Poly air spacers
Submitted: Thursday, Oct 12, 2006 at 21:59
Member - uncle (NSW)
Good evening all, to those with a bit of fitting knowledge, just had polyairs fitted today to the GU, there is a spacer on the top and bottom of the airbags. Does the groove on the bottom spacer supposed to sit groove up, or groove down? Looks to me like it should be groove down.? Thanks unc
Reply By: Member - JohnR (Vic)&Moses - Thursday, Oct 12, 2006 at 22:11
With
mine, the groove is facing the air bag for the bottom spacer unc.
198933
Follow Up By: Member - uncle (NSW) - Thursday, Oct 12, 2006 at 22:18
No worries, must be done the right way then, thanks for that John, it's reassuring, as there were a few dramas with the fitting, and I'm back in there tomorrow to show them the front sway bar bolt that they left snapped off without ezyouting it and replacing it!!.Factory trained technicians Ha.
457693
Follow Up By: acdc - Thursday, Oct 12, 2006 at 22:47
Groove down,but it probably doesnt really matter.
You should only have the bottom block if you have raised
suspension fitted.
457700
Follow Up By: Member - uncle (NSW) - Thursday, Oct 12, 2006 at 22:48
Yeah ,
well there's a top spacer as
well?
457701
Follow Up By: acdc - Thursday, Oct 12, 2006 at 22:59
They all use the top spacer block on Patrols but the bottom is only used for raised
suspension.
457710
Follow Up By: Member - uncle (NSW) - Thursday, Oct 12, 2006 at 23:13
Forgot to mention it's had a full 2inch OME lift and springs , shocks etc today too.Thanks acdc for the help.
457713
