plenty), whip of the road tyres and put on the Superlugs, putting the 4 removed tyres on the roof?
I notice that the MRF Steel-Muscle L all-steel radials are used by some tour companies as a bit of a compromise-OK on road and good side-wall strength. Why didn't you choose these?
AnswerID: 198659
Follow Up By: Willem - Wednesday, Oct 11, 2006 at 07:31
Michael
This year I have managed to stake 13 tyres in my travels. Some of the sidewall cuts on the radials have 4 plugs in them. They seem to tear with use and then inevitably needs another plug. One tyre should really be repaired by a professional mob but I keep it on the spare.
I realise that the Superlugs could be a tad uncomfortable for highway use but I intend doing some over grown tracks and Off Track touring in the future and will use these tyres for those purposes. MRF produce a number of variants and the Superlug looks as if it will be a compromise tyre for my use. Crossply tyres are known for sidewall strength.
No, I will not carry the tyres and swap them over when in the bush. I will minimise my bitumen travel when going to my destination
For normal road driving, gravel roads and also Simpson Desert treks I will still stay with the Cooper STT's as they performed very well with low tyre pressures on sand. I will still be running the Eldorados for normal trips on the trailer and the Dunlop Road Grippers for Off track treks.
FollowupID: 457392
Reply By: V8Diesel - Wednesday, Oct 11, 2006 at 08:07
I'll be very inerested in how the MRF's go Willem. I've got 10 ply Bridestone's on my splits but have got two flats already so I'm itching to go back to cross-plies.
When doing exploration we'd go for the most highway oriented tread pattern available as lugs tended to 'funnel' stakes into the tread.
AnswerID: 198687
Follow Up By: Willem - Wednesday, Oct 11, 2006 at 08:47
I don't have any immediate use for them V8Diesel, but will try them out in January when I caretake a station in the Flinders Ranges and should be able to give an initial report then.
Like with everything else, it is all trial and error :-)
FollowupID: 457406
Follow Up By: Willem - Thursday, Oct 12, 2006 at 20:33
V8
I have just had word from Mick Hutton and Connie Sue Beadell that I should go for the Super Miler MRF and will now take your and their advice and swap the Super Lugs over for them.
FollowupID: 457670
Reply By: Member - Davoe (Nullagine) - Wednesday, Oct 11, 2006 at 18:35
make sure you match them up with decent tubes such as michelin. Besides the fact that those korean tubes are crap i and others have found it is harder to attach patches to them - they just dont seem to "vulcanise" or whatever
AnswerID: 198780
Follow Up By: Willem - Wednesday, Oct 11, 2006 at 19:08
Thanks Davoe. Yes I intend to fit the better tubes when I fit the tyres.
FollowupID: 457484
Reply By: Mikee5 (QLD) - Wednesday, Oct 11, 2006 at 19:04
Hi Willie,
That is a much younger GG in that Pic.
How old is it?
Mike.
AnswerID: 198786
Follow Up By: Willem - Wednesday, Oct 11, 2006 at 19:09
Hi Mike
Not sure if I follow you? GG?
FollowupID: 457485
Reply By: Mikee5 (QLD) - Wednesday, Oct 11, 2006 at 19:24
Willie,
Isn't GG the guy in the white T shirt at the bottom of the drop-off!
Mike.
AnswerID: 198788
Follow Up By: Willem - Wednesday, Oct 11, 2006 at 19:42
OK...LOL..... Yes, April 1992. We have all grown older since those days but are still going out on adventures together as we did this year into the Western Deserts
Now, who are you?
You can email me thorugh my website below
FollowupID: 457497
