Follow up re what do others do
Submitted: Sunday, Oct 15, 2006 at 15:40
ThreadID: 38526 Views:2296 Replies:3 FollowUps:2
Well got to thinking that I am stuck with no help, What to do. Went and had a
look at what I carry.in the toolbox. Ended up using a 19mm socket with a
sidchrome fixed drive. Stood on it, sometimes jumped on it (Richard I weigh 100kg am told I need to lose it ) but managed to get the nuts loose and change the wheels. Did think that I would bend the drive but no.Maybe would have if it was a
Supercheap one. Thanks to those who offered advice.
I think the best will be check the nuts if it goes in for a service as soon as you get it home. cheers Brian
Reply By: Member - Hugh (WA) - Sunday, Oct 15, 2006 at 15:48
Hi Brian,
Should have added this last time as I didn't pick up that you had yet to undo the nuts. I would have taking it back to your service centre, handed the manager the std wheel nut wrench and asked him to undo them for you. Rest assured, they'd get the message pretty quick and you'd not have the trouble of doing it yourself.
Hugh
AnswerID: 199280
Reply By: Mike Harding - Sunday, Oct 15, 2006 at 16:04
Had a similar problem some distance from Broken Hill about four years ago. Put the wheel nut socket on the bar with a sliding half inch drive head which is about one foot long (don't know what it's called). Attached the spark plug socket to the normal extension bar (about one foot long again). Placed the spark plug socket over the end of the bar with the wheel nut socket on it giving me a tenuous lever two feet long and undid wheel nuts - thought I was going to bleep ter the spark plug socket but it held.
On return home went to Kmart and purchased telescopic half inch socket lever about 2.5 feet long when extended. Also called service people (main dealer) and "mentioned" the incident to them.
Mike Harding
AnswerID: 199282
Follow Up By: Member - Jack - Sunday, Oct 15, 2006 at 16:46
They must breed them tough at Broken Hill. I had a similar problem with removing a wheel that had been tightened up in Broken Hill. Luckily I had already bought my extended wheel brace, but it was still an effort to loosen the nuts.
Another place for tough nut tighteners is Tibooburra.
Jack
FollowupID: 458111
Reply By: Footloose - Sunday, Oct 15, 2006 at 19:36
A few years ago when I was young and fit, I had the same problem. Flat tyre and no way of getting the nuts off. Since then I always ask the tyre guys to do the last bit by hand. BUT when I bought a new set of tyres from my local tyre place I asked the new fitter to do em up by hand.
This big pig went off the handle, swore at me and generally went ballistic. As I'd asked nicely, I wasn't happy. The manager came out and apologised for the guy and explained that he couldnt do much as the fitter was the new partner!
I have never been to that place again. No other tyre place has taken exception to my asking.
But these days I carry a piece of pipe in the back, just in case I can't get the nuts off again.
AnswerID: 199316
Follow Up By: Willem - Monday, Oct 16, 2006 at 07:50
I carry an old Hi Lift Jack handle for stubborn nuts.
I insist on wheels being tightened by wheel spanner and my tyre blokes are trained. I very seldom get someone else to work on my tyres as it is and do all the mucking around my self...lol Just plonk your arse in the dirt and lift the wheel on:-)
FollowupID: 458204
