Cruiser/Patrol
Submitted: Monday, Oct 16, 2006 at 19:14
ingo57
Because of our growing family early next year we are upgrading our trusty pathfinder either to a new patrol or cruiser petrol 5 speed.
Given that these two are both very capable 4wds, I have been doing a lot of research on the
forum of the problems encountered with them.
I have read a bit about the Cruisers problems with IFS and blowing front diffs.
With the Nissan's I've read a lot of loosing 5th gears which can become quite costly if out of warranty.
I do not wish to buy the first of the new models which may be released next year, I will go for the current shape but brand new, for in my opinion both manufacturers have had a few years to sort out some of the bugs.
I would like to know peoples point of view on these matters and if you feel that these problems are still existing in the 2006 models or any other problems for that matter.
Reply By: Member - Davoe (Nullagine) - Monday, Oct 16, 2006 at 19:37
check out the current edition of 4wd monthly for a rightup on buying late model crusers 2nd hand
199440
Reply By: Member - Shane D (QLD) - Monday, Oct 16, 2006 at 19:51
NISSAN or TOYOTA?
I've seen drunken yobbo's punch each other out over a similar debate(holden/ford)
some toyota owners will never buy toyota again(for whatever reason)
ditto for nissan
My suggestion is if you don't have an affection for either, keep an open mind when searching and one/or the other may
jump up at you,with the specs you want.
the cruiser IFS has been rectified in the newer models and the 5th gear drama in the nissans(I thought)only affected 4.2 TD.
If you search long enough for inherent faults in ANY vehicle, you will begin to wish you owned a horse!
shop around, tell each dealer your shopin' each other off and see what goodies you may get
both makes have vast array of after market gear(no advantage to either makes)
The answer to your post is there is no answer,only the opinions of those who take the time to reply
199444
Follow Up By: ingo57 - Monday, Oct 16, 2006 at 20:34
Shane thanks for your comment's mate, I understand this can be quite a touchy subject but I am not asking for which vehicle is best.......... just trying to gather as much info from first hand owners before making a decision and handing over a large amount of money.
Regarding the "5th gear drama in the nissans" are the gearboxes in the 4.2 turbo diesel different to the petrol 4.8?
458308
Follow Up By: Kumunara (SA) - Tuesday, Oct 17, 2006 at 00:17
The 5th gear problem was only in one model. Basically manual patrols manufactured in 2000. The same gearbox was used regardless of motor.
458372
Follow Up By: dj Patrol - Tuesday, Oct 17, 2006 at 20:57
And 1999 as
458517
Reply By: Trevor R (QLD) - Monday, Oct 16, 2006 at 20:01
Hi ingo,
I have owned both a 100 series and a GU and my opinion (if you are buying new like you said) is put a value on the cruisers warranty and if it is more than 15 grand then buy the cruiser cause the Nissan warranty ain't worth the paper it's written on in my opinion and 15 grand is about price difference in the two 4.2 turbo variants. At least Toyota will bend over backwards to help in any way they can if you have a genuine problem (that's my experience anyway). Even though I had more mechanical problems with my cruiser over my GU, if buying new again I would go the cruiser for warranty reasons alone. Plus it is a nicer car to drive on the road IMO.
As mentioned above it is a touchy subject with some people but if you look through the one eyed responses you should get your answer.
Regards, Trevor.
199447
Follow Up By: Stu050 - Monday, Oct 16, 2006 at 20:41
Toyota usually has a higher resale value than the Nissan as
Stu
(flame suit on)
458311
Follow Up By: PatrolBen - Monday, Oct 16, 2006 at 22:05
Because it cost more in the first place !!!!!!!!!
458347
Follow Up By: Stu050 - Monday, Oct 16, 2006 at 22:09
Ben,
Sorry, but I have to do it.
You only get what you pay for....
Stu
458350
Follow Up By: PatrolBen - Tuesday, Oct 17, 2006 at 19:47
and thats why some people try and defend Terracans LOL
458494
Follow Up By: dj Patrol - Tuesday, Oct 17, 2006 at 20:54
Well after my aftermarket service with my Patrol I would go for the Cruiser gotta be better than this that some of us are suffering from our own back pockets.Because of my selection of 4x4 wont get caught again.
dj Patrol.
458514
Reply By: Chucky - Monday, Oct 16, 2006 at 22:39
Thou I own a mighty 80 series and have no intentions of buying another 4wd I have thought about this issue.
IMHO it all comes down to what you expect a 4wd to do.
If it will mainly be a daily driver and only taken off road once in a while then the cruiser is the go. It is alot nicer to drive on road than the datsun and the finish of the car seems to be alot better in the cruiser. Little things like dashes fitting flush and panels being aligned etc seem to stick out when you have both of the 4wd's side by side.
The IFS is abit of limiting factor but not by much, nothing a front lockka won't over come. I also know quite a few people who own these and the front diff weakness seems to only show up in used in reverse. Again nothing a lokka wont fix.
If you are after a more capable straight out of the box then I think the datsun is the goer here. But road handling etc etc wont match up.
And of course the cruiser does have better re-sale.
If money was no object then I reckon a cruiser with lokka's is a clear winner.
199488
Reply By: Member - Big Al. Gold Coast - Tuesday, Oct 17, 2006 at 08:50
We took our time, made a list of pro's & con's for each.
Spent at least six months checking out the
forum's.
and in the end it came down to dealer after sales service (on new vehicles).
Now very happy with our choice.
199534
