Suitability of GPS inland
Submitted: Thursday, Oct 12, 2006 at 21:15
Member - Ian T (VIC)
Can somebody point me in the right direction - will a Garmin GPSmap 60 cx get me to the CSR, and along the CSR with side trips off? Is this a good GPS for off-road?
appreciate advice - Ian
Reply By: Ken - Thursday, Oct 12, 2006 at 21:33
Absolutely, Ian, one of the best in my view. Withthe extra memory you can take an amazing amount of maps as
well. The main thing to do is get familiar with it and do a few trips with it before hand.
Ken
198926
Reply By: bob&loz - Thursday, Oct 12, 2006 at 22:49
You will need to load exta maps as the standard maps wont do it
try this site ob
198938
Follow Up By: bob&loz - Thursday, Oct 12, 2006 at 22:52
well that didnt work
Its tracks 4 australia on yahoo groups Site Link
457702
Reply By: On Patrol - Friday, Oct 13, 2006 at 07:18
Ian T
I've got the GarminMap 60C and love it. The std software is fantastic in town and cities & some popular tracks, but yes you will need Tracks4aus for other areas, these can be loaded alongside the std. maps so you dont need to install one or the other, you can install both, and then just switch via your setup function, 10 seconds work.
The only negative i have is the screen's lack of size. Yes play with it a lot before you have to rely on it, this will give you a better undertanding of it's workings, and by then you will be able to handle it with confidence.
Enjoy yor trip.
I'm off to
Cape York in May and will give
mine a workout then.
198953
Reply By: madcow - Friday, Oct 13, 2006 at 07:25
I have the 60cx and am very impressed with it. Tracks for Aust as per the link above have been very accurate so far both here in the
Vic high country and last week around the
robe area. There is also a group dedicated to this model and as it is a worldwide
forum you may learn a bit more off someone else's experience.
Site Link
198955
Reply By: Big Woody - Friday, Oct 13, 2006 at 08:13
I have had the GPS Map60CS for over 3 years and it sure gets a workout. It gets used in the Landcruiser for long distance and track work, it gets used on motorbike safari's on very rough tracks, I use it for hiking and off track exploring, I also have a yacht and use it in the cockpit with Garmin Bluecharts installed.
As mentioned above I use T4A in the bush, Garmin Metroguide on the highway and in the city, and Garmin Bluecharts when on the
water. It is regularly exposed to full sun, rain, salt spray, knocks and bumps and has never let me down.
The memory is more than big enough to hold all of the maps I require for whichever activity I am using it for. Actually I can fit all of Metroguide, T4A, and all of the Bluecharts between
Sydney and
Hamilton Island in the 55MB internal memory. The CX version was not out when I brought
mine but I don't see much of an advantage as the SD cards are only the mini version anyway.
The accuracy of the maps is astonishing. Especially when sailing through charted reef areas the GPS can show that I am 6 metres off a rock and sure enough a quick glance will show that I am in fact about 6 metres from the charted rock.
There are times when I would like a fixed unit with a big screen but then it would not be as portable for use on the motorbike or to carry on a trek by foot somewhere.
Yell out if you need to know any more about the unit.
Brett
198963
Follow Up By: The Explorer - Friday, Oct 13, 2006 at 12:28
"but I don't see much of an advantage as the SD cards are only the mini version anyway."
The mini sd cards are physically small - they do however come with the same memory capacities as "normal" SD cards eg 64mb, 256mb etc. The advantage of extra memory for maps is obvious...if you have the need for it. If you dont, as in your case (?), then having the newer model is of no use at all (assuming this feature is the sole difference). Mini sd cards are typically sold with an adapter that allows their use in normal sd card slots. This means that if you are not using it in your gps/phone you can utilise them in other devices if required eg camera, pda which may be handy sometimes.
457775
Reply By: Moose - Friday, Oct 13, 2006 at 13:20
G'day Ian
Sorry mate but the others have all mislead you. You will need a vehicle to get to and along the CSR :-)
Cheers from the Moose
199000
Follow Up By: Bonz (Vic) - Friday, Oct 13, 2006 at 22:26
hahahahaha u bstard! I nearly fell off my chair laughing hahahahaha
457876
