What do others do
Submitted: Saturday, Oct 14, 2006 at 21:19
Member - Brian (WA)
Hi All. Today went to change the rear
wheels over in the driveway. The wheel studs were that tight I could shift them. What If it was on a isolated track
somewhere and I had a puncture. Dont know how they got that tight, but just had it serviced.Maybe they got swapped around. What do you more experienced
traverllers do? Carry a 5ft long piece of pipe for extra leaverage.
Cheers Brian
Reply By: Notso - Saturday, Oct 14, 2006 at 21:23
Buy a 12 volt rattle gun., or ask the tyre mob to only use a hand wheel brace to tighten your nuts??
199181
Follow Up By: RosscoH - Sunday, Oct 15, 2006 at 07:48
It's law in Queensland that all wheel nuts must be done up with a torque wrench, don't know about other states, if you know a tyre company that doesn't use a torque wrench advise the Office of Fair Trading.
RosscoH
458028
Follow Up By: Alloy c/t - Wednesday, Oct 18, 2006 at 18:53
RosscoH ,the "law" ,would love to know where you get that from , Im not having a "go" at you in any shape or form ,just show us " what the " law is that states a torque wrench has to used , ,,
458696
Reply By: Muzzgit [WA] - Saturday, Oct 14, 2006 at 22:01
Yeah, depending on whether the apprentice did 'em up, they could fall off or snap from being too tight.
I bought a set of free wheeling hubs today to replace the crap auto hubs on the GU, and when I did the left one, the bolts were reasonably tight and everything was clean [just had the wheel bearings re-greased] while on the right side the bolts were so tight I couldn't believe it and there was so much grease it was falling out as I took off the FWhubs.
Obviously the boss did one side and the apprentice did the other.
199188
Follow Up By: Member - Davoe (Nullagine) - Sunday, Oct 15, 2006 at 16:25
sounds like the apprentice had to take over and do the left side after th boss had to take a call after doing the right
458103
Reply By: Member - Phil G (SA) - Saturday, Oct 14, 2006 at 22:08
Smear of grease on each of the studs.
199189
Follow Up By: V8 Troopie - Sunday, Oct 15, 2006 at 01:35
Anti seizing compound would be better than grease for that job. It comes in a little tube and lasts forever as only a small amount is required.
Klaus
458021
Reply By: Scubaroo - Saturday, Oct 14, 2006 at 22:35
First thing I do after having tyres fitted is take off the nuts, put a drop of oil on the studs, and retighten by hand. Check them a couple of days later. Never had a problem with stuck nuts, and never lost a nut. You get a feel for how tight they should be done by hand.
I have had to use the hand winch handle as a "breaker" bar before to get enough leverage - complained to the tyre place on my next visit and they had said they were aware of the problem, and had replaced a particular rattle gun. This time the nuts were correctly tightened - but I always loosen and retighten by hand anyway.
199195
Reply By: Shaker - Saturday, Oct 14, 2006 at 23:08
Every nut on your vehicle has a recommended tension .... for a reason!
I had tyres fitted a few years ago, before I took the car I asked who fitted the
wheels back on the car, I got the genuine wheel wrench out of the boot & asked him to undo a nut ....... Guess what?
199199
Follow Up By: Bonz (Vic) - Sunday, Oct 15, 2006 at 08:19
every nut, even the driver
458031
Reply By: Motherhen - Saturday, Oct 14, 2006 at 23:40
I always kept a piece of pipe, only about 12" long, behind the seats of the Cruisers. 1" pipe was the right size to go over the wheel spanner. That was enough to assist me undoing the wheel nuts. I could jump on it if i couldn't undo them with this little bit of extra leverage.
The tyre service used to hate it when i came in after my guys had done them up by hand - always too tight and hard to undo - they just don't know their own strength. No wonder i needed the piece of pipe.
199204
Reply By: Gerhardp1 - Saturday, Oct 14, 2006 at 23:47
Get one of the 12v rattle guns.
I had to do a diff seal last week, and I tried to undo
the nut with my Supercrap air impact gun but
the nut just laughed at it.
Bugger, thought I, and then remembered the Shentai.
The nut stopped laughing.
Same applies to wheel nuts - they are easily removed with these babies no matter how tightly the moron at the tyre place screwed them up.
Only $79.00 or so, a must have tool.
A mate with a puncture on his troopy north of
Dargo couldn't release his nuts. I got out the Shentai and he looked at it and laughed, but he didn't laugh for long when it took the nuts off with a few slaps.
199205
Reply By: Member - Hugh (WA) - Sunday, Oct 15, 2006 at 01:37
Hi Brian,
I use a torque wrench. Once you've done this once, you'll realise just how overtight guys with rattle guns do them up. The tyre dealer I take my business to gets his guys to use a torque wrench as
well. After I get my vehicle serviced I always back off the nuts and retorque them just to make sure I don't get stuck with nuts that can't be undone when on the road.
Hugh
199215
Reply By: Richard Kovac - Sunday, Oct 15, 2006 at 03:09
Maybe you need to put on a pit a of weight LOL
Before you go on a trip try loosing all wheel nuts off and then torquing them up to the correct torque
This way you can only balm yourself
Richard
199219
Follow Up By: Bonz (Vic) - Sunday, Oct 15, 2006 at 08:21
Richard, this is a family site, anything that you may (or may not) do whilst away that is not mainstream and suitable should be whispered or not mentioned.
Now ... that said .... what type of balm do you use? I have tiger balm and it chafes...........
458032
Follow Up By: Richard Kovac - Sunday, Oct 15, 2006 at 21:15
Sorry Bonz
But I don't really under stand you
And it's my spelling mistake but thats OK I was ran over by a truck when I was
young.....
458176
Follow Up By: Bonz (Vic) - Wednesday, Oct 18, 2006 at 18:36
Aslong as the truck didnt hit your balm mate you're right
458690
Follow Up By: Richard Kovac - Wednesday, Oct 18, 2006 at 20:51
Are you a bit of a dick on E????
458715
Reply By: anglepole - Sunday, Oct 15, 2006 at 16:06
Hello,
Before you do the big trip use the T/wrench on the
wheels as a part of pre trip preparation.
You know the
well known adage if you want the job done
well do it yourself.
199283
Reply By: Truckster (Vic) - Thursday, Oct 19, 2006 at 07:38
Search for a thread where 10.30pm night before a long weekend trip, I was stuck in the driveway last wheel, last nut and the crossbrace snapped
the nut was that tight.
This was the same day I had new tires fitted and they must have rattlegunned the nuts on there for hours to get em that tight..
ended up gettin Crazie to come to the rescue with his compressor and rattle gun*
*shut up adam.
199774
