Manufacturer's policies on Bio Diesel
Submitted: Saturday, Oct 14, 2006 at 18:20
ThreadID: 38501 Views:2775 Replies:9 FollowUps:16
I found the article i have been referring to from our RAC magazine. It was as at June 2006, with some brands being since added.
BMW, Chrysler, Ford, Hyundai, Jaguar, Jeep, Kia, Land Rover, Mercedes Benz, Volkswagen NOT RECOMMENDED
Holden MAX 5% BIO DIESEL (except Rodeo - NOT RECOMMENDED)
Mazda MAX 5% subject to all other fuel standards being maintained
Mitsubishi USE AT OWN RISK, PROBLEMS NOT COVERED UNDER WARRANTY
Nissan MAX 5% BIO DIESEL
Peugeot ACCEPTABLE FOR SOME MODELS UN TO MAX 30% - check with manufacturer
Citroen UP TO 30% BIO DIESEL in cases where the fuel complies with Australian standards
Alfa Romeo and Fiat MAX 5%
Reply By: Tim M - Saturday, Oct 14, 2006 at 19:10
Yes I suppose it is a bit of an unknown for Manufacturers at the moment. I myself have been researching whether it will be a good idea for for my 93 80 series 1HZ. I have heard that engines are that much smoother when run on B20 or above. Might make some one day and trial. Nobody sells it where I am at the moment to trial so will just listen to what views anyone else has.
Tim
AnswerID: 199163
Reply By: Exploder - Saturday, Oct 14, 2006 at 19:18
Yes I remember reading it, basically use biofuel and kiss the warranty good buy.
AnswerID: 199165
Follow Up By: Luke SA - Saturday, Oct 14, 2006 at 19:43
Yep just had my injector pump recond and was told it was biodeisel, im still not 100% sure myself if it was but its what ive been told. What makes me unsure is alot of people use it and swear by it and have no problems
I personally wont use it again for only 2 reasons 1, the waranty will not be covered if i use biodeisel. 2, the 2cents a litre (sometimes you dont save anything) at the servo its not really worth it especially if you have to change your fuel filters a bit more often
Just my opinion anyway
Cheers Luke
FollowupID: 457981
Reply By: Member - Phil G (SA) - Saturday, Oct 14, 2006 at 19:36
I asked a diesel repairer today about biodiesel and my 1HD-FTE Landcruiser, and he said it would wipe years off the life of my injection pump. I'd expect him to give a straight answer.
AnswerID: 199167
Follow Up By: Motherhen - Saturday, Oct 14, 2006 at 20:10
I am surprised to hear this - i thought it was just fear of litigation and the unknown. Still, it's early days in bio-diesel technology; things will be different in a few year time.
FollowupID: 457984
Reply By: Member - Andrew W (SA) - Saturday, Oct 14, 2006 at 20:05
There is a lot of ignorance on this subject. Most mechanics have never received training on it's use, and know little about it, besides some myth or rumour or other.
Manufacturers live on the testing and advice received from the oil manufacturers, most of which have full-time reps onsite with the manufacturers. They don't want people introduced to alternative products, and the manufacturers thus have no reason to provide balanced information on the question. They promote Fear Uncertainty and Doubt instead.
There are a number of real questions:
1. what really matters to you - if the manufacturer's warranty is well and truly over, then at least for me, what they say doesn't matter a toss
2. why do you want to use it? For me, fact is that it is a sustainable fuel, with NO emissions to speak of. I actually pay about 10cpl less than dino diesel too (if you are in SA, you can buy it from a number of SAFF outlets at this price).
3. what will it do to your engine? For most modern engine, and not so modern, like the '99 1HZ I have, it will run smoother, similar efficiency, and cleaner - thus increasing engine life.
It is likely to require an additional replacement of a fuel filter, as it cleans out crud from years of fossil fuel use in your fuel system (Biodiesel is a better solvent). Older engines with natural rubber will need hoses and the like replaced - but they would need this to use Low Sulpher Diesel anyway.
Interesting too that BMW, MB and Volkswagen all positively encourage the use of Biodiesel in Europe (for the same engines).
There is an Australian Standard for Biodiesel which all retailers are supposed to comply with - if they don't you can report them. The standard is more stringent than the standard for fossil fuel diesel.
Lastly, like with any bad fuel, if your engine is affected by Biodiesel from a retail outlet, take a sample of the fuel; report them, and seek recompense from them.
Andrew smelling like the fish and chip shop.
AnswerID: 199171
Follow Up By: hl - Saturday, Oct 14, 2006 at 21:12
Now, that's a whole lot easier to say than to do (to prove the fuel caused your problem)! Besides, it is not likely that your problem occurs on the first few tankfuls, rather, it may take months or a couple of years if the fuel causes excessive wear in the pump, for things to actually fail.
As I understand, it is not the car manufacturers that are cautious, it is more the fuel injector suppliers, and there are not that many different ones out there. The conventional ones are probably ok, but all the new DI diesels use very high pressure injection and these may have problems with bio.
As for being so green, it has been said that it takes a couple of liters of dino diesel in the farming, refining etc etc process to come up with a liter of bio.....
The jury is still out.
If your car manufacturer says 5%, I would stick with it. It would be a wonderful marketing tool to be able to claim that "our cars can run on 100% renewable bio".
So far no maker is running with that and it may be for good reasons.
FollowupID: 457988
Follow Up By: Member - Andrew W (SA) - Saturday, Oct 14, 2006 at 22:04
Well I could prove that the 2 litres of water and crud in the Fossil fuel diesel from the truck stop in Dalby that I picked up a year or so ago was the cause.
You're right about one pump manufacturer that alleges that their pump won't support B100, but they do allow B20 in Europe.
Your allegations about the carbon emissions and energy consumption to produce Biodiesel are wrong - they sound nice, but you forget that most of the Biodiesel manufacturers are accounting for that with net zero emissions and other means of producing a mathematically (at any rate) sustainable product. If it really took two litres of diesel at $1.30 per litre to make one litre of Biodiesel at $1.20 per litre people would be exiting the industry pretty fast don't you think?
Further, significant amounts of Biodiesel are made from waste vegetable oil ... think about that in energy cost or carbon emission terms.
The jury is not out. The jury has spoken in all sorts of European languages.
Try it and see - I have been running B100 for 90,000 km except when I am stuck somewhere that it isn't available. It is all good.
TransAdelaide; Sydney City Council and a number of other large fleet operators have made the switch. Time to get with the program me thinks.
FollowupID: 457999
Follow Up By: hl - Sunday, Oct 15, 2006 at 06:45
Well, the truth is probably somewhere in-between. However, I have read somewhere that to grow enough crops to make bio fuels to displace fossil fuel would require that we don't eat. There is no way it can be produced in those quantities without displacing food crops, and even then it won't be enough.
Don't get me wrong, I like the thought of it, but as with solar panels running your whole house etc etc... the reality is very different to the hype that's often associated with these things.
FollowupID: 458022
Follow Up By: hl - Sunday, Oct 15, 2006 at 06:50
Hi agin,
It is one thing to prove that you copped a bad load of fuel with water in it, and quite another to prove that your pump has failed after 50,000k on bio....
As long as the folks who sell you the stuff can claim it complies with aussie fuel standards, you're on your own. Especially if your car maker says only 5% is ok.
FollowupID: 458023
Follow Up By: Batman69 - Sunday, Oct 15, 2006 at 11:26
Andrew,
I am a little confused how a diesel internal combustion engine produces in your words "No emissions to speak of"?
It would have been more accurate stating bio diesel burned cleaner than petroleum diesel.
There will still be emissions, not all of them environmentally friendly, the amount and type of emission given off will be dependant on the type of biodiesel and the engine it is used in.
FollowupID: 458059
Follow Up By: Member - Andrew W (SA) - Sunday, Oct 15, 2006 at 14:29
Batman's being pedantic ... no Nitrous Oxides or harmful emissions.
Does that help?
Biodiesel by it's nature is esters of fatty acids.
Zero emissions is the terminology used.
FollowupID: 458088
Reply By: F4Phantom - Saturday, Oct 14, 2006 at 21:12
My advice comes from a guy who designs bio diesel plants and runs his own bio business. I am also suprised about VW as in europe some of their engines are actually reccommended to use bio, alot like some jap cars ask you to use premium all the time. The VW engines are not different here. Also over here a lot of brands are brought in by aussie distributors who have to personally deal with warrantys. Given that we are way way behind the ball on bio fuels here and most people dont have access, why the hell would they want to warranty bio? Its bad business. But the consumer who does not kick up a stink misses out. As for the crops growing and acting as a carbon sink, if the machines run on dino diesel then its a reduction of 70% in emmissions, you can have zero emissions if all supporting equipment uses bio diesel. So BD is actaually 100% renewable with zero emissions.
The guy I know has a brand new common rail Pug running 100% bio. Runs like a dream. My car on bio also shows much better ability BUT its harder to start. Anything less than 100% bio will fix the starting problems but I recon 100% is best.
AnswerID: 199178
Reply By: rolande- Saturday, Oct 14, 2006 at 21:26
Doesn't this all sound similar to the ethanol debate a few years ago?
Just the manufacturers being conservative I would say
Rolande
AnswerID: 199182
Follow Up By: Member - Bill F (VIC) - Saturday, Oct 14, 2006 at 21:58
Rolande,
On NINEMSM.COM now
US reviews complaint about ethanol fuel
news.ninemsn.com.au/article.aspx?id=152531
Bill F
FollowupID: 457997
Follow Up By: Scubaroo - Saturday, Oct 14, 2006 at 22:45
*Big* difference between the E10 in Australia and the E85 in the US. The problem is also limited to one or two models.
Most of the cars in Brazil run quite happily on ethanol blends between E25 to E100.
FollowupID: 458004
Reply By: Doggy Tease - Sunday, Oct 15, 2006 at 00:40
Gday Mother...:0
We have been running 10% Bio in the Patrol for nearly two years now, without a single problem. We fuel up out at Lorrie's in Kelmscott...they use the stuff Gull make.
As well as the patrol, i run it in our truck, which has a Cat 425hp motor, and i think the old girl runs alot better on Bio. The economy dropped off for a short period when we first started using the Bio, but quickly returned to normal.
So for me at least i have no problem using Bio at all, especially when it is usually about 6cpl cheaper than most other places. And using roughly 500-600lts every three days,,,well there is a big saving over a year.
meow.
rick.
AnswerID: 199213
Follow Up By: hl - Sunday, Oct 15, 2006 at 08:16
Is that Patrol a 3.0 TD?
FollowupID: 458030
Follow Up By: Motherhen - Sunday, Oct 15, 2006 at 10:02
Hi Rick - I'm pleased to hear of your success. I'm sure most of it is fear of the unknown by manufacturers.
I will not risk doing anything outside of manufacturers recommendations while we have the ZD30 motor Patrol.
It is not an option for us to purchase anyway, so cannot try it in other vehicles.
FollowupID: 458045
Follow Up By: Doggy Tease - Sunday, Oct 15, 2006 at 18:31
Gday all.
hl,,,yes this in a 3,0tdi
Motherhen. We have never had a problem running the B10 from Gull, which Lorrie's use, so are mere than happy with the savings we have had on fuel.
From memory, you dont live in Perth do you,,,,,is it somewhere a bit further south?
meow.
rick.
FollowupID: 458124
Follow Up By: Motherhen - Sunday, Oct 15, 2006 at 18:48
Not that i think it would be a problem - don't want to do anything non standard or not by their recommendations in case we have to scream at them should the motor join the long list.
Yes, i am at Bridgetown.
FollowupID: 458127
Follow Up By: Tim HJ61 (WA) - Monday, Oct 16, 2006 at 10:45
Gull is producing B20 I understood.
It's my fuel of third fuel of choice.
First being vege oil, then B100, then Gull B20 then DinoD
Tim
FollowupID: 458224
Reply By: Ray Bates - Sunday, Oct 15, 2006 at 10:34
Isn't it about time that the vehicle manufacturers lifted their game so that vehicle can run on bio- diesel. We have just taken delivery of a brand new Mercedes Sprinter and was told not to run it on bio-diesel or are the vehicle manufacturers in the pocket of the big fuel companies????????
AnswerID: 199246
Follow Up By: Tim HJ61 (WA) - Monday, Oct 16, 2006 at 10:52
Ray,
Have you checked the European websites for the same vehicle and seen what their recommendations are??
I suspect that the Euro recommendations will be different, but the vehicle won't be any different. Might be useful to challenge your distributor to ask why.
BioD ADDS lubricosity - therefore must be better for the pump.
BioD softens rubber fuel lines over time, and rubber seals, so there 'may' be an issue in vehicles with rubber fuel components but as I understand, modern vehicles haven't used rubber.
I've run my HJ61 12HT on alternatives for coming up to a year now. No sign of softening lines yet.
Tim
FollowupID: 458225
Reply By: traveller2 - Monday, Oct 16, 2006 at 08:28
All those that buy fuel at Volume Plus (in NSW at least) are running bio at up to (it is suspected) 40 %. I've been running B100 in the warmer months with sero problems, does make cold starts harder as the weather cools though. Usually any mix up with dino relieves the cold start problem.
Having had an injection pump on a 1HZ work vehicle totally rebuilt at 190k as it was totally buggered after running on Dino all that time I'd say things could only improve by running it on bio.
Especially with the increased lubricity, apparently most dino has bio added these days to replace lubricity lost with the sulphur removal anyway.
No advantage to the employer with a tiny fleet to change though when using fuel cards from Shell etc.
AnswerID: 199367
